      11-26-2023, 12:52 PM   #1
1M Tex
1M Tex's Avatar
Drives: 2011 BMW 1M Coupe, AW,
high mileage 1M
190,000 miles. What does the collective group think the 1M N54 engine can achieve in total miles?
The 1 series M is the most badass, coolest, sickest BMW to debut since the 1988 M3. The E30 M3 finally has a successor. Please welcome the stupidly fast, wickedly tempered, awkwardly named, possibly perfect little son of a benchmark - Automobile Magazine, August 2011
      11-26-2023, 01:07 PM   #2
nachob
Really depends on the care it received. Oil changes etc. The engine can probably go a little more but stuff around it breaks. Turbo lines leaks, vanos will need rebuilding, vacuum leaks etc. The amazing thing about the 1M is that the stuff is not exotic though as far as the engine goes. If you don't drive it a lot, it will be better but I wouldn't get it as a daily at that mileage. Just too much plastic stuff that will start to fail.
ayao643.00
      11-26-2023, 01:14 PM   #3
PRTSB1M
Drives: AW3 1M
300k for internal bearing surfaces. How much oil is it consuming at 190k?
      11-26-2023, 03:44 PM   #4
1M Tex
1M Tex's Avatar
No oil consumption. Oil changed with Liqimoly every 5000. Vanos errors appearing.
ayao643.00
      11-26-2023, 07:55 PM   #5
PRTSB1M
Drives: AW3 1M
No oil consumption is a great sign. I have spare vanos solenoids for when mine start to fail. Have you tried cleaning or replacing the vanos solenoids yet?
markslc1183.00
      11-26-2023, 08:47 PM   #6
1M Tex
1M Tex's Avatar
Yes. New ones installed.
ayao643.00
      11-27-2023, 05:39 AM   #7
PRTSB1M
Drives: AW3 1M
If it were my 1M and I was getting vanos errors at 190k after replacing the solenoids, I would probably consider replacing the whole timing setup... and maybe cams/springs/guides while I'm in there.
      11-27-2023, 08:05 AM   #8
1M Tex
1M Tex's Avatar
Agree. Or replace the entire engine.
      11-27-2023, 01:52 PM   #9
PRTSB1M
Drives: AW3 1M
Yeah, a full rebuild would probably be in order, as long as the cylinders and crank are still in good shape (should be with no oil consumption). Fresh rods and a set of mahle's forged pistons would be nice.
I'm only at 60k on mine, but have RB ones, akra down and mid pipes, uprated low pressure fuel pump, dual oil coolers, CSF radiator, and a fresh water pump to put in over the winter.
Shifting at 7k in the spring
1M Tex240.00
      11-27-2023, 07:51 PM   #10
Pyrat_1M
PYRAT
Drives: BMW 1M
This.
N54's are dirt cheap, just swap it out for a low milage one from a wreck.
1M Tex240.00
      12-20-2023, 08:20 PM   #11
1M Tex
1M Tex's Avatar
Compression test completed all cylinders at 191 psi. Cam cradles in excellent condition. New vanos actuators and chain and seals going on. Let's go another 100,000 miles!
Appreciate 9
Tornado1M1211.00
1'M Blue255.00
PRTSB1M300.00
WTFM221.00
ayao643.00
      12-25-2023, 10:36 AM   #12
Eyeman
Eyeman's Avatar
121
That's cool to see. I have 140k miles on my full modded 135, I'm surprised to see a 190k mile driven 1M. My car has 400whp and I bet I averaged oil changes around every 10k miles and I have no oil consumption. I'd guess my car goes into limp mode about twice as often as it did when lower miles (almost always I just turn it off and it's fine when restarted).
