08-25-2014, 09:05 AM | #1 |
Rep 3,856
Possible throttle response issue
Okay, this past weekend was my first HPDE and this is where I noticed this issue as I was full throttle in many situations. I kept having the same problem though on the straight up to turn 7 at NJMP lightning track. Basically I'm full throttle in 4th gear and I want to just hold the speed so I'm letting off, letting off, letting, off, and nothing is happening, the car is still charging forward just as fast as it would if I was 100% on it. It's only when I'm significantly off the gas that the car begins to slow its rate of acceleration. I have an N51, everything stock except for the Active Autowerke tune (which was installed before I bought the car). I've heard of an issue similar that member KGolf was having who also has the N51 and AA tune where he'd let off the throttle but there'd be some lag between his actual inputs and what the engine was doing. Is this the issue I'm having?
Thanks |
08-26-2014, 07:43 AM | #3 |
Rep 3,856
08-26-2014, 12:19 PM | #4 |
Resident Tamed Racing Driver
298
Rep 4,697
I certainly would hold off tracking until I got that sorted.
08-26-2014, 08:42 PM | #5 |
Rep 701
The reason I bring that up is because I believe the DME has some influence on the Accelerator Pedal Module & the Electronic Throttle Valve. I would just drop A.A. an email with a description of you situation and ask them if they have any ideas or if they modified/adjusted any of those systems.
08-26-2014, 09:29 PM | #6 | |
Rep 3,856
08-26-2014, 09:45 PM | #7 |
Rep 3,856
I will say that the change over around 4-4.5k with the DISA is INTENSE to say the least. It kicks in like a brick wall!
08-26-2014, 09:49 PM | #8 | |
Rep 701
08-27-2014, 06:11 AM | #9 |
Rep 2,239
DISA kicked in yo!
08 e93 335i MT
08-27-2014, 07:57 AM | #10 |
Rep 3,856
08-27-2014, 12:30 PM | #11 |
Rep 957
coming from a 2013 128i N51, 4th+ feels like cruising gears. The car has quit a bit of momentum behind it by the time you hit 4th gear, which means it requires very little gas to keep it moving. This may be why it feels like the car is still charging forward when you let off the gas a bit in 4th. However, once you've hit fourth the car lacks power to accelerate fast enough to feel a big enough momentum shift when you let off the gas.
Like others have said, giving the car slight throttle v.s. full throttle in 4th doesn't feel much different because at the speed you're going in 4th gear the car doesn't have the horsepower to feel the acceleration as much as you do in 1-3. Hopefully that made sense. lol. Maybe I am completely wrong and the lack of throttle response in 4th is the result of fuel efficiency programming. |
08-27-2014, 01:20 PM | #12 | |
Rep 3,856
One of the things that is a pain in the ass really is the DISA change over at around 4-4.5k. It totally fucks up the throttle input. If the Active tune is magnifying this effect, then it is getting removed altogether. EDIT: AA got back to me and said it is the first time they have heard of this. Relevant info from their website: "Modifications to the a/f, ignition tables, VANOS, Vlavetronic systems, and wide open maps" "Sportier throttle response" This is a tune that can be removed safely right? or no? |
08-29-2014, 06:53 AM | #13 |
Rep 1,623
Drives: Alpine White 128i Cabrio
Didn't Kgolf have this same issue/feeling?
2008 128i E88 / Alpine White / Boston Leather Sport / 6AT / M3 Paddle Shifters / Bilstein B8 / H&R Springs / Dinan Fixed Camber Plates / BMW 335i Front Brakes / PIAA Xtreme White 4150K Angel Eyes / Rear Fogs Enabled / Cyba Air Scoops / Euro Airbox / BMW Performance Exhaust / Stubby BMW Antenna
08-29-2014, 01:29 PM | #14 |
Rep 3,856
