09-27-2014, 06:00 PM | #1 |
Rep 265
Help- Heated Seat Fail
Hi,
My wife's 2009 128i (sport seats) driver side heated seat recently stopped working. All other electronics on the seat work fine. Passenger seat also works perfectly. When you push the button, the three lights light up and immediately turn off. A click can be heard from under the seat. Intermittently I can get it to work by pressing the button over and over. Based on what Internet research I've done, this isn't an uncommon problem however I've yet to read about a fix. Any feedback or direction would be appreciated as BMW wants more than $1500+ to replace the whole lower section of the seat. Sadly the car just came out of warranty and local dealers are refusing to consider a good will fix. Cheers |
09-28-2014, 10:19 AM | #2 |
Rep 4,040
Drives: 130i coupé ;)
look at e46fanatics or e90post and see what they did in simmilar situations
Next realOEM.com should have separate part numbers for heating element or something else. Allowing you to save alot on only the affected part Then its matter of taking the seat apart, to learn and repalce the issue
09-28-2014, 10:27 AM | #3 |
Rep 1,623
Drives: Alpine White 128i Cabrio
Sounds like a circuit break or something. If the lights turn on then shut off right away. Maybe there is a wire somewhere that isn't connected properly or theres some sort of short in the circuitry. Just thinking out loud. I have no experience with this kind of stuff.
2008 128i E88 / Alpine White / Boston Leather Sport / 6AT / M3 Paddle Shifters / Bilstein B8 / H&R Springs / Dinan Fixed Camber Plates / BMW 335i Front Brakes / PIAA Xtreme White 4150K Angel Eyes / Rear Fogs Enabled / Cyba Air Scoops / Euro Airbox / BMW Performance Exhaust / Stubby BMW Antenna
09-30-2014, 05:48 AM | #4 |
Rep 1,409
I ran into this exact symptom prior to purchasing my wife's 2009 328i xdrive a couple of weeks ago. I even considered buying a second hand seat.
Just for the heck of it, I first raised the seat to highest position to see if I could see any damaged or disconnected wires under there. That was not the case, but still went ahead and pressed down and wiggled every single connector. The heated seat started working again and hasn't acted up since then.
09-30-2014, 02:07 PM | #5 |
Rep 4,040
IS there fuse in the glove box that connected to this feature too?
10-02-2014, 10:41 PM | #6 |
Rep 541
Are you looking for an electric, heated, sport seat? I have one for sale.
2008 Sedona Red 128i
Black Chrome powder coated VMR 710's 18's, Carbon fiber engine bay cover and intake, Carbon fiber interior trim, Demon eyebrows, euro intake, performance brace, black grills, Magnaflow exhaust, Stage 3IM, AA Tune |
10-05-2014, 08:36 AM | #7 | |
Rep 265
