      09-30-2014, 08:55 PM   #1
E82IsTheWay!
E82IsTheWay!'s Avatar
15
Drives: 2011 535i
211111111111111111111111111
0000000000000000000000000000000000
      09-30-2014, 09:15 PM   #2
andrey_gta
andrey_gta's Avatar
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
Yes all the holes & DISA are there.
Make sure you take off all the screws/sensors before washing. Dish soap works well and tons of rinsing
      09-30-2014, 09:54 PM   #3
MarkkyyMan
MarkkyyMan's Avatar
Drives: 2010 BMW 128i
http://www.turnermotorsport.com/p-17...28i528iz4.aspx
^Part Numbers.
      09-30-2014, 10:15 PM   #4
E82IsTheWay!
15
Drives: 2011 535i
Originally Posted by MarkkyyMan View Post
it varies i believe from car to car but i think they are all the same. the one on turner is from a bmw 330i
      09-30-2014, 10:56 PM   #5
MarkkyyMan
MarkkyyMan's Avatar
Also has pictures to compare. If it is truely from an N51 then it is a DISA manifold.
      09-30-2014, 11:15 PM   #6
E82IsTheWay!
15
Drives: 2011 535i
all the pics match up perfectly its just that i dont have that y pipe thing, do i need it, where can i buy one?
      09-30-2014, 11:27 PM   #7
MarkkyyMan
MarkkyyMan's Avatar
www.realoem.com
look up the part #, dealer can get them.
Or
Search around on here, few other people made threads to verify they had the correct manifold.
      10-01-2014, 05:56 AM   #8
631twentyeighteye
631twentyeighteye's Avatar
Drives: 08 335i
Looks like the correct one. Seems to have come off a x30i not a x28i n51, but regardless its the same manifold with the DISA motors.
08 e93 335i MT
      10-01-2014, 09:28 AM   #9
E82IsTheWay!
15
Drives: 2011 535i
cant seem to look up the part number on real oem, but judging from what people say it seems to be correct.
      10-01-2014, 01:07 PM   #10
andrey_gta
andrey_gta's Avatar
x30 manifolds i think were used in n51 with no part number change hence why the sticker has n52b30
      10-01-2014, 11:12 PM   #11
E82IsTheWay!
15
Drives: 2011 535i
Hey guys how should i test these DISA pieces before i put them in?
      10-02-2014, 09:42 AM   #12
andrey_gta
andrey_gta's Avatar
Yes its easy to do
With the Valves in your hands before the electronic test
With DISA in your hand gently try to wiggle the Flap- it should be tight and require good finger pressure to even move it slightly
Inspect the base of the flap for any damage, failure via age, movement
With your car, still with OLD Manifold installed:
1) get a friend/relative
2) Connect disa to any disa cable - hold Valve in hand by the motor side
3) Neutral/ car off position is OPEN
4) once the car is started into idle the valve will Close
5) Turn off car, disconnect Valve
      10-02-2014, 03:19 PM   #13
E82IsTheWay!
15
Drives: 2011 535i
      10-02-2014, 06:35 PM   #14
andrey_gta
andrey_gta's Avatar
I really dont like that tear at the bottom of flap on each one. Otherwise all those damages are okay.
Look up some industrial silicone glue that can take heat and oil.
I dont think superglue is Safe because it can brake into pieces. Same for epoxy.
Otherwise I cant say its worth to do anything. In some places you may even cut it off if you feel it wont impact the seal alot
      10-02-2014, 07:31 PM   #15
E82IsTheWay!
15
Drives: 2011 535i
im thinking just some normal silicone and putting it on both sides of the seal, very light coat?
      10-02-2014, 07:37 PM   #16
631twentyeighteye
Drives: 08 335i
I think it will be okay regardless. I guess it wouldn't hurt to put a small drop of some sort of bonding agent on the bottom one but i personally wouldnt worry too much.
08 e93 335i MT
      10-02-2014, 07:41 PM   #17
E82IsTheWay!
15
Drives: 2011 535i
do you guys think i can use some permatex gasket maker?
