05-26-2008, 12:18 PM | #1 |
Rep 120
Scratch in clear coat
Jeez,
was cleaning some bird crap off the hood with a wet tissue and it left behind some really light scratch marks! Damn, never scratched a car before while cleaning it!! Think its from the clear coat I had put on?! Not terrible, im probably the only one who will notice it but it bothers me. I tried the scratch doctor stuff, really didnt work. Any suggestions? Thanks bski |
05-26-2008, 12:43 PM | #2 | |
Donkey Kong King
89
Rep 1,129
Bird crap will etch into the clear coat. Couple things to try. First, what really needs to be done to remove the scratch is the use of a high speed polisher with some mild abbrasive polish, this should clear it up. If you don't have access to a high speed polisher (Porter cable or Flex are my recommendations), then you can try meguiars Scratch X and a foam pad. You will have to work the area probably at least 3x's and you'll have to put some friction(meaning really rubbing back and forth) into the use of the foam pad. Bird Crap is very, very bad. If you see it on your car at any time, remove it immediatly, the longer it sits, the more time it will etch into the clear coat. |
05-26-2008, 05:40 PM | #4 |
Rep 334
I carry Meguire's Quik Detailer and a microsoft towel in the trunk at all times. It's come in handy more times than I care to think about. Preventive maintainence is key........
