      10-15-2015, 09:30 AM   #1
Suhb
Suhb's Avatar
119
Drives: 2010 128i Coupe 6-Speed
DISA Upgrade/Repair
Hey guys. I'm sure everyone knows about DISA valves failing in the older engines but has anyone run into DISA problems on the n52 engine yet? Apparently the DISA motors for the N52 can show problems as well. Has anyone has done either of these or plans to do a repair/upgrade in the future? the three stage intake manifold is on my mod list and I'm wondering if it's wiser to just do the upgrade/repair before installing it. Thoughts?
http://www.bimmerfest.com/forums/sho...d.php?t=792912
http://vanos-bmw.com/repair-kit-for-...-n52-n52n-n52k
      10-15-2015, 07:17 PM   #2
Blacksport
Blacksport's Avatar
54
Drives: 2013 128i
I bought all new parts when I did the Stage 3...if you buy a used manifold, get new valves.
I've read about the problems, but I believe there's many, many more cars that never had DISA problems...assuming I keep the car long enough, I'll probably replace the valves after 20k miles or 2-3 years...they're not that expensive.
'13 128i 6sp, '19 Cherokee Ltd 3.2, '17 Ducati SuperSport S Gone But Not Forgotten: 74 Z28, 77 Datsun 280Z (1st 5sp in US), 92 Nissan 300ZTT, 94 MB SL600 V12, 01 M Roadster, 66 Yamaha TwinJet 100, 70 Suzuki X6 Hustler Race: GP/FP Spitfire SCCA, Merlyn FF SCCA, Mazda RX7 IMSA GTU, Yamaha FZR 400 AMA.
      10-16-2015, 01:11 AM   #3
honestzergtea
Drives: 2010 335d
61k on my N51 and the DISA valves haven't given me any problems yet.
      05-17-2016, 11:08 AM   #4
gratuitous
gratuitous's Avatar
Drives: 2019 BMW X5 M-Sport (G05)
I have a 2011 128i with over 116K, and I'm consistently seeing a 002AAC code now. I'm going to start by replacing the upper DISA, since I don't have to remove the intake manifold for that, then replace the lower if that doesn't do the trick. It's too bad that the DISA valves can't be rebuilt for the N52K.
      05-17-2016, 11:07 PM   #5
gratuitous
gratuitous's Avatar
Wow, www.i6automotive.co.uk does manufacture a DISA repair kit. rhydtuned makes the rebuild look easy in this video:
      05-23-2016, 05:51 PM   #6
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
Mine failed around 70k miles combined on manifold plus my car. Was the last thing I repaired before I sold it.
      05-23-2016, 07:02 PM   #7
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
I'm confused. You sold the 1er?
Inertia is the enemy!
      05-24-2016, 06:34 AM   #8
TheSt|G
TheSt|G's Avatar
Yes.
Bought an Interlagos on Cinnamon E46 M3 that I'm manual swapping next week.
      05-24-2016, 03:15 PM   #9
chris82
chris82's Avatar
Drives: 128i
2009 BMW 128i  [9.80]
Yes.
Nice! but you had an awesome 1er! Will be missed here
      05-24-2016, 07:27 PM   #10
Fume
Drives: '19 Porsche 718 Cayman GTS
Yes.
Nice on getting the E46 M3. Sad that you sold your 128i though. Your DIY threads were always very informative.
New Car: 2019 Porsche 718 Cayman GTS | Stock for now
Old Car: 2013 BMW 128i | 6MT | BMW Performance Grills | CDV Delete | SSK | Performance Exhaust | M3 RSFB | TCKR DA
      06-03-2016, 03:58 PM   #11
TheSt|G
TheSt|G's Avatar
Thanks gents. Ultimately, I justed wanted a bit more performance.
Did the VANOS rebuild and lockdown on the M3 last month. It's actually a pretty easy/fun car to wrench on if you get a chance.
      06-07-2016, 09:11 AM   #12
gratuitous
gratuitous's Avatar
Hey Guys,
I replaced the upper DISA and the 002AA8 fault code is gone. The car feels like it has more low RPM power, and runs slightly smoother. However, I'm still regularly seeing the 002AAC (variable intake manifold, self diagnosis) fault message.
Should I pull the intake manifold and replace the lower DISA, or should I ignore this fault code?
Thanks!
Grat
      06-11-2016, 06:36 AM   #13
gratuitous
gratuitous's Avatar
Hey Guys,
I'll try this one again. Has anyone out there replaced their lower DISA? Was that the only way to make all faults go away? I'll rip out that intake manifold if I must, but I was hoping to get some guidance from you all.
Summary: DISA upper replaced after seeing 002AAC and 002AA8 fault codes. Now just 002AAC remains consistently.
Thanks!
Grat
      06-11-2016, 08:44 AM   #14
Bimmer-Bob
Bimmer-Bob's Avatar
Drives: 2010 128i
Originally Posted by gratuitous View Post
Hey Guys,
Thanks!
Grat
You might have more luck over at E90Post (in the N52) section, as you'll reach a lot more people over there. I've not heard of any people over on this side having to replace there DISAs yet (other than in this thread).
That's interesting that you got a couple of fault codes. I was wondering how easy the issue would be to diagnose if it occurred. Did you get a CEL or SES light, or did you just notice a downgrade in performance, and then check for codes? Ho noticeable was the degradation in performance?
FWIW, if I were you, I would just go ahead and change the second DISA. I mean, you changed one and it cleared one fault, and one remains. And it seems reasonable to change both simultaneously (although it seems weird that they would fail simultaneously, it also seems like if it's a wear issue that they would have similar service lives).
EDIT: Doing a quick Google of that fault code, I don't see what else the issue could be. I might run the car by an indy to see what they think if you really want to know for sure before ripping the intake manifold out, if that's your hesitation.
Just out of curiosity, is your car an N51 that cam stock with the DISA motors, or an N52 where they were added afterwards? Mine is an N52, and I swapped in the 3-stage manifold - I'm wondering if my car would even "know" these codes in case of DISA failure? I know they work without coding, and the fault code most come from a problem downstream (AFR sensor or something), so it probably would.
____________________________
      06-11-2016, 12:00 PM   #15
gratuitous
gratuitous's Avatar
Thanks for the reply.
Mine is an N52K that came stock with two DISA's in the manifold. There were no CEL or SES lights displayed. I purchased this car used, and therefore had no idea what the acceleration should feel like had the car been new. I only discovered the codes, because I was trying to sort out a right cornering light issue (different thread), which does display as a dash warning on start-up. I was also performing an whole car maintenance reset due to not quite knowing how the car had been maintained by the previous owner, and wanted to see what other sort of faults were occurring.
The degradation in performance was a subtle, low RPM sort of thing. When accelerating hard, I would notice a sort of drop in power between 3500 and 4000 RPM, and then get a surge of power after 4000 RPM. The engine definitely puts out more power at low RPM's now. You can definitely feel the increase in power in the seat of the pants, and the drop in power between 3500 and 4000 is not longer as harsh as it used to be.
I appreciate your recommendation for posting over on the e90 forum, and I may just replace the lower DISA for the heck of it.
Cheers,
Grat
      09-26-2016, 06:54 AM   #16
gratuitous
gratuitous's Avatar
Hey Guys,
I wanted to close this topic by letting you all know that replacing the lower DISA finally eliminated the last of my variable intake manifold codes. I found a couple of decent videos are how to remove the intake manifold, and was able to do the job myself with no drama.
Thanks,
Grat
      03-23-2019, 12:48 PM   #17
automan25
Drives: 2010 BMW 328i Coupe
Gratuitous,
Did you notice another improvement in performance when you replaced the lower DISA valve? Also, can you provide a link to the videos you mention. Thanks.
      03-23-2019, 03:21 PM   #18
desertman123
E82 Mudflap Ambassador
desertman123's Avatar
Drives: '08 128i
1992 Honda Beat  [9.50]
2008 BMW 128i  [10.00]
2014 BMW 528i  [10.00]
Originally Posted by automan25 View Post
Gratuitous,
My friend needed both DISAs replaced, I only needed the small/lower one and there's a dyno graph over at E90post showing what the power looks like with broken DISAs.
Based on how my car changed after replacing the small one, and how my friend's car changed changing both, I think the big DISA affects the 3-5k RPM range and the small DISA is lower end.
When I replaced my small DISA my partial throttle and low speed driving was a fair bit smoother, but I didn't feel I gained much if any power.
      04-13-2019, 01:56 AM   #19
juld0zer
If you have access to ISTA, i highly recommend using that to reset the DME adaptations after changing the DISA flap/s. I got throttle adaptation faults after doing it in INPA.
      04-13-2019, 12:01 PM   #20
desertman123
Drives: '08 128i
Yeah I'd imagine ISTA covers the throttle adaptation by itself too. Usually I just reset with INPA, then do the 'hold the throttle for 10 seconds' to reset it followed by clearing the codes.
