      03-28-2016, 12:07 PM   #1
dbiker207
dbiker207's Avatar
Drives: 2009 135i m sport
Help, Cornering bulb socket
I have been getting ccid 380 and 381 for faulty cornering lights. I believe that they are the h3 bulbs under the little cover on the top of the headlight assembly. When I took them apart to inspect i found lots of damage to the socket and bulb from arcing and i broke the drivers side one because it was stuck in the housing. I would like to order new bulb sockets but cant seem to find the part number. Can someone point me in the right direction? The only one I can find that looks correct says its for 2011 and newer...
I have a 2009 135i with adaptive xenon lights.
      03-29-2016, 10:40 PM   #2
HIPSI
Drives: 08 135i
I had this issue on my daughters 09 128 and had to replace the entire headlight housing $$
08 135 Coupe SGM/Terra
15 Porsche Macan S- Family Hauler
22 C8 Corvette 3LT HTC
      03-30-2016, 10:57 AM   #3
suspenceful
suspenceful's Avatar
Drives: 2015 M3, 2008 135i, 2009 335i
Is this the bulb you're talking about?
http://www.1addicts.com/forums/showthread.php?t=1002590
Part number: 63126940665
Or buy it on ECS: https://www.ecstuning.com/ES172889/
750whp 135i Build | Budget 335i Build | F80 M3 Build
🎬 YouTube channel (35K+ subs): youtube.com/jakespence135
📷 Follow me on Instagram: instagram.com/jakespence
🏁 Shop BMW merchandise: bimmerstreet.com
      03-31-2016, 04:57 PM   #4
chris82
chris82's Avatar
Drives: 128i
2009 BMW 128i  [9.80]
I just put in new stock headlamps but unfortunately they didn't have the turn signal socket. I bought 2 of them (They're cheaper from eBay due to free shipping). The part nr posted above is correct, and they are the same for both sides. I only managed to get my left side installed though; my right side is being a little bitch. I have it in correctly and lined up, but it only turns about 2 mm to the right and it needs to turn another 3 or 4 for it to lock in and work. Anyways, good luck
bulb, bulb h3, cornering bulb, headlight, socket
