      11-06-2023, 05:31 PM   #1
BigZ88
Cap'n Winky
BigZ88's Avatar
23
Drives: e90 330i
koni install fit and brake line route
All… I want to start by saying this is the biggest pain in the ass suspension swap I’ve ever done…
I finally got the new strut in and want to be sure brake line and brake line sensors are routed properly… please have a look
The brake sensor wire only seemed normal if i routed it in that loop…
Last thing, is it normal to have to load the suspension a bit to get the sway bar link in? I have the wheel/tire on the other side which may be the reason…
      11-07-2023, 09:03 AM   #2
Brandon_2011_135i
Brandon_2011_135i's Avatar
Drives: 2011 BMW 135i, 2012 Audi A4
If you have one side unloaded, and the other side under weight, then absolutely the sway bar will fight you. What was difficult about the suspension swap? are you using stock springs? Update on the ride quality later when you're up and running. I am looking for new shocks at some point and not sure what I want yet, but I don't think I want to do coils and lower the car. Are these the STR.T shocks?
      11-07-2023, 09:11 AM   #3
BigZ88
Cap'n Winky
BigZ88's Avatar
23
Drives: e90 330i
Well, the previous owner had tightened the shock tower studs until they spun… so I had to drill them out… took about 4hours of cursing, breaking drill bits etc. to get one side out. Granted all of this was made worse due to the m3 strut bar which pockets around the special nuts….
Then you realize with the relatively short springs on these cars the standard rental spring compressors will not compress the spring enough to relieve tension on the top hat safely….
Once you finally get it out, (made easier due to lack of studs) getting a stock length spring/shock back in is a bear. Only way I could see to do it was taking the caliper off to not stress/break the brake line. Even after that and having loosened pivots at the arms it was a struggle to get back into the car. Maybe someone knows a better way but I only ever saw tutorials getting shorter springs back in.
These are the str.t… happy to update when I get this whole thing back together.
      11-23-2023, 12:05 AM   #4
Donkeyshins
Drives: 2010 128i ZSP 6MT
2010 BMW 128i  [0.00]
Ugh...that *sucks*. It also sounds almost exactly like what I went through on Saturday helping my son with his E46 330Ci, although in this case, the overtightened shock tower studs were his fault (one broke, one spun, one came loose normally) - and yes, he was using the E46 M3 strut bar with the special nuts. Took us 5 hours to get the strut off the car (we only needed to replace the studs / hat on the driver's side).
I'm going to have to do my shocks at some point (sport suspension) - probably will keep the springs but go with Koni Sports. Thankfully I know my shock tower studs are tightened to spec and I've taken my calipers on and off enough times that I'm not worried about doing it again, although I may just replace the brake lines since the ones I have on the car now might very well be the originals from BMW.
2010 128i ZSP 6MT Coupe
Deep Sea Blue (Tiefseeblau) Metallic
Style 264 Wheels
Lemon Boston Sport Interior
BigZ8822.50
      11-23-2023, 11:22 AM   #5
BigZ88
Cap'n Winky
BigZ88's Avatar
23
Drives: e90 330i
I’m loving how it rides with these shocks. This is a weekend fun car, not a race car so it’s like oem+ I think factory m sport springs and these shocks are a perfect match.
