      12-19-2014, 05:38 PM   #1
Ilovemountains
Drives: 2010 128i M Sport 6MT Alpine W
      12-19-2014, 05:47 PM   #2
Vigilante375
Drives: 2012 AW 6M 135i
Have you read the manual and done anything it tells you to do? I had no problems hooking my car up to the bluetooth.
When you turn your bluetooth on with your phone and do a search, does anything come up? Also, do you have Navigation or no?
      12-20-2014, 01:10 PM   #3
heeblet
heeblet's Avatar
Drives: 2014 228i xDrive F31
pics of buttons?
      12-21-2014, 12:40 PM   #4
Motohip
Motohip's Avatar
37
Drives: 128i
all cars have the steering wheel buttons
      12-21-2014, 02:06 PM   #5
TheCaptain
Drives: m235i x 'vert
I don't know anything about why, but some cars don't have Bluetooth audio. Run your car through a VIN decoder to see if you have that feature on your car.
      12-23-2014, 07:28 AM   #6
david in germany
Drives: 118i, 335i and 328i
Or look under the trunk floor for the combox with the bluetooth symbol on it.
      12-23-2014, 11:01 PM   #7
JakeWJF
Drives: 2012 128i
Just hit the button and pair it like everything else. It doesn't have Bluetooth audio, just hands free calling only.
      12-23-2014, 11:03 PM   #8
JakeWJF
Drives: 2012 128i
Also so far as I know they have HD radio but no sat radio/XM.
      12-24-2014, 10:32 AM   #9
JakeWJF
Drives: 2012 128i
I was under the impression that hands-free was standard. Normally hitting the phone button on the radio takes to you another menu for that configuration (similar to the sound settings button). I assume the clock and music note button work to modify the radio display? Also I certainly have hands-free but I have not noticed a microphone near the map lights, but I will look again when I get home.
      12-24-2014, 02:03 PM   #10
TheCaptain
Originally Posted by Ilovemountains View Post
When I press the buttons nothing happens, Ive read the manual a few times as well, its almost like its missing the pairing section.
I was digging around online, should I have a microphone up by the map light buttons? If so, I don't....
The microphone is on the top of the steering column between the wheel and the gauges, it's a little slit in the plastic.
      12-25-2014, 03:08 AM   #11
david in germany
All I have down there is a battery.... or do I need to actually remove the trunk floor?
Under the trunk floor. You do have to lift up the whole thing.
      12-26-2014, 11:29 PM   #12
smellthebeans
smellthebeans's Avatar
Drives: LPCs
1990 325i  [0.00]
I'm having some buyers remorse on this one, that's what I get for assuming the thing had blue tooth, considering it has the buttons.
I cant imagine them putting an M steering wheel in the car and NOT installing the module to use it, that is ridiculous. Is it a plug and play card or module since its apparent the car has the damn buttons?
Good news bad news here. I purchased a 2010 128i with navigation (in 2011), under the impression that it came with bluetooth. Well guess what? No bluetooth. But, there is good news. With coding and a coupe of hours of DIY running wires from the COMBOX and you can add it in.
Search this forum for the retrofit.
HERE: http://www.e90post.com/forums/showthread.php?t=660738
