03-12-2009, 09:28 AM | #1 |
Rep 540
Active Autowerke Intercooler | Spring Special's
Hello,
I am having a Spring Special on our intercooler's for the 135's. Contact me for details. Below is some info on the intercoolers. A lot of people are under the impression that a wide intercooler is more efficient, that is not necessarily the case. The factory intercooler works well; however, we designed a much more efficient intercooler with much more surface are. With more surface area the intercooler will be more efficient. In addition our core is 88% larger than your stock intercooler. Our intercooler also comes with a specially designed shroud to force air over the entire intercooler evenly. Here is a diagram comparing our intercooler to the stock intercooler in regards to size and surface Area: http://activeautowerke.com/images/pr..._21378_656.jpg Dyno's: Power - http://activeautowerke.com/dyno%20im...ower%20Run.JPG Conditions - http://activeautowerke.com/dyno%20im...ion%20Runs.JPG In the "Power" runs you will notice there is no power loss after continuous runs, which is what you will feel on the street. Heat soak is just about eliminated. The "Condition" chart is the same chart as "Power", the temps get hotter and the power remains. p.s. Purchase of the intercooler will qualify you for a discount on our Signature badge. |
