      02-17-2023, 01:34 PM   #1
Expert@ApexWheels
Expert@ApexWheels's Avatar
3530
Drives: M3
APEX Forged VS-5RS 18" 1 series fitments incoming:
Hey All,
I wanted to give you a quick heads-up before we went into the weekend: After quite a bit of development time and back and forth on these wheels, we are releasing VS-5RS forged wheels for the 1 series.
The fitments are going to be 18x8.5 ET40 front, and 18x9.5 ET58 rear. This is a familiar combination to many with an offset in-between our ET45 and ET35s for the front wheel. It's slightly less ideal for completely stock cars but offers more room for anyone running aftermarket suspension that reduces inner clearance around the front suspension. The 18x8.5 ET40 can also of course be run square.
Many of you have already seen this car on 17" wheels, but here's a taste of the design on this chassis in a smaller diameter:
17x9 ET42 square shown above
Pledging for the 18" Group Buy is open and includes these wheels and the Fitment Guide is updated.
The wheels are arriving in May. While we weren't initially going to include them in the Group Buy, we wanted to give the 1 series community the opportunity to join the Ongoing deal and lock in a discount on these wheels, especially those of you who have been waiting since our original release.
I hope you enjoy these wheels and are as excited about them as I am. I'll have more news and content around these fitments in the future but let me know if you have questions about these wheels and I'll dive into them next week.
-Tom
Esteban43787.00
Fakemike368.50
houtan707.00
      02-17-2023, 08:20 PM   #2
twinturbovan
Drives: 2009 BMW 135i M Sport Vert
I want these so bad
      02-20-2023, 04:49 PM   #3
amg6975
amg6975's Avatar
500
Drives: '12 M1.5, '05 ZHP, '98 M3/4/5
How does the brake clearance compare to an SM-10? I'm about to do an AP CP9668 BBK on my "135" (with M3 knuckles, etc.) and was told the 18x8.5 et35 SM-10s I have are about the only non M3/1M wheel that will fit, but that VS-5RS is super sexy and the et40 would definitely be better...
      02-21-2023, 11:23 AM   #4
ResinThirteen
ResinThirteen's Avatar
191
Drives: 09 135i
2009 BMW 135i  [0.00]
Those are absolutely gorgeous! I don't usually prefer a square setup looks-wise, but I LOVE how much meat is on those tires!
      02-21-2023, 02:24 PM   #5
Expert@ApexWheels
3530
Drives: M3
The lower offset of the ET35 SM-10 and the thinner flow-formed spokes likely give it an advantage with regards to the spoke clearances on this kit. Are you using an E9X kit supplied by Essex in the US? If you’re using one of those and have the part numbers, I likely have it on file and can check clearances although depending on the parts you’re using it may be more of an estimate rather than an exact reference.
Agreed, the 17” setup looks amazing but the 18s should be much easier to fit.
-Tom
      02-22-2023, 09:53 AM   #6
amg6975
amg6975's Avatar
500
-Tom
Thanks for the reply, Tom. Yes I'm planning on going with the Essex kit here: https://www.essexparts.com/ap-racing...93-m3-1m-coupe
I talked to someone at Apex a little while ago and they confirmed it should fit with my current SM-10s. My car is essentially a 1M/E9x M3 at both ends but still has the 135 body panels.
The 18x8.5 et35 SM-10s juuuust fit in the front with 3.5 degrees of camber but it would definitely be nice to go to a et40. That would allow me to either eliminate rubbing with a 245/40R18 or, run a 255.
      02-22-2023, 12:05 PM   #7
Expert@ApexWheels
3530
Drives: M3
Gotcha, I'm putting in a request with our engineering team to check the VS-5RS against those brakes and double-check the SM-10s as well as I don't see test results on our internal sheets. The 9668s are a massive caliper because of those 25mm pads so I'm curious to see what the clearances are like here.
We have the clearances of this kit done against most of the M3 fitments, but not 1 series.
-Tom
amg6975500.00
      02-22-2023, 01:23 PM   #8
Expert@ApexWheels
3530
Drives: M3
Our engineers turned this request around quickly luckily. The actual M3 kit doesn't clear the wheels without spacers in either the SM-10 or VS-5RS design. A table to explain:
Green C denotes clears in all directions with no spacers needed or barrel clearance issues.
I found your email to our support team on 10/4/22. Geirsen didn't have the data for the M3 kit VS the 8.5" wheels on hand but he confirmed that the AP/Essex kit for the non-m e9x chassis cleared, which it does. The M3 kit on the other hand needs the spacers for the 9668 version as that caliper is thicker.
While it's nice to have that massive endurance pad in the calipers, the 9660 would be easier to run if you stick with the M3 kits. Again, caveats in your case if something is slightly different from the M3 assembly.
Hope that helps.
-Tom
amg6975500.00
      02-22-2023, 04:20 PM   #9
amg6975
amg6975's Avatar
500
Our engineers turned this request around quickly luckily. The actual M3 kit doesn't clear the M3 Kit without spacers in either the SM-10 or VS-5RS design. A table to explain:
Hope that helps.
-Tom
Wow, awesome info, thank you so much. I wonder what's different between the M3 and non-M kits. I suppose I could go back to the non-M knuckles and run the non-M kits. I'll have to get ahold of Essex and pick their brain about this.
It's also interesting that the 9668 kit needs more spacer with the VS-5RS, but with the 9660 kit it needs less(no) spacer with the VS-5RS.
      01-08-2024, 06:33 PM   #10
Expert@ApexWheels
3530
Drives: M3
Video & Photo shoot update
A better look at the 18" VS-5RS on a volunteer car:
Wheels: Brushed Clear VS-5RS with Hankook RS-4s
Front: 18x8.5 ET40 with 5mm spacer & 245/40-18
Rear: 18x9.5 ET58 with 3mm spacer & 265/35-18
We'll have photos soon, but thought you all might enjoy this quick video of the new VS-5RS in action.
houtan707.00
Brian_10.50
      01-08-2024, 10:10 PM   #11
N55e82Simon
N55e82Simon's Avatar
151
Drives: BMW 135i
2011 bmw 135i  [9.33]
Beautiful.
ApexWheels1427.50
      01-10-2024, 09:17 PM   #12
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Thanks for another excellent option in one series offsets. Quick question, Will these clear the F8 M3/M4, 380 mm brakes?
      01-11-2024, 10:59 AM   #13
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Drives: E82 Mutt, M57 Truck
In for this too.
Additionally what offset and width do you recommend for 1M clone bodywork and nonM rear subframe track width. I'm assuming 9.5et22 it's still the front spec.
2010 135i 6MT Jet Black
      01-11-2024, 11:01 AM   #14
Expert@ApexWheels
3530
Drives: M3
Yes, as long as it's the SLG adapter kit. I contacted the team over at Seems Legit Garage and got a scan of their conversion to have that info on file. A small table comparing it to our typical 1 series fronts can be found here.
Other kits might not share the exact same clearances if the calipers sit in a slightly different place.
-Tom
houtan707.00
ShocknAwe3234.00
      01-11-2024, 11:09 AM   #15
Expert@ApexWheels
3530
Drives: M3
In for this too.
Correct on the fronts. For staggered I tend to recommend the 18x9.5 ET22 up front. It looks great with a bit of camber. 10.5 ET22 can fit for the rear especially if you've done the e9x hub conversion for a bit of extra room.
This car is running that exact fitment: https://apexwheels.com/gallery/bmw/1...port-gold-1351
If you want a less aggressive front wheel, you can go to a ET28 9.5. If the car is going to be track-focused, 18x10 ET25 square is a good option provided you've got enough camber dialed in up front via camber plates.
-Tom
houtan707.00
ShocknAwe3234.00
      01-11-2024, 10:42 PM   #16
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
-Tom
Motorsport gold huh. Tickles the right spots. Wow.
      01-12-2024, 11:32 AM   #17
Expert@ApexWheels
3530
Drives: M3
Yeah, it's a great gold IMO. Its also available in the standard offsets for the normal 1 series fenders so you don't need a 1M conversion to get that color.
-Tom
      01-13-2024, 10:48 PM   #18
FrostyDC4
Drives: C63S Sedan|350Z
2007 Nissan 350Z  [0.00]
2012 BMW 135i  [4.50]
Rolled fenders?
C63S Sedan: Long Live The V8
350Z: The Very Poorman's 981 GT4
      01-15-2024, 12:02 PM   #19
Expert@ApexWheels
3530
Drives: M3
Originally Posted by FrostyDC4 View Post
Rolled fenders?
Not as far as I know, but the owner has made a number of modifications to the alignment and suspension.
Full mod list:
MCS 1 way coilovers with swift springs.
Ground control camber plates.
M3 upper and lower control arms.
Solid aluminum rear subframe bushings.
Adjustable rear toe arms.
H&R swaybar with ground contol endlinks.
Stoptech ST60 380mm big brake kit.
Bayoptiks headlights.
Carbon fiber front lip.
Carbon fiber mirror caps.
Boca style carbon fiber trunk lip.
Carbon fiber rear diffuser.
NRW carbon fiber interior trim.
NRW carbon fiber rear seat delete.
Recaro pole position seats.
M3 alcanatra flat bottom steering wheel.
IND alcanatara shift boot and ebrake boot.
      03-17-2024, 09:14 AM   #20
Vorsprung_CJB
Vorsprung_CJB's Avatar
Drives: AW 135i
Are your other style wheels discontinued for E82 fitment?
      03-18-2024, 10:59 AM   #21
Expert@ApexWheels
3530
Drives: M3
They are not, we're still producing the 18x8.5 ET45 and 18x9.5 ET58 in our ARC-8 and EC-7 design specifically for the E82 along with the 17x9 ET52.
-Tom
      04-04-2024, 05:04 PM   #22
Cas29
Cas29's Avatar
Drives: M
The fitments are going to be 18x8.5 ET40 front, and 18x9.5 ET58 rear. This is a familiar combination to many with an offset in-between our ET45 and ET35s for the front wheel. It's slightly less ideal for completely stock cars but offers more room for anyone running aftermarket suspension that reduces inner clearance around the front suspension.[...]
Hey can you elaborate on why these are a less than ideal fitment for stock height? I'm pretty clueless when it comes to wheel offset and I wanna put a set of these on my e88. At the moment I'm on stock ride height, and I only plan on going with H&R Sport springs... any information will help.
Thanks!!!
