      08-13-2014, 10:18 AM   #1
..'s Avatar
Rear Seat Delete
Any DIYs?
Have not found much information on removing the rear seats.
Would like to have a roll bar as a replacement.
Thanks,
Durim
08' Sparkling Graphite Metallic E82 135i. 6spd Manual.
      08-13-2014, 12:04 PM   #2
JeffyD
Destroy All Monsters
JeffyD's Avatar
Drives: '02 EB M Coupe, '11 M Coupe
Guide? Haven't looked. I can tell you that popping out the trim around the seats isn't too hard with a plastic trim tool or dulled putty applier, there are no especially hidden fastening screws or bolts to find, and shouldn't be too hard to figure out a process once the trim and rear cardboard compartment lid is ganked.
      08-13-2014, 02:22 PM   #3
cheshirecat79
cheshirecat79's Avatar
Drives: 370z & 135i
It's been done quite a bit. Remove the trim, use a socket to remove the seats- they just bolt in. Some people have then fabricated wood boxes to make it a little more finished looking.
Poke around the seats and you'll see. It's very straightforward.
      08-13-2014, 08:51 PM   #4
MuNkY6913
The Crowing
MuNkY6913's Avatar
Drives: BMW 135i
2009 135i  [8.00]
Bottom seat cushion you pull up. Side parts where the seat belts are pull off. Seat backs unbolt. Done.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback
      08-22-2014, 12:04 PM   #5
..'s Avatar
Is it any different for those with the folding seats that are from the cold weather package?
      08-22-2014, 12:07 PM   #6
Fifty3bags
Drives: 2010 135i
I think the cold weather package only adds the pass-through with ski bag on the upper part of the rear seats so removing the rear bottom should be the same
      08-22-2014, 02:02 PM   #7
MuNkY6913
The Crowing
MuNkY6913's Avatar
Drives: BMW 135i
2009 135i  [8.00]
Should be the same. With the cold weather package I think it's a door built into the seat so it comes out with it. Not sure though. I don't have that option.
      08-22-2014, 09:49 PM   #8
Eyeman
Eyeman's Avatar
121
I don't think you actually have to unbolt the bracket to remove the rear seat backs. I did, but others have reported that you can knock the hinge out of the bracket. Good luck.
      08-22-2014, 09:54 PM   #9
..'s Avatar
Did you do a custom rear seat delete? Or just removed them and left it that way?
I'm sure there's not much weight savings. 40lbs at most?
