      02-19-2024, 08:34 AM   #1
iXguy
Drives: M240iX, 128i Msport
1 Xenon headlight out
I replaced the angel eye lights with a LED replacement which is a perfect color match for the xeons. (super cool look btw) As advertised, no code... for a while. Then it started throwing a lighting warning on the dash. As everything was working, I ignored it.
Fast forward a few months and now the driver's xeon light is down. Swapped bulbs, the problem does not move. All wiring is pristine and intact. Puts a new headlamp warning on the dash now.
I read that after 50 warnings for lighting the FRM might do this as a safeguard of some sort and that it can be reset or disabled but frankly I can't completely follow the instructions or the logic with the tools I have at hand.
It's a Canadian 2011 128i m-package. I have bimmercode, bimmerlink and carly if that helps, but that's it. And I don't read german. :-)
Thanks guys!
      02-21-2024, 06:57 PM   #2
iXguy
Bump in hopes that new eyes will have an idea...
It's actually my daughter's car and she's running around with one headlight making me feel like a bad dad...
      02-25-2024, 06:16 PM   #3
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2008 BMW 135i  [9.50]
2006 330i  [6.75]
Could it be that the new bulb may be defective? Did you double check the replacement matches the one you have?
Have you tried to swap out for the one on the other side to see if works?
      02-26-2024, 09:24 AM   #4
iXguy
Yes, sorry if my original post wasn't clear but I did swap sides for the headlamp bulbs, and both bulbs are fine as the problem did not move. The wiring all looks perfect and clean but I did not test it as I'm not sure what voltages are involved in the xeon system.
These are most likely the OEM headlamp bulbs originally supplied with the car. It was the Angel Eye bulbs I switched out for LED, they are still working fine. I'm trying to figure out why the drivers's side headlamp no longer works.
      02-26-2024, 09:28 AM   #5
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2006 330i  [6.75]
I woukd check for codes and fuses next.
      02-28-2024, 06:44 AM   #6
iXguy
All other lighting is working, I can't select a fuse that would only impact the driver's side high/low beam light and nothing else. There are no codes according to ODBII.
GoRomeo963.50
      02-28-2024, 08:06 AM   #7
jdt10768
jdt10768's Avatar
332
Drives: 2013 128i MSport 6MT
and when you swap the angel eye back in to driver's side headlight, it works ??
      03-05-2024, 01:17 PM   #8
iXguy
The angel eyes are both fine, those are the aftermarket LEDs. It's the high/low beam that's not working on the driver's side, if I swap the bulbs the problem doesn't move so both (factory) bulbs are good.
      03-05-2024, 02:34 PM   #9
mkeiser
Drives: e82 128i 6mt m sport
do some more research on resetting the short circuit counter in the FRM. if you don't understand how to do it, you'll have to pay someone who does. or just bite the bullet and replace the FRM.
2011 BMW 128i 6MT M Sport - Alpine White on Terracotta w/ Glacier-Silver trim - Koni Yellows w/ H&R Sport Springs, M3 Control Arms, Euro Intake, BMW Performance Exhaust, 3.73 Diff w/ RacingDiffs LSD Conversion, Black Line Taillights, M Performance Grilles, lots-o-maintenance
      03-06-2024, 08:30 AM   #10
iXguy
I don't have the software I see referenced in those documents or even a windows machine to put it on. I have bimmercode, bimmerlink and carly, that's it.
Does anyone know who can do this in the Ottawa, Ontario region by any chance? Dealer wants $1200 and I think buying a used one in this case is pretty risky... and really unnecessary if it just needs a reset.
      03-10-2024, 10:15 AM   #11
Olgeezer1
Had a guy in Ottawa help me with some coding a couple of years ago. You could send him a text to see if he's still doing that. His name is Najib , text: 613-869-8721 .
angel eye, frm, lights, xenon
