      11-17-2009, 03:15 PM   #1
anthony @ eas
anthony @ eas's Avatar
Drives: R56 Cooper S
▀▄ eas | Macht Schnell 3" ThermalCoated N54 Catless Track Downpipes
Applications which require a significant surface temperature reduction as a result of high temperature heat soak will benefit from ThermalCoating. Designed to operate in temperatures up to 2100° F, and meet 3000+ hours of a standard ASTM B 117 salt spray testing, this process will protect the substrate from thermal fatigue and oxidation as well as oxidation scaling while reducing skin temperatures by as much as 54%. ThermalCoating meets U.S. military specification MIL-C-81751B for metallic-ceramic coatings, including FAA approval.
With a maximum output of 306 hp from 2,979 cc the 135/335’s N54 powerplant ensures exceptional driving dynamics at all times with all the power of a much larger normal-aspiration engine. Twin turbochargers each forcing compressed air into three cylinders ensure a standard of spontaneity never seen before in a turbocharged power unit. The big advantage of these relatively small turbochargers is their low inertia, avoiding excessive “turbo gap” – the moment which usually passes by until the turbocharger builds up its boost – typical of a conventional turbocharged engine. On the road, therefore, the turbocharged power unit of N54 variant offers all the power and performance of a much larger normally-aspirated engine.
Stock downpipes cause a major restriction in exhaust flow coupled with their small 57mm (2.25″) pipe diameter and numerous crush-bends with factory pre-cats squeezed in engine compartment. This results in excessive backpressure and excessive heat, which ultimately affects overall performance at all RPM loads.
Macht Schnell’s 76.2mm (3.00″) N54 Catless Track Downpipes allow instantaneous turbo spooling and ultra-low backpressure proving significant hp/tq gains that can be felt immediately after installation.
Mandrel-bent T304 Stainless Steel tubing is used to ensure constant exhaust flow is achieved by eliminating any restrictions, resulting in maximum gains and noticeable sound during turbo spooling. TIG-welded construction and Stainless Steel V-Band/catback flanges are durable as well as pleasing to the eyes. Heavy Duty exhaust gaskets and Stainless locking fasteners complete the package.
Stainless O2 sensor bung locations are mounted in the factory locations while introducing additional stainless steel thermocouple bungs for those monitoring EGTs.
Downpipe Features:
- 76.2mm overall diameter, eliminating restrictive factory pre-cats and crush bends
- ThermalCoating reduces surface temperatures by as much as 54%
- Meets U.S. military specification MIL-C-81751B for metallic-ceramic coatings, including FAA approval
- 100% T304 Stainless Steel construction, using mandrel bends
- Precision TIG welded joints
- Heavy-Duty Stainless V-Band/Exhaust flanges
- Heavy-Duty locking fasteners and exhaust gaskets included
- Factory O2 locations retained with Stainless Steel bungs
- Pre-installed Stainless EGT bungs for easy thermocouple mounting
- Reduced underhood temperatures
Models Supported:
2007+ 335i (not for xi models)
2008+ 135i
Dyno of Macht Schnell 3" catless downpipes vs popular 2.5" catless downpipes
Product Photos
Macht Schnell - 76.2mm (3.00") ThermalCoated Catless Track Downpipes for N54 Variants
http://www.europeanautosource.com/pr...oducts_id=2419
      11-19-2009, 12:02 PM   #2
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Overnight orders are being packaged up as we speak - more in stock.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      11-19-2009, 12:17 PM   #3
escobar929
escobar929's Avatar
154
Drives: M2 CS
2020 M2 CS  [10.00]
2020 M240i  [0.00]
wow, now those are nice
      11-19-2009, 01:25 PM   #4
SlicktopTTZ
SlicktopTTZ's Avatar
Drives: 91 300ZX Twin-Turbo, 2010 135i
Correct me if I am wrong, but isn't it better to have more heat at the manifold/turbine and less heat after? (downpipe and back) It seems to me that the thermal coating on the downpipes would hold heat in the pipe and cause a smaller temperature difference before and after the turbine causing a slight decrease in efficiency. Or is this just to prevent oxidation/rust?
      11-19-2009, 01:56 PM   #5
BroDoze
Drives: Stuff
Hot air molecules move faster = less backpressure. That's why going too big on exhaust diameter can lead to power loss. Too big = cooler air = air moves slower = power loss. Moving air out of the exhaust at the highest speed possible is key. On my old STi, I wrapped my DP, and then ended up buying one coated. Heat is a good thing in the exhaust.
      11-19-2009, 09:59 PM   #6
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Here's our 135i running straight 91/methanol w/ Macht Schnell 3" DownPipes and still running the OEM catback exhaust:
Here is a list of modifications to the vehicle for this run:
2008 BMW 135i 06/08 build
GIAC Stg. 2 beta calibration
Macht Schnell 3” Catless Downpipes
Macht Schnell Dual Cone intake kit
Macht Schnell Intake Scoops
Snow Performance S2 Boost Cooler
Evolution Racewerks Competition Intercooler
Forge Motorsport Adjustable Diverter Valves for N54 Turbo
      12-17-2009, 01:31 PM   #7
anthony @ eas
Just got some more sets of the coated downpipes in stock
      01-06-2010, 01:44 PM   #8
anthony @ eas
All PMs replied. We have a few more in stock ready to ship.
