      01-24-2011, 06:45 PM   #1
WheelSTO
Drives: BMW
✚WHEELSTO | WORK Wheel S1 R & M1 R Meister - Semi-Forged, Lightweight & Aggressive!
Bimmerpost,
We here at WheelSTO are proud to announce the release of the new WORK Wheels Meister S1-R & M1-R for BMW 5x120 PCD. You might be familiar with the original, cult classic Work Meister S1. The original S1's were spun cast barrel with a cast face available in riveted 3 piece or the 2 piece construction.
WORK Wheels have decided to cut the weight down and make the Meister into a competitive 2 piece track wheel.
The new WORK Meister S1 R/M1 R was born.
WORK Meister R series uses a two piece construction wheel. They have modernized the center disk to a more updated look while saving as much weight as possible without sacrificing the wheel strength while utilizing their patented low pressure cast center disk with a spun forged step rim barrel.
Sizing:
18" Sizing only at the moment
Sizing ranging from 18 x 8.5 ~ 11.5 wide. Offset increments in (1mm) for a precise specification
Construction:
Low pressure cast center disk with a spun Forged step rim barrel.
Disk Type:
(A) Disk for standard, larger factory calipers.
(R) Disk for Big brake clearance.
(O) Disk for Maximum lip, less brake clearance or smaller brakes.
Weights:
18 x 9 ~ approximately 22 lbs
18 x 10 ~ approximately 23 lbs
Colors/Finish available:
Matte Bronze Anodized Barrel - S1R
Feinheit Silver II - S1R
Matte Black (MBL) - S1R
Bright Buff Finish (BBF) - S1R
Matte Bronze Anodized Barrel - M1R
Feinheit Silver II - M1R
Matte Black (MBL) - M1R
Platinum Gold (PG) - M1R
How to Order or Get More Information:
Call: 312.880.7767
Email: info@wheelsto.com
PM the WheelSTO Crew:
Julius ● Julius@WSTO
Dave ● Dave@WSTO
WheelSTO Wheel & Tire Package Program
WSTO also offers wheel and tire packages. Please Let us know what your favorite tire is, when asking for price quotes . If you are not sure, just let us know and we can make some suggestions for your intended use! WheelSTO uses a Hunter Road Force balancer to ensure your setup is perfectly balanced. Each order includes a printout showing the accuracy. Ask Your WheelSTO Rep about our FREE Mount and Balance Program Today!
- Wide selection of Tires: Yokohama / Michelin / Nitto / Toyo / Pirelli / Vredestein & more
- Mounted and balance with TPMS
- "Ready to Go"
      01-26-2011, 02:23 PM   #2
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
Hello,
The 18 x 9 (O) Disk +69 ~ -11
The 18 x 9.5 (O) Disk +75 ~ -17
The 18 x 10 (O) Disk +84 ~ -24
Originally Posted by maxnix View Post
So one can achieve a +60mm offset for the rear wheels?
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
      01-26-2011, 07:17 PM   #3
competition
competition's Avatar
Drives: '21 F87 M2C
NICE! I can't wait to see a set of Meister S13P on a 1er!
      01-27-2011, 12:49 PM   #4
driftdriven
Drives: BMW 135i
^ +1
I want Matte Black (MBL) - S1R but are they coming out in 19" anytime soon?
      01-27-2011, 06:58 PM   #5
WheelSTO
Drives: BMW
I am sorry, but those numbers make no sense to me.
How about R disc final offsets?
You can order them in any offset increment up to (1mm) in those ranges I have listed above, and FYI you can run most Work Wheels 2 or 3 piece with an (O) Disk for OEM M3 E9X brakes, so any E82 should clear without any problems.
If you plan on running a "HUGE" BBK, let me know and I can check the clearances for you.
Yessir!
Originally Posted by driftdriven View Post
^ +1
19's are planned, but no official news yet.
