      08-08-2013, 11:52 AM   #1
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
|VRSF| BMW Wheel Spacer Kits W/Extended Bolts - Highest Quality & Best Price!
VRSF Wheel Spacers for your BMW
VRSF BMW Wheel Spacers move your wheels and tires outwards so they are more flush with the fender––instantly giving your vehicle the perfect stance! With our wheel spacers you can fill the gap in your fenders and GO WIDE! VRSF Wheel Spacers feature a "perfect fit" hubcentric design that makes the spacer function as a precise extension of the axle hub, thereby guaranteeing precision wheel fitment.
The VRSF BMW Wheel Spacers are manufacturered from a super lightweight aluminum/magnesium alloy for excellent strength and also to save unsprung weight. The spacers are drilled for additional lightness and easy fitment. They are then hard anodized for durability. These are not universal spacers - the bolt pattern, hub sizing, and other dimensions are designed to be used on BMW models only. This spacer slips on the existing hub lip and leaves some lip left over for the wheel to rest on. This keeps the wheel hubcentric*.
VRSF Wheel Spacer Kit Features:
  • Improve Handling by Reducing Body Roll with Wider Wheel Base
  • Available in 10mm, 12mm, 15mm, 18mm & 20mm
  • Pry Tabs Allows Quick & Easy Installation & Removal
  • Specifically designed for BMW vehicles
  • Flat Black Anodized Finish for Additional Strength and Corrosion Resistance
  • CNC Machined from 6061-T6 Aluminum
  • 1 Piece Construction with Hubcentric Factory Lip
  • Includes Black Zinc Plated Corrosion-resistant Wheel Bolts
  • VRSF Lifetime Guarantee
Each Wheel Spacer kit Contents:
  • 2x Performance Wheel Spacers
  • 10x Extended length zinc plated coated wheel bolts
Fits the Following Models:
  • 2007 - 2013 1-Series (E81, E82, E87, E88, 1M, F20)
  • 2012 - 2013 3-Series (F30, F31*)
  • 2006 - 2013 3-Series (E90, E91, E92)
  • 1992 - 2006 3-Series (E36, E46)
  • 1988 - 2013 5-Series (E34, E60, E61, F10)
  • 2003 - 2013 6-Series (E63, E64, F12, F13)
  • 1987 - 2013 7-Series (E32, E38, F01, F02)
  • 2003 - 2013 Z4 (E85, E89, Z4M)
  • 1996 - 2002 Z3 (E36, Z3M)
  • 2000 - 2003 Z8 (E52)
  • 2010 - 2013 X1 (E84)
      08-09-2013, 02:52 PM   #2
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Top!
      08-09-2013, 03:39 PM   #3
john_w_lewis
Drives: 2008 E82 135i
Any before and after pics with these installed? Any concerns for safety?
John Lewis
2008 BMW 135i | Sedona Red | 6MT
      08-09-2013, 03:41 PM   #4
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
These are essentially the same dimensions as the other popular spacers used, I can PM you a comparable thread with some pictures if you'd like. No safety concerns when using extended wheel bolts
      08-11-2013, 07:38 AM   #5
john_w_lewis
Yes, please do. Also, can you send me pricing?
Thank you!
John Lewis
      08-13-2013, 12:58 PM   #6
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Top!
      08-14-2013, 12:33 PM   #7
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Top!
      08-15-2013, 03:07 PM   #8
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Top!
      08-19-2013, 08:04 PM   #9
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Top!
      08-20-2013, 02:19 PM   #10
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Top!
      08-21-2013, 12:17 PM   #11
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Top!
      08-25-2013, 07:05 PM   #12
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Top!
      08-26-2013, 01:52 PM   #13
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Top!
      08-28-2013, 03:13 PM   #14
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Top!
      08-29-2013, 11:53 AM   #15
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Top!
      09-02-2013, 04:32 PM   #16
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Top!
      09-03-2013, 03:20 PM   #17
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Top
      09-04-2013, 01:29 PM   #18
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Top!
      09-05-2013, 03:47 PM   #19
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Top!
      09-08-2013, 06:22 PM   #20
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Top!
      09-10-2013, 02:48 PM   #21
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Top!
      09-13-2013, 10:50 AM   #22
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Top!
