      11-26-2017, 12:08 AM   #1
OzJustin
Drives: 2008 135i AT Monaco Blue
2008 BMW 135i  [8.66]
Recommended batteries
Hi all,
Seeking recommendations for a good AGM battery available in Australia.
What model are you using and how much was it?
I'm aware that coding is required.
Thanks
Justin
      11-26-2017, 03:55 AM   #2
JBT2
JBT2's Avatar
Drives: 2015 435i
Seeing that the original Varta on my car lasted 8+ years, I bought one from BMW. Exactly correct fit and cost $299 a year ago. Fitted it myself and had an indy code it.
      11-26-2017, 04:07 AM   #3
OzJustin
Do you know what model Varta is required?
      11-26-2017, 08:59 PM   #4
Superdaws
Drives: 2020 F87 BSM M2C
I recently replaced my OEM varta agm with a larger capacity (90ah) exide AGM. Was roughly $320. Exides are made in the Philippines, varta and Bosch are German made I believe, but were less than half the price of the similar capacity German produced batteries. Similar warranty.
2020 MY21 BMW M2 Competition 6MT | Black Sapphire
OLD 2010 BMW 135i M Sport 6MT | Le Mans Blue
2016 BMW F15 X5 30D | Sapphire Black | Black Leather
      11-26-2017, 09:16 PM   #5
chappy
chappy's Avatar
Drives: 335 M-SPORT COUPE
Just replaced mine OEM (95AH) AGM after 7 years with VARTA 90AH AGM they are $520 compared with the OEM $895
THE BEAST MHD Flash Tune /M3 suspension/Forge Intercooler/Alpina B3 AT Flash/Bilstein B4 Suspension/BMW OEM M3 Steering Wheel and DCT Paddles/LUX V4 Angel Eyes/CIC Retrofitted
      11-27-2017, 12:57 AM   #6
Aus335iguy
Aus335iguy's Avatar
Drives: 2009 e92 335i MSport DCT
2009 BMW 335i  [10.00]
Originally Posted by chappy View Post
Just replaced mine OEM (90AH) AGM after 7 years with VARTA 90AH AGM they are $520 compared with the OEM $895
They can be had a lot cheaper than that ! I can have one delivered to my door for less than 300 Aus Dollars.
When you doppelkaplung you doppel your fun.
      11-27-2017, 01:52 AM   #7
OzJustin
Originally Posted by Superdaws View Post
I recently replaced my OEM varta agm with a larger capacity (90ah) exide AGM. Was roughly $220. Exides are made in the Philippines, varta and Bosch are German made I believe, but were less than half the price of the similar capacity German produced batteries. Similar warranty.
Can you tell me what model Exide battery you're using and where you got it? OEM size and fitment I gather?
For everyone else - What model Varta are you running and where did you source?
      11-27-2017, 05:34 AM   #8
chappy
chappy's Avatar
VARTA G14 595901085
All the ones I have seen online are around the $500plus this battery is huge
Battery World was close to me.
I can't see how you can get this battery for $300.
      11-27-2017, 05:41 AM   #9
Aus335iguy
Aus335iguy's Avatar
VARTA G14 595901085
Yeah You're right i was wrong. The ones that i found aren't the AGM ones.
      11-27-2017, 06:17 AM   #10
Superdaws
Its an Exide Evolution AGM.
http://www.exidebatteries.com.au/bat...ion/SSAGM-95EU
Its the biggest aH from Exide that will fit in a 135i, very simple to fit (just remember negative first off last on), just make sure it gets coded if its a different aH rating (80-89,90-99 etc), and if its not a diff ah then it still needs to be registered. Had an 80aH Varta BMW one in it before.
I got it from Independant Battery in Melbourne, i realised i made a typo before and have now corrected it, but im pretty sure it was low $300s.
      11-27-2017, 08:14 PM   #11
RadiuM
RadiuM's Avatar
Drives: 135i, 97 GTR VSpec
I have a Supercharge battery in mine, same specs as to what the standard battery was and it was ~$180 plus coding by BMW. I do less than 5000km a year and its been in there for 4 years now with no issues.
'09 BMW 135i, Lemans Blue
'97 Nissan Skyline R33 Series II GTR V-Spec
      11-28-2017, 05:51 AM   #12
juld0zer
Just make sure you fit the correct type of battery.
AGM (black casing BMW) for AGM
or for enhanced FLA (white casing BMW) you can install either enhanced FLA or AGM. As Superdaws stated, any change in capacity or battery type will require coding.
BMW batteries have a longer warranty. 3yrs if factory fitted, ie same duration as the car warranty. 2 years if fitted by a dealer.
Not many battery manufacturers will give a long warranty for AGMs as they assume most will be used in stop/start equipped vehicles.
Currently, for genuine batteries the 90Ah AGM is best bang for buck if you dont mind carrying the extra weight. This is because the 90Ah is the most commonly installed size.
      11-28-2017, 06:22 AM   #13
OzJustin
Thanks for the recommendations guys. It sounds like the Exide Evolution ($350ish) may be the best value AGM battery unless anyone has another recommendation.
      11-28-2017, 05:47 PM   #14
rac
rac's Avatar
27
Drives: 2008 135i 6MT
I got my varta from battery world for about $300 but it was the next size down from what you are looking for, my 135 only came with the 70ah and it also lasted 10yrs.
      11-29-2017, 01:28 AM   #15
Superdaws
Was it a Varta AGM though? For that price I'd guess it was not, else good deal.
      11-29-2017, 07:19 AM   #16
rac
rac's Avatar
27
No your right it isn't the AGM.
John_01232.00
      12-07-2017, 05:57 AM   #17
JBT2
JBT2's Avatar
Drives: 2015 435i
The one supplied by Westside BMW was Exide. I queried them about the original being Varta. They said the Exide with the BMW part # was the genuine spare part here in Australia.
Anyway it was identical to the Varta and seems to be fine. At $299, I'm not complaining.
      12-28-2017, 05:11 PM   #18
glendo
Drives: 09 135i Coupe
is coding the battery possible by using the BMW Carly App?
      12-31-2017, 04:33 PM   #19
OzJustin
I've read that it has this capability if you have the Pro version and the battery option unlocked. Anyone in Brisbane able to assist with coding?
      03-23-2018, 09:13 PM   #20
glendo
UPDATE:
For the DIY people,
Just bought a Varta G14 at Battery world to replace my dying battery. Cost $540, bought the Carly Battery extension for $16. Swapped and registered the Battery myself, no problems seen whatsoever.
      11-13-2020, 03:30 PM   #21
shumphr1
Drives: BMW 520D SE Auto 2012
re:G14
Hi Glendo,
re: your fitting of the G14, you registered the battery but did you have to recode the ECU? I am told this is also necessary if you change the battery spec and I am looking for a tool or software and cable to do this. Wondering if you have any advice?
many thanks,
Stuart
battery agm
