      06-18-2014, 08:43 AM   #1
135Pats
135Pats's Avatar
Drives: A few BMWs
Strut Bar (E88 Specific)
Well I guess it's not really specific to the 'vert, more just a question and sanity check.
I'm about to pull the trigger on a proper strut bar for the 1er. Am I correct in my assumption that it will be of particular value on the inherently less rigid chassis of the soft top?
The M3 FSB has helped to settle and stiffen the front end but I still feel that it dives and rolls too much on turn in.
Have at it.
F30 N55 XDrive EBII
      06-18-2014, 10:57 AM   #2
Rob Daman
Drives: 2007 E90 335i
I'm not sure if the brace made any difference when I installed mine but it looks good though.
      06-18-2014, 11:41 AM   #3
135Pats
135Pats's Avatar
Drives: A few BMWs
I'd be lying if I said that wasn't a factor in my desire to purchase one
F30 N55 XDrive EBII
      06-18-2014, 11:50 AM   #4
3002 tii
3002 tii's Avatar
2285
Drives: Z4 M, X5, GX460
Theoretically yes, it'll add more rigidity but keep in mind some strut bars are cr@p, ie hinge designs.
Follow for latest mods
      06-18-2014, 11:54 AM   #5
135Pats
135Pats's Avatar
Drives: A few BMWs
Yea. I'm leaning towards the AA version - though it's not like we have many options. The Dinan one is so sexy...At the same time the thought of paying $350-500 for a bar of metal is off putting. It is what it is I guess.
F30 N55 XDrive EBII
      06-18-2014, 12:03 PM   #6
135ivert
Drives: E88 135i,E70 X5M,E93 M3
Given your mods list, I would think that you'd at least try it out. If you didn't like it you could probably resell for 80% or so.
I like the AA one as well. It's pretty far down on my mods list ATM but I'll still get one eventually.
      06-18-2014, 12:30 PM   #7
3002 tii
3002 tii's Avatar
2285
Few of us put on the 1M bar, got it for $206 shipped.
      06-18-2014, 12:35 PM   #8
chris82
chris82's Avatar
Drives: 128i
2009 BMW 128i  [9.80]
I had the AA one, gorgeous piece if you ask me, but I couldn't feel anything with mine as far as an increase in rigidity. And it won't help with dive or roll either. But yea, they look pretty sweet
      06-18-2014, 01:03 PM   #9
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
Check out the Mason Engineering bar.
      06-18-2014, 01:16 PM   #10
Rob Daman
AA is a beefy one indeed. I decided to go with CF bling bmw performance one though.
      06-18-2014, 01:17 PM   #11
135Pats
135Pats's Avatar
Drives: A few BMWs
Whoa. Now that is a serious strut brace.
The E88 is strictly street driven so I wonder if that's overkill. I'm trying to strike a fairly impossible balance here - a reasonably quiet and non shuddering convertible that is stiff and responsive up front.
Those are largely contrasting goals I realize but we can dream right?
F30 N55 XDrive EBII
      06-18-2014, 01:46 PM   #12
TheSt|G
TheSt|G's Avatar
Yup, Mason has a long history of making serious/functional bars. They have another version with shorter firewall braces to allow top mount adjustment access.
Generally braces reduce chassis noise.
      06-18-2014, 01:52 PM   #13
135Pats
135Pats's Avatar
Drives: A few BMWs
Interesting I would have figured that adding a hard link between the strut towers would increase NVH and the general crashing ride of the verts.
Hm. You may have sold me sir. I appreciate your good advice per usual.
F30 N55 XDrive EBII
      06-18-2014, 02:20 PM   #14
TheSt|G
TheSt|G's Avatar
My experience has generally been that with less body flex, one dials out a lot of panel noise(of which the 1er has a lot). Shock tower noise seems to be mostly determined by bushings and springs/strut choice. Happy to chat as always as we usually see eye to eye on most things.
On a related aside, one of the most kickass things about E36 coupe/sedan ownership was the existence of the 'vert. Thanks to said soft top, E36 owners got the "X-brace", which was a structural cross brace installed standard on 'verts to keep them from flopping about. It seriously beefed up the already relatively stiff coupe/sedan.
      06-18-2014, 02:23 PM   #15
135Pats
135Pats's Avatar
Drives: A few BMWs
Yea the E88 has some extra bracing farther aft in the chassis, it's not as robust as the above picture but I think (hope) that the general structural rigidity has improved since the 36 was being produced. Mmm now i'm just thinking about E36 M3s hahaha.
And yes, the amount of noise that emanates from the various door panels and pillars in the 'vert....whoa. It's like there are a bunch of marbles just hanging out in the door tweeters.
F30 N55 XDrive EBII
      06-18-2014, 02:56 PM   #16
135ivert
So you hit a patch of bad pavement and get (for lack of a better term) aftershocks in the cowl and squeaks in the dash and A-pillar? Right now that's my biggest problem with the E88 and would hope to dial out with the strut tower bar. While the Mason engineering bar looks SERIOUS, I don't think it would provide that much advantage over the AA on a street-driven car.
      06-18-2014, 04:03 PM   #17
135Pats
135Pats's Avatar
Drives: A few BMWs
Yep. It's a rattle machine with the windows up.
F30 N55 XDrive EBII
      06-19-2014, 07:41 AM   #18
TheSt|G
TheSt|G's Avatar
Yeah, the E90 era in general got a pretty big boost in structural rigidity(though the E60 was weirdly less than the E39).
I seriously miss my E36 M3 and E36 M3s in general. Easily the most important car I've owned.
      06-19-2014, 08:25 AM   #19
andrey_gta
andrey_gta's Avatar
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
Can I present you with e88 specific braces (Link for 128i n52):
http://www.realoem.com/bmw/showparts...08&hg=51&fg=80
Se part 3 and 2, they make a V shape thats fits under the airbox / headlight area. Mounts to the Crush arms of the engine bay. I just saw it on an e88 the other day of @pj.rodriguez, its cheap and eurobox compatible.
The left side changes with a different engine, so 135i guys look up your own version.
Part 4 is the front A brace to the side
Part 6 & 7 may not be needed for coupe, but the 335i guys have talked abotu using an M3 version of that part to replace the oem rear A brace in the coupe
      06-19-2014, 08:31 AM   #20
TheSt|G
TheSt|G's Avatar
The plot thickens. Does the E82 have mounting provisions for it?
      06-19-2014, 08:33 AM   #21
3002 tii
3002 tii's Avatar
2285
Interesting, I know both the Z4 roadster & coupes have V-braces running along the back of the car... but damn, $155 for both sides is rough lol.
      06-19-2014, 08:42 AM   #22
TheSt|G
TheSt|G's Avatar
Really? I was thinking that was pretty cheap. E36 version was ~$200.
