      07-08-2012, 01:01 AM   #1
1M Roo
1M Roo's Avatar
Drives: 1M & 640d Gran Coupe M Sport
Looking for help on track brake upgrade!
Got a 2012 1M coupe in AW and done about three track days in it do far, but as usual with a M car the brakes "grumble" then loose bite after 3/5 hot laps. Just wondered if anyone out there has any suggestions from new pads/fluid to a whole new system. Would look at all options a will be doing at least 10 track days a year in it. Cheers.
      07-08-2012, 01:12 AM   #2
bdaddylo
bdaddylo's Avatar
Drives: 2017 F80 M3
If you don't mind swapping your pads out before each track day, then Performance Friction PFC01 pads and Castrol SRF fluid are a great combination.
_______________________
1991 E30 M3/Brilliantrot
2017 F80 M3/AW
      07-08-2012, 11:41 AM   #3
MDORPHN
Drives: AW 1M
Agree, but PFC-08 or -06 would also be fine. Any you could also use less pricey brake fluid, like Ate Blue/Type 200 or Motul RBF.
FWIW, I run Motul fluid and PFC-08 pads
Neil
      07-08-2012, 02:28 PM   #4
bdaddylo
bdaddylo's Avatar
Drives: 2017 F80 M3
With the PFC01s I easily reached the boiling point of the stock brake fluid on a relatively cool day for Houston (mid 80s/29.4C) and since I haven't done a brake cooling duct mod I decided to go with the fluid with the highest wet boiling point even though it's 2-3 times the price of Motul. No issues ever since the switch.
2017 F80 M3/AW
      07-08-2012, 06:29 PM   #5
Jet Mech
Jet Mech's Avatar
66
Drives: 2011 1M Coupe VO
What is the difference between the PFC-01, 08, and 09s? Is one more agressive that the other pad?
2024 X3 M40i
2011 1M Coupe VO (Sold)
2015 MB GLK 250 Blutec Deez (Sold)
2001 S54 M Coupe (Sold)
1998 M3/4 (Sold)
      07-09-2012, 04:00 AM   #6
Advevo
Drives: M2 Competition, E30 M3 DTM
01 are little bit more aggressive but are also harder for you brake discs.
For trackdays 06 or new 08 are more then enough braking power and are far more easy on you're discs. These are endurance pads and they also last a lot longer then the 01.
I tested both pads this weekend on the M3 GT4.
      07-09-2012, 05:56 AM   #7
octainejunkee
octainejunkee's Avatar
Drives: M3 f80 Comp, MPE, stage 1
i cant think of a better range than carbotecs xp brake pads.
if youre prepared to swap them befrore each track day then id go for xp10's
or if you want to run them on the road id go for the xp8's.
ive used carbotecs along with race fluid on m3's and evo's and found them to provide much better feel and performance than pf, ferodo and definately ebc.
they usually can get them to you for next day delivery in my experience.
      07-09-2012, 09:16 AM   #8
atv12
atv12's Avatar
Russian Federation
14
Drives: ///1M Coupe
has anyone tried hawk ht-10 pads?
      07-09-2012, 11:04 AM   #9
LotusBoy
Drives: BSM 1M, N55, KW's DDC
BMW is also selling factory performance pads for the E93 M3. As the brakes of the 1M are the same, these pads fit both cars. Only downside, they cost 919 euros ...
      07-09-2012, 11:36 AM   #10
GaryS
Drives: 2009 135i 6MT
2009 135i  [6.50]
If you change the fluid yourself, Motul RBF600 is a great choice. It should not be used in winter (Motul recommends Motul 5.1), and it probably shouldn't be used more than 6 months.
If you don't change the fluid yourself, Castrol SRF once a year is probably a better choice. It can be used through the winter and lasts at least a year.
      07-09-2012, 02:50 PM   #11
VO 1M
VO 1M's Avatar
Drives: 1M Coupe
then you where ripped off I have them on mine. The front pads you can buy at a dealership in Germany for 369.50 EUR (Front). The ones for the back are cheaper.
I ordered the PFC 08 today
      07-09-2012, 02:56 PM   #12
Advevo
Those are pagid Yellows RS29
      07-09-2012, 05:48 PM   #13
Jet Mech
Jet Mech's Avatar
66
Thanks for the info. I will go with the 08s then.
2024 X3 M40i
1998 M3/4 (Sold)
      07-09-2012, 11:25 PM   #14
VO 1M
VO 1M's Avatar
Drives: 1M Coupe
They are Textar pads what I know. (at least written in the spare parts catalog)
      07-10-2012, 04:48 AM   #15
Advevo
Are you sure? Orginal pads are from Textar. But sport pads were always Pagid but maybe they changed it.
      07-10-2012, 11:45 AM   #16
LotusBoy
For now I've just changed the fluid, after a so-so experience in Spa with brakes fading after 20 minutes. Tomorrow I'll drive on a slower racetrack, will report on how the brakes react ...
      07-10-2012, 12:14 PM   #17
VO 1M
VO 1M's Avatar
Drives: 1M Coupe
I also have in mind that the E46 M3 competition / CSL sport brake pads where from Pagid, but I am told the current ones are form Textar. Could be wrong though! I will check mine when I swap them for the PFC 08 and see if there is something written on it.
      07-11-2012, 10:31 AM   #18
Rotor head
Drives: F10 535
Anyone tried the complete brake kit from Performance Friction for the 1M?
Think it's the complete kit for front and rear.
Any review on that is appreciated.
      07-11-2012, 04:03 PM   #19
HP Autosport
Supreme Allied Commander
Drives: F80 M3
On stock brakes I like the Hawk DTC pads with either Motul 600 or Castrol SRF. PFC01 or 06, 08 should also be great.
      07-11-2012, 10:21 PM   #20
M3 Adjuster
Albania
7906
Sounds like you are braking too much. I have gone through two sets of stock pads on track with little drama.
      07-11-2012, 10:22 PM   #21
M3 Adjuster
Albania
7906
Neil
One could use a lesser fluid, but why would you. ;-).
As Gary S indicated, SRF has the highest wet BP, I believe it is higher than the DRY boiling point for Motul, or at least very close.
It is indeed easily good for a year, in my experience, including tracks like road atlanta and mid Ohio.
SRF ROCKS.
      07-12-2012, 09:14 PM   #22
Mnime
Drives: 2015 Cayman GTS
Cause you drive like an old lady
Just kidding Mark... I couldn't resist.
Current - 2015 Cayman GTS White Borla Exhaust
Prev - AW 1M #43 USA
Meisterschaft, N55 mids, AFE CAI, ER Charge, Wagner IC
