02-22-2024, 04:38 PM | #1 |
Rep 74
Adjustable Collars for Swift Springs Rear?
Hey 1ers, I'm redoing the suspension. After a lot of reading on this forum, for the rear springs I bought:
60mm 9" 700lb swift spring rear. +Thrust sheets However, I can't find any kind of adjustable collar that will work. BC Racing/HR makes collars, but both are unorderable. Will the 9" spring sit well (~1 drop) - or does anyone have a link for reasonably priced 60mm inner diameter adjustable collars? Thank you in advance. Last edited by jsciam; 02-22-2024 at 05:12 PM.. |
02-26-2024, 01:24 PM | #2 |
Rep 74
Anyone here that has bought adjustable rear collars for Swift Springs? I can't find an actual link to buy 60mm ID adjusters that would properly fit, but I'm assuming many people run this setup.
03-20-2024, 09:30 PM | #5 |
Supreme Allied Commander
3886
Rep 54,519
Drives: F80 M3
We carry these TCKR height adjusters:
https://hpautosport.com/product/tc-k...ght-adjusters/ 9" spring will almost require you to max out the adjuster to get to what you are after. Got a set of our NLA HPA height adjusters for sale here: https://www.e90post.com/forums/showthread.php?t=1822819 Last edited by HP Autosport; 03-20-2024 at 09:36 PM.. |
