      03-08-2018, 08:01 AM   #23
T1M
Drives: AW MY12 1M
The front adapter looks kind of strange. Can you picture it off the car? If you were to use only the caliper and retain the stock rotors would the adapter still be necessary?
Just to confirm the rear M4 brake bolt right onto the car without an adapter?
      04-22-2018, 01:16 PM   #24
MDMA 135i
Drives: 135i N54
Rears calipers and m3 rotors are bolt on. Just need 2mm washer to center brake caliper and machine inside brake rotor 1mm lip that look like on the e92 m3 brake rotor.
M4 brake calipers dont work with e92 m3 front brake rotor. You can drill one more hole on the wheel carrier and bolt brake caliper that way withot any adapter.
