      01-14-2018, 10:07 PM   #1
rapter
Drives: 1(M)other f*^#er of a car
Driving with a chattering flywheel
Clutch out and car in neutral ... chatter chatter chatter... clutch in... silence.
Upon take off (launch at 1100 rpm), stutter stutter stutter (moderate vibrations felt in car).
reasonably normal car behaviour while in motion.
Taking off with a higher rpm (1500-1700rpm) generally smooths out the stutter at take off.
What are the implications of driving with a chattering flywheel and early slipping clutch?
Will the clutch disk wear out quicker?
Is there any else that will take abuse or will be damaged if the flywheel goes unfixed?
      01-19-2018, 10:40 PM   #2
rapter
... really nobody?
      01-20-2018, 01:12 AM   #3
abb6027
Drives: 2012 1M
Raptor Iím pretty sure this is normal for the car. I had it on my 130i as it had done 80000 klms. The 1M is starting to do it but only 55000 klms. The dealer said it was a getrag gearbox noise from memory.
      01-20-2018, 04:30 PM   #4
Ewok
Drives: AW 1M
2011 1M  [0.00]
Hmm, I donít have this issue. Are you on stock flywheel / clutch ?
As part of the drivetrain , I wouldnít be taking any chances with a failing flywheel .. best to get it checked !
      01-21-2018, 12:48 PM   #5
rapter
I am currently on an all-stock set up (no tunes or aftermarket mods).
      01-21-2018, 12:48 PM   #6
rapter
Mine is currently at 55k as well and the symptom has just started, like you the dealer will have to check up on this in the spring.
      02-12-2018, 10:08 AM   #7
-cj-
Drives: 2011 AW 1M | 2018 M3 Ultimate
I have this issue as well. Same symptoms. I was going to do the CDV delete to see if it helps. Car has 40k km and I'm pretty easy on the clutch.
      02-17-2018, 05:21 PM   #8
rapter
I really believe the flywheel has been undersized for this car...
      02-18-2018, 02:05 AM   #9
gmx
Drives: VO 1M
Undersized as in diameter or weight? It's apparently lighter than other N54s and unique to the 1M. An early(8 bolt) N54 DMFW might be what you're after?
I can hear a distinct difference with clutch in/out and I'm at 42k km. It isn't loud to bother me nor prompt me to diagnose...
      02-19-2018, 01:46 PM   #10
rapter
Undersized in its max torque specification category, for example the flywheel may be running over 90% its design and is failing because of at-the-limit tolerance.
I would have liked to see something last longer or perhaps designed and installed at 75% leaving a 26% tolerance.
      02-20-2018, 10:46 PM   #11
-cj-
How many people with these issues still have the CDV installed?
      02-23-2018, 06:22 PM   #12
mackeroni
Former Opel GT Pilot
mackeroni's Avatar
Drives: 2011 135i, AW, CR, 6MT
I do not think the CDV has any effect on your problem. I did the CDV delete on my 2011 135i a few years ago. My car never made any bad noises before. The CDV delete was simply an effort to smooth out low gear shifts.
Now, for the last year or so, I notice a soft "ticketa-ticketa-ticketa-ticketa" sound with the clutch engaged in neutral. When I depress the clutch, the sound disappears whether in gear or not. I am inclined to hold the clutch in at stops to quiet this sound, though I realize I may be shortening the life of the clutch throwout bearing.
Also, my clutch occasionally stutters on take off at normal driving speeds. This does not happen at every start and is relatively innocuous though noticeable.
So, that's it. I am doomed. There is no patch, no methadone, no substitute. Curse you BMW. Curse you and your seamless power delivery. Curse the incredible sense of road feel. Curse the comfort, the luxury, the envious looks from the masses. I am... hopelessly addicted.
      02-23-2018, 10:45 PM   #13
M3 Adjuster
M3 Adjuster's Avatar
This is NORMAL
Lone Star BMW CCA Chapter Ex-president (retired 2017) , Chief Driving Instructor - LIFETIME Member # 119366
If you don't STAND for something.. you'll FALL for anything
Past: 1991 BMW E30 M3 street car ; 1988 BMW E30 M3 track car
      02-24-2018, 01:04 PM   #14
mackeroni
mackeroni's Avatar
Originally Posted by M3 Adjuster View Post
This is NORMAL
What causes the 'ticketa-ticketa' sound? The flywheel? Does the sound indicate an upcoming repair or some maintenance that I have missed?
Thanks... Mack
      02-24-2018, 07:10 PM   #15
rapter
This is NORMAL
Your car is shuttering under acceleration is absolutely not normal. Thanks for your contribution
      04-02-2018, 01:53 PM   #16
chris_flies
I enjoy this car too much
chris_flies's Avatar
Drives: Enthusiastically...
2009 BMW 128i  [5.00]
My $.10 into this:
Dual-Mass Flywheels are made of two parts, carefully engineered to reduce harshness and vibrations from the drivetrain. The springs and various mechanicals wear-out over time leading to a clunking sound when shifting and starting-off.
Single-Mass Flywheels are made of only one solid part, and the only maintenance needed is a rare resurfacing when you replace the clutch. A SMFW should permanently fix all DMFW-related issues...
If the DMFW is bad enough, you could definitely feel this slop when driving which would cause something like the stuttering that you experience.
The ticka-tacka sound (for me) was the direct result of installing stiffer transmission mounts, which have a lesser damping effect for vibrations than stock. If I remember correctly, it's the result of some built-in play in the driveline being exaggerated as a result of the increased vibrations.
2009 130i 6-Speed Coupť | Monaco Blue with Black Sensatec | chris_flies' 128i Build
"To disarm the people...was the best and most effectual way to enslave them" -George Mason
-NA Supremacy Propagandist-
