      07-13-2007, 01:44 AM   #23
Devon K
Devon K's Avatar
24
Drives: TBD
Wow - the Tirerack reviews of this runflat model are 90% negative! Admittedly there aren't many reviews online so we may just be seeing comments from the disgruntled few, but it is not looking pretty.
      07-13-2007, 07:38 AM   #24
Lips
Drives:
The tires are not good that is why the reviews are poor. Maybe BMW will offer a different tire package with an upgraded wheel or something...
2005 G35 Coupe Lakeshore Slate
2007 Mazda MX-5 Galaxy Grey
      07-13-2007, 07:48 AM   #25
Wiggum
Future N54 Owner...
Drives:
If RFT's are the only option, I'll be picking up a new set of wheels/tires and have them waiting for the new car, probably CSL's on 615's...
      07-13-2007, 07:53 AM   #26
Lips
Drives:
Not a bad idea although I would hate having to change out wheels and tires after picking up a 35k + car.
      07-13-2007, 09:35 AM   #27
Wiggum
Future N54 Owner...
Drives:
My logic is this...
If I can pull the OEM wheels and tires, use what ever it is that I want to use, when it comes time to get rid of it, I can be CPO because of the RFT's...
Getting a set of Falken's and CSL Reps is probably about the price of 4 RFTS!
      07-13-2007, 09:37 AM   #28
Lips
Drives:
Good point, although the price of RFT's has been coming down quite a bit, but it is still pricey.
      07-13-2007, 10:51 AM   #29
imported_MPower
Zoom Zoom
22
Drives: 2010 VW GTI
Speaking of CSLs... do you know the weight of those wheels?
      07-13-2007, 11:03 AM   #30
Lips
Drives:
E46fanatics has a post about them and they say 24lbs without tires :iono:
      07-13-2007, 11:12 AM   #31
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
My goal with aftermarket wheels is usually not to exceed weight in lbs=diameter+1.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      07-13-2007, 02:22 PM   #32
eMINI
Drives:
That explains why the 14 lb 17" SSR Comps are so nice on the MINI
So replacements for the 135 OE wheel should be no more than 19 lb for an 18" wheel. Got any recommendations?
2010 135i Coupe | Black Sapphire Metallic | Red Leather | Poplar Grey Wood Trim | 6MT | Premium pack | M Sport pack | Heated Seats | HK Premium sound | USB | Smartphone integration | Automatic high beams
      07-13-2007, 03:16 PM   #33
larryn
Drives: '97 332ti, '16 F82 M4
Nothing specific, but I bet those 135's weigh more like 26 lbs (or more) each. BMW makes them beefy so they are more stout on potholes, and are able to have those PITA to mount runflats not damage the seats on the wheels.
      07-13-2007, 04:03 PM   #34
mikeo
Santa Fe Concorso
mikeo's Avatar
... So replacements for the 135 OE wheel should be no more than 19 lb for an 18" wheel. Got any recommendations?
Haven't found anything yet that melts my butter. I'll post here when I do.
      07-13-2007, 07:56 PM   #35
mikeo
Santa Fe Concorso
mikeo's Avatar
These may do...
$299 for 18x9, 17.7lbs, 43 offset, all silver or black w/polished rim. Also avail in 18x10!
      07-13-2007, 08:17 PM   #36
larryn
Those are currently my racing wheels. I have the 16.2lb gunmetal 17x9's on my 332ti. I'd like them more if they didn't need dremeling on teh back to use a spacer and the requirement of those blasted additional hubcentric rings.
They are incredibly light though, especially for the price.
Edit: to add pic. :biggrin:
      07-13-2007, 08:54 PM   #37
335i=:)
Drives: 335i sedan-blk/blk-Poplar
Where did you see these?
Links?
      07-13-2007, 09:08 PM   #38
larryn
You can get them from Turnermotorsport, Vorschlag, or Diffsonline. I got mine from Diffsonline, since they were the closest and cheapest. BTW, they are called DForce LTW5.
      07-14-2007, 08:05 AM   #39
mikeo
Santa Fe Concorso
mikeo's Avatar
The latest versions are BMW hubcentric.
      07-14-2007, 09:04 AM   #40
Lips
Drives:
Those are rims are really nice. What is the lightest most durable rim?
      07-14-2007, 09:52 AM   #41
mikeo
Santa Fe Concorso
mikeo's Avatar
In general it would be a forged manufacturing process wheel instead of cast. TireRack has a good explanation.
      07-14-2007, 12:40 PM   #42
Lips
Drives:
I am aware that forged is lighter than cast, but I am confused as to the durability factor. If the wheel is too light would that make it less durable? If so, what is the threshold?
      07-14-2007, 12:53 PM   #43
mikeo
Santa Fe Concorso
mikeo's Avatar
Yes, and the threshold factor would be beyond my knowledge to discuss.
      07-14-2007, 01:38 PM   #44
larryn
Those wheels are strong, but might not be as durable as the heavier stock wheels. D-Force calls them spun forged since the aluminum is simultaneously spun, heated, and pressed, but the spokes are cast aluminum.
I've used them on both my e90 and my 'ti without any problems and hit some substantial potholes with no ill effect.
I would say that forged would be somewhat stronger, but 2-5 times more expensive too. These wheels are stronger than your average lightweight cast alu wheel though.
