      10-31-2007, 01:52 AM   #1
BlingBling2
Drives:
Question Anyone know what run-flat tire will the 1er be using???
I went up to Tirerack.com and found a bunch of run-flats any guess on which ones will come with the car? And if you were to get new rims and tires are you stuck with getting towed if you get a flat?
[SIGPIC][/SIGPIC]I am the ONE to Bling!
      10-31-2007, 02:09 AM   #2
alex2364
alex2364's Avatar
Drives: 2017 M4 ZCP
2017 BMW M4  [0.00]
I'm guessing the same kind as the E90. Just get a fix-a-flat kit.
      10-31-2007, 07:55 AM   #3
atr_hugo
No longer moderate
atr_hugo's Avatar
Drives: '13 135i
Bridgestone RE-050
      10-31-2007, 10:54 AM   #4
TESLAASTRO
DE STIJL
14
Drives:
Send a message via Yahoo to TESLAASTRO
Originally Posted by atr_hugo View Post
Bridgestone RE-050
would you consider these good wet traction tires?
'Maybe Tesla does the Astro'
      10-31-2007, 11:23 AM   #5
bimmerfile
bimmerfile's Avatar
Drives: 2016 M235xi cabrio
The BS RE-050's on my Z4 are fine in the wet. :w00t:
But in the snow - fogedaboudit...:biggrin:
      10-31-2007, 11:40 AM   #6
atr_hugo
No longer moderate
atr_hugo's Avatar
Drives: '13 135i
A separate set of Blizzacks WS-60s on 17" wheels may be the trick. Teslaastro is in FL so he hain't seen snow in awhile (I would suspect).
BTW, the WS-60s were developed because you Cannucks complained about the tread pattern on the WS-50s being squirrely during lane changes in slush ; -).
      10-31-2007, 11:50 AM   #7
larryn
Drives: '97 332ti, '16 F82 M4
My e90 has Bridgestone RE 050A runflats stock. They are decent as daily driver tires in the wet. Heck, I left them on for the past two winters up here in Massachusetts too. I certainly wouldn't recommend that, but I've driven in the snow with them (and they did suck, as expected).
      10-31-2007, 12:50 PM   #8
TESLAASTRO
DE STIJL
14
Drives:
luckily, one of the only redeeming qualities of living in Dante's Inferno is that it's like, well, an inferno - no snow to contend with.....
      10-31-2007, 04:06 PM   #9
bimmerfile
bimmerfile's Avatar
Yah, lucky you..:w00t:
Unfortunately, I won't live long enough to see the benefits of global warming - warm sunny weather and palm trees in Toronto in January..:headbang:
      10-31-2007, 04:16 PM   #10
atr_hugo
No longer moderate
atr_hugo's Avatar
Drives: '13 135i
And sipping a fine Winnipeg Cabernet Sauvignon to boot!! :biggrin:
      11-01-2007, 03:13 AM   #11
BlingBling2
Drives:
This is the review I found for this tire.
http://www.freshalloy.com/site/marke...0a/default.asp
So it turns out to be not bad of a tire other than the fact that you may have to change them once a yr. (Once every 3 months for some of us who love putting solid strips on the streets).
