      04-02-2008, 03:59 PM   #45
larryn
Drives: '97 332ti, '16 F82 M4
Originally Posted by adc View Post
Ah, I usually point mine to the grease marks on the hands, face and hair.
I should've gone for Coral Red, and cheated away... :wink:
      04-02-2008, 04:03 PM   #46
adc
Drives: 2015 F80 M3 ED
Well, it so happens... I do have the Coral Red... just in case...
2015 F80 ED
2004 Z4 3.0
2014 X3 35i
      04-02-2008, 04:42 PM   #47
silverbullet135i
silverbullet135i's Avatar
Drives: AW E90 335i ///M Sport
Send a message via AIM to silverbullet135i Send a message via MSN to silverbullet135i
just tell her your having an affair with your 1er and that she needs to move out because you want to sleep next to your 1er at night...
but then your wife will probly tell you to sleep in the garage.
I agree. Now that the car is dropped a bit and has more negative camber, I want to see how I make out. I'll do the mount this weekend... I've spent so much time under/in/around the car (or on this site), that my wife is checking the terra leather for lipstick marks. :wink:
      04-05-2008, 09:39 AM   #48
larryn
Pics.. finally. I used a 3mm spacer, and no rubbing at all, even with my lowered car. The thing looks like a stock car with this fat rubber on it.
I'll tell you... This thing is going to be tenacious.
      04-05-2008, 09:41 AM   #49
larryn
Front fender from above. It looks like it would slightly rub, but it doesn't.
      04-05-2008, 10:49 AM   #50
adc
Larry, questions from a spacer newbie:
- A 3mm spacer won't have a hubcentric lip - is it held in place just with the bolts? Or is it so thin that some of the hub lip still protrudes? Questions about the solidity...
- This changes the balance of the wheel by sticking it out - will this have any long-term impacts on the wheel bearings? Or is this just a track setup?
The car looks absolutely amazing! This is exactly what I'll do with mine (420 days or so from today ).
2015 F80 ED
2004 Z4 3.0
2014 X3 35i
      04-05-2008, 11:32 AM   #51
larryn
It grabs the hubcentric ring enough that I don't need a hubcentric extender. You're right.. the 3 & 5mm spacers do not have hubcentric extenders on them. Having lost a wheel at an auto on my car in the past due to the wheel not grabbing the hubcentric ring enough... I'm wary, but this seems safe.
This is only my autox/DE setup. Not a fan of it for the street, unless I'm too lazy to swap out for an event. :biggrin:
      04-05-2008, 12:56 PM   #52
scottn2retro
scottn2retro's Avatar
280
Drives:
Hi Larry - sorry for being a little slow (I'm not the brightest bulb on the light string :biggrin: )
Could you summarize your final tire/wheel/offsets/spacers again for f and r?
Front: 255/XXx17 on 17x8.5 et YY / Z spacer
Rear: 255/XXx17 on 17x8.5 et YY / Z spacer
2015 M4 BMW Club Racer
SCTS Racing
https://www.facebook.com/sctsraceteam/
      04-05-2008, 12:58 PM   #53
scottn2retro
280
Drives:
You should be wary - there is a thread on B'forums track section about wheel and spacer combinations. There are spacers with the tapered centers and spacers without.
So depending on if you have wheels with centering rings or not, that would determine which type spacer you should use.
SCTS Racing
      04-05-2008, 01:34 PM   #54
larryn
Front is 255/40/17 Advan Neova AD07 with 3mm H&R spacer on 17x9 LTW5 ET 41
Rear is 255/40/17 Advan Neova AD07 on 17x9 LTW5 ET 41, direct bolt on.
I have the early adopter LTW5's with the centering rings. The spacers are camfered. They fit well, and I'm using the lug bolts from my 5mm spacers, even though the 3mm spacers supposedly do not need different lug bolts. I think the 5mm spacers will work as well.
There's room for a 285 in back probably, if you had the right wheel. The LTW5 would not accommodate that, as it would need about a ET 52 offset in the 17x9 fitment.
Piquing your interest a bit, Scott? I also lost about 10lbs a corner with those meatier wheels/tires. :biggrin:
      04-05-2008, 02:53 PM   #55
SpeedFrq
SpeedFrq's Avatar
Drives:
Larry - that looks awesome!
      04-05-2008, 03:18 PM   #56
Guerillah
Drives: E90 AW
Looks nice! Got any side views?
      04-05-2008, 03:28 PM   #57
larryn
Nope, sorry. I just put those on as a test fit (to drive around this morning) and they'll only be mounted for driving events. I already swapped 'em back to stock. They are so wide that the front kick up dirt on top of the hood.
      04-05-2008, 03:41 PM   #58
PhAzE
Drives: AW 1m (soon)
Nice Larry, I find it funny how there's a cop car across the street when you took those pictures.. Waiting for you so he can bust your ass hahaha
      04-05-2008, 03:56 PM   #59
atr_hugo
No longer moderate
atr_hugo's Avatar
Drives: '13 135i
^ I noticed that too - Larry must have him a nice one of these:
      04-05-2008, 03:57 PM   #60
larryn
The person that lives next to them is also a State Trooper, and my daughter's best friend's mom is also a trooper. Never had to use one of those cards, but I think I could. :wink:
It's better than a house alarm system could ever be, too.
      04-05-2008, 04:03 PM   #61
atr_hugo
No longer moderate
atr_hugo's Avatar
Drives: '13 135i
Same thing then - beats a bunch of benjamins wrapped around policemen's ball tickets. ; -)
      04-05-2008, 06:15 PM   #62
sadu77
sadu77's Avatar
Drives:
that looks sharp.
Titanium Silver
6 speed man
Black Boston Leather
Gray Poplar Trim
Nav system
Comfort access
Power/Heated seats
Sattelite radio
Ipod
Production number 398****
      04-05-2008, 06:17 PM   #63
sadu77
sadu77's Avatar
Drives:
a mass statey too. i went to umass amherst. those staties dont f around
Titanium Silver
6 speed man
Gray Poplar Trim
Nav system
Comfort access
Power/Heated seats
Sattelite radio
Ipod
      04-05-2008, 06:57 PM   #64
WyattHerb
Drives: 2008 BMW 135i
I love the stance of the 135i as it is. Very intimidating. The addition of that wheel/tire combo makes the stance absolutely terrifying!:w00t:
      04-06-2008, 08:31 PM   #65
scottn2retro
280
Drives:
I definitely have a vested interest in going to 255/40x17s on all 4 corners of the car (and good to know 275/40x17s would fit on the back if needed)
:biggrin:
SCTS Racing
      04-06-2008, 09:22 PM   #66
Mturbopower1
Drives:
Those rims are sick, you should leave them forever not just for the track.
