      05-28-2013, 09:04 PM   #243
dorkdog
Big Mouth No Filter
dorkdog's Avatar
Drives: 128i Montego Blue 6MT Sport
Interesting wrench options --- 11mm
From Sears:
Do you think any of these would be better than the Hazlet or is 5 degrees too big?
I'm thinking 12 point is 360/12 or 30 degrees... would 5 degrees be 6 times better?
http://www.sears.com/kd-tools-kdt985...&blockType=G79
http://www.sears.com/gearwrench-8522..._tnt=39869:4:0
We do not inherit the Earth from our parents; we borrow it from our children
      06-10-2013, 05:15 PM   #244
Maybe this video will help those who run into bleeding issues when trying to bleed the clutch system.
      06-10-2013, 09:56 PM   #245
tracer bullet
tracer bullet's Avatar
Drives: '11 135i , '15 X3 35i
I just used my standard open ended 11mm wrench. Used the open side since I had the tube sticking out of it. No fancy turns or curves or anything needed. Just give it a few degrees, flip it, give it a few more degrees, etc. Nothing to it. This is a 2011 135i w/ N55 if that matters at all. I suppose a different wrench would be a little quicker but I'd have maybe saved 30 seconds. Maybe I got lucky? For my application, nothing special was needed whatsoever.
No idea on before / after feel. I got it apart, put the new one in, and then realized that the one I pulled out was already modded. Previous owner did it and either forgot to mention it or I forgot that he did. LOL. That would explain why I didn't know why everyone hated the stock clutch!
About the bleeding, I can't think of any way to do it "right" that guarantees no air in it. To me, doing it right means bleeding it. Even if you put the ends together slowly and allow a little fluid to come out to minimize the air. I think you can definitely get away without bleeding it, you may not have enough air to cause problems or notice it. But I still wouldn't call that the right way to do it.
      07-24-2013, 09:51 PM   #246
dcaron9999
dcaron9999's Avatar
Drives: 2011 135i M package
Thumbs up
Did this mod tonight on my 2011 135i M-sport. Ran into minor issue with pressure bleeding. Only used air initially, as reservoir "looked full". Wound up bleeding fluid, bubbles, and then air in that specific sequence. Clutch pedal went to the floor without any resistance. Undid the bleeder, filled the reservoir up to the rim, put about a cup of fresh fluid in the bleeder, pumped it up to 20 psi, bled again but with short bursts, until no more bubbles appeared in the clear tubing and catch bottle. Pedal firmed up immediately, and I was good to go.
Wow, this is what a fast clutch engagement feals like - never experienced this in a BMW, and I owned 5 of them before my 135i. I also installed clutch stop. Got to get used to the new dynamics. So little pdeal throw is needed now, and so easy to shift smoothly and promptly in gears 1-2-3. Rev matching is also smoother and easier.
As a previous poster mentioned, the standard 11mm wrench and some patience (taking 1/4 turns, and flipping the wrnech) is all you need to crack the bleed valve - no fancy half moon or angled wrench to buy for this task.
Great mod, and I highly recommend it.
      07-25-2013, 12:15 AM   #247
Mach1er
Mach1er's Avatar
88
Drives: '13 128i
I really want to do this, but I've got < 3K miles on the car and if I break it (I'd have it done at an indie) this early somehow I'm going to be really pissed. *torn*
'13 128i | 6MT | SGM | Black Boston | Black Gloss | Lighting | Premium | Tech | HK | Anti-Theft | [CDV-Delete | Clutch Stop | 30% Pinnacle]
Ordered 2.23 | Production Begin 3.7 | Ends 3.15 | Released to carrier 3.18 | At port 3.19 | Departed 3.23 (K-line to Brunswick) | Arrived 4.7 | Truck 4.12 | Dealer 4.19
      07-25-2013, 09:20 PM   #248
dcaron9999
dcaron9999's Avatar
just bought my 2011 135i less than a month ago, and it is still under warranty. With all the great DIY's out there, and especially this one, I felt confident. If you ever tackled a did brake job or brake bleed before, this CDV replacement job is way simpler.
      08-25-2013, 10:39 PM   #249
Naoto
warranty denied.
Japan
13
Drives: 2011 135i
i finally got around to doing this today. great mod and i should have done it sooner!
      09-03-2013, 02:35 PM   #250
granracing
Drives: Mazda Miata
Just picked up a 135i and will be doing this mod. Thanks for writing it up!
Dave Gran
Free Guide to Motorsports AND Car Reviews from an Enthusiast's Perspective
GoAheadTakeTheWheel.com
      09-04-2013, 10:15 PM   #251
larryn
I freaking love that folks are still utilizing this DIY 5.5 years after I wrote it. Too cool.
      09-09-2013, 04:59 AM   #252
Acheron83
Acheron83's Avatar
South Africa
53
Drives: F22 M240i
2018 BMW X3 M40i  [0.00]
2016 BMW M240i  [0.00]
Originally Posted by fe1rx View Post
Of course I realize that. It just looks like a pill and taking it (out) seems to make a lot of people feel better, even though many have no idea what it actually does. What it does is remove a "restriction" and that has to be a good thing, right?
If one were to attempt to learn English as a second language from this forum, one would conclude that the word "performance" when attached to a modification meant "change for the sake of change". That is not a bad thing, because if that were not so this forum would be long cold and there wouldn't be a fraternity tinkering with their cars for the joy of tinkering.
I have to say that I miss the passing of Larryn from this forum. He provided a lot of wisdom and he was motivated by actual performance, tested at the track and at the autoslalom. With respect to this mod though, I suspect it is better only because it is different.
Question: with the CDV installed how fast does one need to release the clutch before the slave cylinder can't track the pedal movement any more?
Arthur1920 is saying "the king has no clothes". He is wrong about hill hold though - greatest thing since sliced bread!
Great thing about this forum - we get to disagree about things.
Of course I will agree that your version of the CDV delete is the best. If I get bored and decide to try it, I will do it your way.
So thousands have done this and have noticed a positive difference, yet you'll debate it without even having tried it yourself.
      10-08-2013, 02:09 PM   #253
mechavore884
mechavore884's Avatar
Drives: the fat mobile
probably a dumb question, but what fluid are you guys using? anything over the counter (like from advance or autozone)
      10-08-2013, 02:47 PM   #254
Ginger_Extract
California-bound
Ginger_Extract's Avatar
Drives: BMW 135i
Actually, both Autozone and WalMart carry this OTC DOT4 brake fluid that comes in a small (.3L) yellow bottle with impressive dry/wet boiling points for about $4. Can't recall the brand off the top of my head, just look for the yellow bottle, make sure it'd DOT4, and you're golden.
Also, for everyone's reference, I made a small write up about my experiences, check it out if you'd like:
http://jakestumphracing.tumblr.com/p...-valve-install
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18
https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3
      10-08-2013, 03:03 PM   #255
mechavore884
ZIIIng thatnk you SIIRR!!! I know exactly what your talking about
      10-08-2013, 03:17 PM   #256
Ginger_Extract
California-bound
Drives: BMW 135i
It just came to me, PRESTONE brand!!! I've been mixing it with Motul RBF600 to make it go further for my buck, track tested, Ginger_Extract approved.
Bimmer TV125.00
      10-08-2013, 03:38 PM   #257
mechavore884
hahah gotchya *i figured it was prestone* Im going to try my hand at the CDV goodness next weekend and get the CDV part for ecstuning then cross my fingers regarding the install and the bleeding haha
      12-30-2013, 08:50 AM   #258
sixburgh
sixburgh's Avatar
Drives: 2010 128i 6 MT BMW PE
Hey Dack,
Did you actually change this out? Sounds like a good, necessary mod.
Let you all know how it goes in a week or two. Its too cold out to be crawling under my car right now! bye
      12-30-2013, 08:58 AM   #259
Originally Posted by sixburgh View Post
Hey Dack,
Yes, I did. I HIGHLY recommend deleting the CDV on a manual transmission.
See page #6 of this thread...
http://www.1addicts.com/forums/showp...&postcount=123
      12-30-2013, 03:19 PM   #260
sixburgh
sixburgh's Avatar
Thanks. It's my next mod on my 6MT.
I appreciate your comments and contributions to the e82.
Happy New to you.
      02-25-2014, 12:35 PM   #261
mgrych
Drives: 08 BMW 135i M-Sport
After the bleeding where do I top it off with fluid?
08 BMW 135i--JB4--DCI--CPE Downpipes--AFE Exhaust--FMIC--ER Charge Pipe W/TiAL BOV--EC-7 Wheels--Rieger Diffuser
      03-04-2014, 11:18 PM   #262
crbalch
The Schwab
crbalch's Avatar
Drives: 2020 AW M340xi
2017 BMW X1  [0.00]
2016 BMW M235xi  [0.00]
Anyone in Chicago that has done this/willing to help me get this done?
Everything seems straight forward except for the bleeding of the clutch...never done that before.
      03-14-2014, 08:40 PM   #263
evbecks
Hero
evbecks's Avatar
86
Drives: 2009 135i M-Sport
Cam, I can walk you through this via text/pm.
Not hard at all!
Evan
@throtl - http://www.throtl.com
Subscribe to our YouTube channel (+880,000 subscribers) http://www.youtube.com/throtl
2019 M2 Competition
      03-17-2014, 07:16 AM   #264
FactorX81
Drives: 2010 135i, 2014 Ford Escape Ti
Question for all those that have done this how smooth is your clutch pedal now? I did this about a week ago and I love the engagement however I feel as if my clutch pedal is not smooth it almost feels like it is rubbing or something I bled the clutch using a motive bleeder but did not have anyone to hold down the pedal. I also noticed the pedal now makes a faint squeaky noise not sure what the deal is.
