FORUMS
- 5
| 04-07-2008, 04:21 AM | #1 |
BMWCCA Driving School?
Has anyone here ever been to one of the BMWCCA driving school events? My local chapter is having one in June and I was thinking about going. I've always wanted to try track racing, but I've been a little scared in the past due to lack of training. This sounds like a good way to learn how to do it right, however I'm concerned about a few things...
1) Is it going to eat up my tires? 2) Do I really need to change the oil and break fluid before and after the event? 3) Is it bad for the car in any other way? (don't plan to do it a lot) 4) Is it worth the roughly $600 it's going to cost me for the 3 day event? Anything else I should consider or be concerned about? Dan |
| 04-07-2008, 04:48 AM | #2 |
![]() ![]() Drives: 135I - white/coral red - sport Join Date: Dec 2007
Hi Dan,
You will love the car on the track. I took mine to the track this past weekend and there is a short write-up in Autocross/Track section. http://www.1addicts.com/forums/showthread.php?t=6752 It is the only way to learn to do it right with your own car. No matter how aggressive you drive on the street you will not approach what you can do on the track in a very controlled environment. Fernley in June? You will really want to keep a close eye on your tire temperature and pressure. RFTs - 200F and 40-42 psi hot.
Alan
08 135I (AW/Coral Red - delivered 3/15/08 -- 13 Audi S4, 83 SC (trackster), 90 C2 (Sally's Carrera), 04 Avalanche Blingmobile ![]() |
| 04-07-2008, 09:24 AM | #3 | |
i would guess the realistic weekend cost is more like $1000. if you drive the car as God intends you to, you'll use up a set of tires in 6-8 track days, same with the brake pads. your average mpg will be 10-12, so figure at least $100 worth of gas. plus, you have to have a pre-event inspection, and i would change the break-in oil before hand. your brake fluid should be fine, since the car is quite new. i think that if you maintain your car well, track driving is not "bad" for a car, but wear and tear is obviously higher than driving around your neighborhood. is it worth it? the first time i went (with bmwcca, natch), i wasn't even sure if it was fun or not-- so much information to process, trying to learn the course plus driving techniques plus watching mirrors, etc. however, once you start putting it together, and lay down a couple of laps that feel good and fast, there is really nothing like it. certainly, track driving is safer than many adventurous activities, such as sky diving, rock climbing, kayaking, hiking, surfing, where people die every year. i think that anyone who enjoys taking an on or offramp a little faster than they are supposed to should do this at least once or twice. take your car stock- learn more that way.:thumbup: |
| 04-07-2008, 10:00 AM | #4 | |||||||
What you have to remember is that YOU are holding the steering wheel, and working the pedals. Anytime you are not comfortable doing something, let the instructor know and he'll take a different approach. And never through caution into the wind, you don't have to prove anything to anybody. Quote:
Is it worth it? Absolutely, unquestionably, resoundingly 100% YES. Quote:
So remember: you are there to learn, you don't care who's faster, you will have unbelievable fun, and you need to go home with the same car and in the same pristine condition as when you went there. :thumbup:
![]() 2009 E90 M3 ED 2012 MINI Countryman S 2000 Boxster |
| 04-07-2008, 12:16 PM | #6 |
Thanks guys. I think I'm going to do it. Provided I can put enough miles on the car before June 27th to get out of the break in period. I wont even have the car for 6-8 weeks so it's going to be tight.
Dan |
| 04-08-2008, 07:02 AM | #8 |
No longer moderate
A lot of instructors have told me that women make better students at these events, they make more progress, and emerge with higher skills, because unlike men - who let their egos interfere with learning - the women pay attention. ; -)
| 04-08-2008, 10:03 AM | #9 |
On the other hand, they end up being slower after awhile, because of the constant need to stop and ask for directions. :wink:
| 04-08-2008, 10:38 AM | #10 |
lol ADC!!
One more thing to add... pay attention to other cars around you. You'll only be able to pass in a few places, and your instructor will help you there. Also, just because there's a Ferrari out there.. it doesn't mean you need to pass it as your goal for the day. The people in your run group will be of similar driving level as you. As for what you're driving, it doesn't matter, as long as you're learning. :smile: |
| 04-08-2008, 03:12 PM | #11 | |
Private No Class
You will have an absolute blast and you will walk away a much better driver (and you will probably be hooked for life!). And like ADC said...listen to your instructor and ask questions. It's the best way to learn (plus it shows the instructor you're not holding your breath the entire way around the track!!).
They followed me home...can I keep them?
![]() Dan in Houston / CCA # 93849 |
| 04-08-2008, 09:53 PM | #13 |
Santa Fe Concorso
Drives: '09 335d, '13 X1 sDrive28i Join Date: Jul 2007
I'm of the school that firmly believes driving school novices should start on street tires, properly inflated. You will learn better car control, more safely, by going with street tires instead of r-compound tires. If you like the results of the first weekend and expect to repeat the DE experience several times in the next year you might consider a set of extreme performance street tires mounted on an extra set of wheels.
| 04-09-2008, 05:01 AM | #14 | |
Alan
| 04-09-2008, 07:39 AM | #15 | |
| 04-09-2008, 09:23 AM | #16 | |
Private No Class
| 04-09-2008, 10:10 AM | #17 |
![]() Drives: '96 Maxima SE 5MT, '04 MB E500 Join Date: Jan 2008
Excellent posts R32 & ADC...
To the OP, you may want to check out NASA's HPDE/Open Track calendar for events happening near you. They put together some really great events that are safe, educational, and more fun than a barrel of monkeys. Afterwards, you'll drive back home a better driver with newfound skills, and a lot less urges to try risky/illegal things on the streets. You'll drive safer on the street and have a better appreciation of the skills you've learned, not to mention knowing your car's handling capabilities in a more intimate way. Check out this link about HPDE to get more info... http://www.nasaproracing.com/hpde/index.html |
| 04-09-2008, 02:37 PM | #18 |
Instructor Session
At our recent high performance driving clinic on Jefferson Circuit, we were encouraged to take students for demonstration laps. Watch those tire temps/pressures. Pictures seem a little odd - Everything seems stretched to me. Car is still very dirty from a wet track day followed by an hour on the wet skid pad.
Now I must apologize to my students the day before for not taking them out on the main course; but, I really wanted to explore the limits and modes on the skid pad before pushing the envelope. I believe this was the only car on RFTs on the circuit during the weekend. Also, note body roll condition of the C4S compared to the near exact same position the next lap for the 135I. I still say springs before sway bars.
Alan
| 04-09-2008, 03:38 PM | #19 | |
Private No Class
White911...not to hijack the thread but...how tough was it to get around the C4S? Did the 135 pull it on the straight or did he have to lift to let you go around?
| 04-09-2008, 05:49 PM | #20 |
Not difficult at all. I had raised my rev limit to 5K. After all, we were playing nice because we had students in the car and that course is very short. It seems, I probably know the track better then he does. Note, for one lap there is not much distance between us. This particular course was designed for students who had never been on a race track before.
Alan
| 04-11-2008, 09:04 AM | #21 |
Yes those tires are certainly tucked up into the wheel wells, although body roll doesn't seem that bad. Did you happen to check to see if you stayed off the bump stops?
135i built 2/14/08 SGM w/Black and AL, 6 forward gears
| Bookmarks |
