      09-13-2012, 11:41 PM   #265
KellyK
Lady Driven
KellyK's Avatar
Drives: AW 2011 128i
thanks so much ! just installed my gloss black ones. ended up having to take the scoops out to get my hand in there and pry them out... end result looks great !
      09-14-2012, 07:44 AM   #266
m3nt0s
Drives: 09 128i
2009 BMW 128i  [0.00]
Originally Posted by e82n54 View Post
Thanks for the DIY instructions!
I was able to pop out the bottom clips with my hand so it was very fast.
Bottom and side clips I could get with my hands. Used a flat screw driver for the tops, came right out. If you're an absolute idiot with doing this sort of stuff like I am, the most important tool is patience.
R.I.P. Charles "Vodyk" Gale - amazing friend for 13 years, 1 tragic night
2009 128i Jet Black on Black Leatherette N51 6AT CPO Until 4/15
135 Grilles || 15% Llumar Tint || Magnaflow Catback || Wish list grows...
2012 Toyota Yaris LE 5-Door Magnetic Gray Metallic 4AT
72 Month/120k Warranty || 20% Llumar Tint || Debadged
      09-22-2012, 11:19 PM   #267
kb135
kb135's Avatar
Drives: 135i Space Grey
Exclamation
Just a heads up to anyone removing/replacing the kidney grills. This writeup was great first of all! But there is one thing I encountered which anyone should look out for, that is, when pulling the kidney grill out, if you pull the bottom half out first at a bit of an angle, you risk scraping paint off the top left and right corners of the bumper where the top of the kidney grill is, since the edges of the kidney grill tend to gouge it out... see pic below...
Luckily I had touch up paint and you can't tell what happened unless you knew where to look.... but to avoid this just try not to pull the bottom half out too much before starting to remove the top half.i.e. don't create too much of an angle when removing the kidney grill. try to pull out as straight as possible.
      09-28-2012, 03:27 PM   #268
Boosted_N54
Boosted_N54's Avatar
102
Drives: 135i N54
Originally Posted by AndyM
Tools Required
T-30 Torx Driver
Right Angle Tool
Flashlight
Flat Blade Screwdriver
Removing the Kidney Grills
With the hood open, begin by removing the 4 T-30 Screws above the kidney grills and set them aside.
You will also want to lift the strip of insulation at the front of the hood off of it’s sleeve. You remove it by pulling up.
The Kidney Grills are held in with 6 clips. There are three along the top edge, one along the side toward the light and two along the bottom. If you are replacing the Kidney Grills, look at the new Grills: you will see the locations of the clips. To remove the kidney grills, you need to lift the two clips along the bottom of the grills. The easiest way to do this is with a right angle tool. They are available from Sears and are a handy tool to have. Sears part number: 00999802000 ($12.99). Sears carries a few different varieties.
You will want to begin by undocking the two lower clips. You will be able to see them in between the slats in the grill. You may need a flashlight to help you locate them. Once you have located them, insert the right angle tool to lift the center section of the clip and lift up. You will want to use your free hand to gently pull the grill toward you. You will want to prevent the grill from re-docking itself so once you have one side unclipped, keep enough pressure outward so it does not go back in.
With the lower clips undocked, you can begin working on the upper clips. In order to access the clips, you want to pull up on the bumper trim and if you look in from the engine compartment, you will see the three clips. Use a flat blade screwdriver or the pointed end of the pick to push the clips down.
As you did with the lower clips, gently pull the grill toward you to keep the clips from re-engaging. Once you have the 3 upper clips undocked, you can pull the grills out.
Installing the new Kidney Grills
To install the new grills, simply line them up and push them in until you hear the clips engage. Once you have both grills installed, replace the 4 T-30 Screws and tighten them down. Re-install the strip of insulation.
If you follow this DIY , please post a thank you.
I did this without taking the screws off the top of the kidney grills and with just a thin flat screw in 8min
MHD Custom Flash (E85) [Jake@MOTIV] / Vargas Stage 2 Turbos / Fuel it LPFP Stage 3+/ Moitiv Port Injection/ MMP Turbo Inlets/ 3.5 Tmap Sensor / ER FMIC /ER Chargepipe HKS-BOV / AA Downpipes / Agency Power Race mid pipes / Berk Technology race exhaust / BMW SSK / BC Forged Whees Toyo R888 tires / KW Club sport coilovers+KW Camber Plates / Spec stg2+Spec SMSFW/ APR Wing GTC200
      11-08-2012, 11:58 PM   #269
Old_Guy
Drives: A wolf in sheep's clothing
A sharp controlled pull at each edge worked fine for me.
Which to choose?
Went with gloss black performance surround, stock chrome inner:
      11-09-2012, 12:22 AM   #270
Tee-Dub
Tee-Dub's Avatar
Drives: 2008 135i
this job is way easier if you remove the two scoops for the cold air intake. You can then get your hands in there to release the clips. FWIW, I pulled mine and painted them with black Plasti-dip paint for about $8. They look just like the matte black ones you pay almost $100 for.
      11-09-2012, 09:24 PM   #271
andnkuhn
andnkuhn's Avatar
Drives: 135i.N55.6SPD.M-SPORT
2011 BMW 135i  [0.00]
Which to choose?
Attachment 779440
Attachment 779441
this is exactly what i the most also. great choice.
TauK-n Tky 1. at a time///
      11-10-2012, 07:17 AM   #272
^+1. Yup me too. I started at the top and worked my way down. For the bottom half you just have to tug/pull real hard.
      01-17-2013, 09:20 AM   #273
Ratcliffe33
Drives: BMW 118D
great walk through ! very helpful !
      03-22-2013, 07:05 PM   #274
135ivert
Drives: '10 E88 135i, '13 E70 M-sport
Any pics of full matte black grilles on Jet Black/BSM? I'm debating on matte vs. gloss.
      03-23-2013, 12:13 PM   #275
Dave ABP
Dave ABP's Avatar
Drives: AW BMW 135i Coupe
I think on a black car the gloss black will blend in nicer.
I have always liked matt black grills on white ones though even though i have gloss black on my white one and they do look good.
AW 2009 135i, BMW Performance front bumper & side skirts, BMW Performance Carbon mirror caps, BMW Performance gloss black kidney grills, BMW Performance exhaust, BMW Performance 269 alloys, Toyo Proxes sport tyres
      03-24-2013, 09:00 PM   #276
135ivert
You're probably right. I think I was just looking at ways to make it "mine".
Also, should I be worried about the grilles fading at a different rate than the paint? The sun's pretty intense here in CO, but I garage at night.
      06-26-2013, 08:41 PM   #277
Larz
Drives: E90 M3
Thanks! I just used these instructions to install black gloss grilles. I didn't have a right angle tool so I modified a metal pick used for teeth!
      07-12-2013, 09:59 PM   #278
STL BMW
STL BMW's Avatar
Drives: BMW 128i Coupe 6MT
Thanks for the DIY. For anyone wondering about a redneck right angle tool, I just bent a kitchen knife and it did the trick.
      07-14-2013, 06:36 AM   #279
LMBe82
LMBe82's Avatar
Drives: 2012 135i M sport
Thank you. I installed my performance grills in minutes because of this write up. It looks so good on Le Mans blue
      09-19-2013, 10:42 PM   #280
resurrect.ink
Drives: 2012 128i coupe
I have a 2012 128i - I literally popped the hood and tugged on each grille. The top will pop first and give it a little extra tug on the bottom. They come right out and you pop the new ones in. Just took me five minutes. love it!!
      10-03-2013, 10:20 AM   #281
GMD
Took my grilles out yesterday, and have a tip for anyone with small hands. Instead of fussing with a right angle tool, I simply pulled back gently on the top of the bumper where the torx were, and reached my hand down in and lifted up on the lower tabs. Way easier than with a tool, given you can fit your hand in there.
      12-21-2013, 11:40 AM   #282
Iron Man
Iron Man's Avatar
Drives: '13 128i Alpinweiß/Korallenrot
I just did this as the first mod for my 128i. I took more time debating about using tools, and in the end I just put on cut resistant gloves, grabbed the original grills and yanked them out. Just make sure to pull straight towards yourself and they "pop" out suddenly when they un-clip. Had to pull pretty hard.
Just popped the new grills in. Took a few seconds.
2013 128i I Alpine White/Coral Red I M-Sport Pkg I Heated Seats I BMW Performance Grills
      12-22-2013, 01:19 PM   #283
cmcdonald
cmcdonald's Avatar
Drives: 2012 BMW 128i
Just did this today, switched my stock grilles for the BMW Performance gloss black ones. I did it the same way Iron Man did, just yanked em straight out. Worked really well, no scratched and no broken tabs. Car looks much better without the chrome grilles.
2012 BMW 128i: BMW Performance Rear Spoiler, BMW Performance Front Grilles, 20% Tint, BMW 135i M-Sport Axle-back With Shadowline Tips, Golf-Tee Mod, 261 M-Sport Rims with Falken 235/40R18 265/35R18 Tires,Depo Smoked LED Side Makers, Eiback Pro Springs (To be installed)
      03-16-2014, 04:28 PM   #284
maxslug
Custom User Title Here
Drives: 2011 135i 6MT, 2014 E84 X1
thanks for the write ups! I did the same trick -- undid the torq bolts and then gently pulled from inside the grill, first up from the bottom and then down from the top. No other tools used, no broken tabs, no chipped paint.
-m
I drove the first Saab in the very first few 24 Hours of LeMons, and I run the GTI-VR6 List.
Previous Rides: 400whp GTI-VR6 Turbo, MK2 GTI, 72 Dodge Dart, Audi Coupe Quattro, Accords, Subies
      03-24-2014, 08:19 PM   #285
JeffyD
Destroy All Monsters
JeffyD's Avatar
Drives: '02 EB M Coupe, '11 M Coupe
Great write up.
I wound up just unscrewing the torx screws, and using a tiny flathead screwdriver. If you pull at the corners using the second slat from the headlights, and do so with consistent pulling - ie not jerking - they'll pop out with nary a worry about paint damage or broken clips.
Just make sure to use your other hand to push on the bumper while you pull at the grille.
I may have just lucked out, so don't take my advice and get upset if it doesn't work out as well.
      04-13-2014, 04:48 PM   #286
128GP
128GP's Avatar
25
Drives: AW 328i 6sp RWD M Sport
Great vid, i used a long flathead, took all of 10 minutes.
