      04-22-2008, 08:03 PM   #23
malves85
Drives:
Send a message via AIM to malves85
Very nice video. Im sad to say ive never actually seen someone change oil on a car before. seeing its easier then i thought i might change the oil myself every 3 or 5k miles and just take it to bmw for the routine 15k.
Thanks for the video!
      04-22-2008, 08:06 PM   #24
Mad Dragon
Mad Dragon's Avatar
Drives: 2010 GTI
Before you ruin your filter housing, you need to buy one of these:
      04-22-2008, 08:36 PM   #25
Robert
Drives: 135i, current is350
N52 and N54 share the same oil cap?
- There's nothing in my pocket other than knives and lint
      04-22-2008, 08:43 PM   #26
Mad Dragon
Mad Dragon's Avatar
Drives: 2010 GTI
Yes.
The price on Centernet is $17.75, but that's probably dealer cost. I forget what I paid for mine, but I can guarantee it's a lot cheaper than a new filter cap.
You'll need a 27mm socket, too.
      04-22-2008, 08:44 PM   #27
malves85
Drives:
If someone is up to it can you make a complete list of everything a total beginer like myself will need to do an oil change at home.
From the video I got:
7 quarts of bmw synthetic oil
Oil filter
Oil catch pan
Oil filter pliers
17mm wrench
      04-22-2008, 08:50 PM   #28
TunedM2
TunedM2's Avatar
Drives: 2016 LBB M2
Thanks and nice garage flooring. That's another thing on my "to do" list!
      04-22-2008, 09:11 PM   #29
Bizall
Bizall's Avatar
Drives: 2018 M3-Alpine White/6MT
Nice vid/write-up.
2018 BMW M3 - Arrived (Alpine White/6MT)
2014 BMW 335i M-Sport (Sold) 12.4 @ 113mph
2008 BMW 135i (Sold) 12.8 @ 106mph
      04-22-2008, 10:57 PM   #30
JohnL135I
Donkey Kong King
Drives: 2012 Boss 302
Oil filter
Oil catch pan
Oil filter pliers
17mm wrench
You'll need either a jack with a couple jack stands (safety), or a couple ramps. Next you'll need some rags and some gloves for your hands. And you'll need a funnel for your oil when pouring into the engine.
      04-23-2008, 01:06 AM   #31
Robert
Can someone comment on my question whether it has to be BMW oil?
      04-23-2008, 01:11 AM   #32
JohnL135I
Donkey Kong King
No, it does not have to be bmw specific oil. I believe the owners manual also recommends Mobil 1 and Castro Synthetic.
      04-23-2008, 01:39 AM   #33
ichiban
ichiban's Avatar
57
Drives: 08 135i
is it okay to switch between mobil 1 and bmw synthetic?
      04-23-2008, 01:43 AM   #34
Mystiqueskillz
Drives: 2007 Honda S2000
WOW the filter for the 135i is a lot different compared to other cars.
      04-23-2008, 01:51 AM   #35
JohnL135I
Donkey Kong King
shouldn't be an issue, I believe Mobil 1 says is compatible with all conventional and synthetic oils on the market.
      04-23-2008, 03:00 PM   #36
mad chemist
mad chemist's Avatar
Drives: F82 M4
Originally Posted by JohnL135I View Post
Mad Chemist-
I actually used an extra plastic floor tile between the jack and the plastic jack point on the car. After the job I actually had an impression on the plastic floor tile of the plastic jack point. However, I had no damage to the jack point on the car. I suppose using some wood would work also. The bad thing, is there is not a whole lot of clearance between the jack point on the car and the jack when its completly lowered.
Cheers...:headbang:
Thanks John,
I have just bought a proper neoprene jack pad from Seally Tools in the UK. Hopefully this will do the job.
BTW, I also had hardly any clearence between the jack and the jack cup on the car when I first attempted a lift!.
Cheers,
Mad Chemist.
      04-24-2008, 12:09 AM   #37
SlickShift
SlickShift's Avatar
Drives: '14 M235i, '14 X1 M Sport
Two Questions:
Did you use all 7 qts of oil when filling up the engine?
And are those gardening gloves? :wink:
-Nick
2014 BMW M235i
Mineral Grey
/Coral Red/Aluminum
Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i
      04-24-2008, 02:18 AM   #38
JohnL135I
Donkey Kong King
Originally Posted by SlickShift View Post
Two Questions:
Yes, I ended up adding a full 7 qts. First I put in 6 qts, let it idle, checked the electronic dipstick (it said full), then I added one more qt for a total of 7.
Those are not gardening gloves, its actually an old flight glove I had. USAF-Above All:headbang:
      04-24-2008, 08:08 AM   #39
josh
Drives: E36 M3, 135i
Just to double-check: is the oil filter same as for a 335i? I can't find the 135i listed on BMW parts e-sites yet.
      04-24-2008, 01:03 PM   #40
JohnL135I
Donkey Kong King
Its the same motor as the 335i, so I would assume its the same part #. I would call a BMW service dept. and check the price for filters for a 335i and a 135i and ask if they show the same part number.
      04-24-2008, 01:43 PM   #41
AndyM
AndyM's Avatar
82
Drives:
Originally Posted by denial View Post
Does anyone know what to torque the drain plug to?
Per TIS, the drain plug gets torqued to 25NM.
      04-24-2008, 01:59 PM   #42
AndyM
AndyM's Avatar
82
Drives:
You lubed the O-Rings prior to installing them right?
      04-24-2008, 07:17 PM   #43
Mad Dragon
Mad Dragon's Avatar
Drives: 2010 GTI
All N5x gasoline engines use the same oil filter.
      04-25-2008, 02:39 AM   #44
JohnL135I
Donkey Kong King
Yes, I lubed the O-Rings.....
