      04-25-2008, 09:10 AM   #45
Templedogg
Drives: 135i, Trailblazer SS, 1934 PU
Originally Posted by JohnL135I View Post
Yes, I lubed the O-Rings.....
Do you just lube them with a little motor oil? If not what?
      04-25-2008, 09:30 AM   #46
AndyM
AndyM's Avatar
81
Drives:
Yes, dip your finger in the (new) oil and lube the O-Rings, then put them on.
Man this thread going down the gutter!
      04-25-2008, 02:18 PM   #47
ChrisK
ChrisK's Avatar
Drives: '19 M2 Comp (On the List)
2015 BMW X1  [0.00]
2017 BMW M2  [0.00]
2015 Porsche Macan S  [0.00]
Which website has the best prices on filters?
      04-25-2008, 02:53 PM   #48
malves85
Drives:
Send a message via AIM to malves85
http://www.1addicts.com/forums/showthread.php?t=7945
These guys seem really good. I plan on ordering a few kits when I get close to that 1k mark.
      04-26-2008, 04:48 AM   #49
Robert
Drives: 135i, current is350
Bought one today for about 20 dollars from the dealer. thanks for the parts number, I dug it up from my phone while at the dealer because he couldn't locate the parts number.
- There's nothing in my pocket other than knives and lint
      05-06-2008, 03:33 PM   #50
TMc135
1addict, and proud
TMc135's Avatar
Drives: '06 330xi (dd)
1995 BMW M3  [5.00]
2008 BMW 135i (SOLD)  [0.00]
2006 BMW 330xi  [0.00]
Jack Points???
Probably a stupid question but I see where I jack the car up but then where do I put the jack stands? Do they go just forward of the jack mount? It is hard to tell b/c of the underbody cover. I don't want to damage anything. Thanks.:iono:
Daily Driver: '06 E90 330xi Monaco Blue w/burl walnut trim, Terra leather, Sport Pkg, Nav, Prem Audio & iPod, Cold weather pkg, VMW VB3 18's, KW V1 suspension, tint (2008 135i modded - SOLD)
Track Car: E36 M3 Avus Blue coupe, too many mods to list!
      05-06-2008, 03:43 PM   #51
denial
denial's Avatar
This is what I did. I jacked up the car using the rear jacking points (per manual, the points in front of the rear tires) high enough so that I could slip a jack stand underneath the front jacking points (points behind the front tires). I repeated this step for the other side.
I also cut out some blocks of wood to use as inserts into the stock mounting points. while they seemed to work ok they ended up slightly cracking when it was all said and done. I plan on ordering some aluminum stock (square 1 inch bar), cut it, and make some new, solid inserts.
      05-06-2008, 03:59 PM   #52
Templedogg
I just used Rhino Ramps, they are cheap and easy and get the car high enough for the job. With the cost of the ramps, oil kit, etc you are still cheaper than having the dealer do it one time.
      05-06-2008, 08:42 PM   #53
TMc135
1addict, and proud
TMc135's Avatar
1995 BMW M3  [5.00]
Any issues with the ramps sliding out on you while trying to drive up them? The jack I was using today wouldn't go low enough so I had to drive up onto 2x6's and they kept sliding out on my slick garage floor. Just wondering if I will have the same issue with the ramps?
      05-07-2008, 01:15 AM   #54
Templedogg
Mine do not slide on my concrete floor.
      05-27-2008, 02:11 PM   #55
mikeco
Drives:
Really cool video, but maybe I'm confused. According to http://www.bmwusa.com/Standard/Conte...e/Default.aspx you get oil changes for "free" (built into the price of the car) for 4 years.
BMW Maintenance Program: One of the most comprehensive maintenance programs in its class covering all factory-recommended maintenance, oil service and fluid service, as well as items that need replacement due to normal wear and tear - such as brake pads, brake rotors and wiper blade inserts.
Is there an advantage to doing it yourself? Better oil?
      05-27-2008, 02:27 PM   #56
AndyM
AndyM's Avatar
81
Drives:
Originally Posted by mikeco View Post
Really cool video, but maybe I’m confused. According to http://www.bmwusa.com/Standard/Conte...e/Default.aspx you get oil changes for “free” (built into the price of the car) for 4 years.
BMW Maintenance Program: One of the most comprehensive maintenance programs in its class covering all factory-recommended maintenance, oil service and fluid service, as well as items that need replacement due to normal wear and tear–such as brake pads, brake rotors and wiper blade inserts.
The BMW free oil change is every 15,000 miles. Most people prefer shorter intervals.
      05-27-2008, 03:06 PM   #57
wrongprotocol
wrongprotocol's Avatar
Drives: 128i MT, white
great tutorial! thanks!
      06-11-2008, 09:26 PM   #58
crzy4135i
crzy4135i's Avatar
Drives: 08 135i
Rhino ramps have rubber blocks at the leading edge that grab the floor when the tires first start going up the ramps. The rubber pieces can fall out while carrying the ramps around and if you don't notice it.. the ramp will slide the next time you use it.
Ordered 4/7/08, Delivered 5/15/08, Sold, but not forgotten.
      06-11-2008, 10:06 PM   #59
crzy4135i
crzy4135i's Avatar
Drives: 08 135i
Thanks for taking the time to put that video together!
[u2b]0RFrakD1lsg&feature=email[/u2b]
      06-19-2008, 11:08 PM   #60
BMWhokie
Drives: BMW 135i
Is it possible to remove the filter housing when there is oil inside the engine? The O-ring shifted as I was tightening it. I can see the O-ring in between the plastic housing and the metal housing.
      06-22-2008, 04:33 PM   #61
KeithLM
Proud 1er
KeithLM's Avatar
Drives: Crimson/Coral 135i
Send a message via AIM to KeithLM Send a message via Yahoo to KeithLM
How many washers are on the drain plug? I see one on there that looks like a typical steel washer, it doesn't look like the crush washer. Does this stay or does it go?
      06-22-2008, 05:32 PM   #62
crzy4135i
crzy4135i's Avatar
Drives: 08 135i
One washer.. the new oil filters come with a new copper washer for the drain plug.
      06-22-2008, 09:46 PM   #63
Mad Dragon
Mad Dragon's Avatar
Drives: 2010 GTI
Loosen it and let it sit for a minute, so it'll drain. If you haven't started the engine since you filled it, you can take it right off. Either way, you're going to need a new o-ring.
      06-22-2008, 10:42 PM   #64
KeithLM
Proud 1er
KeithLM's Avatar
Thanks for the reply. I saw in the check list thread to remove the "washer" and put on the "crush gasket" so I decided that must be the case, and figured two washers was probably bad anyways and all seems well (so far).
      07-25-2008, 11:46 PM   #65
60Driver
Drives:
Thanks for the video. Gardening gloves, that was funny. I was wondering where you got the nomex gloves. I really liked the old Air Force motto. The new one, not at all.
~My other car is a Blackhawk~
[SIGPIC][/SIGPIC]
      08-02-2008, 11:43 PM   #66
twinturbo135i
twinturbo135i's Avatar
24
Drives:
okay, so can I assume that the Hi Performance BMW oil is made by Castrol?
former 135i owner - ditched it for a new Camaro SS
