10-14-2008, 07:28 AM | #89 | |
Rep 268
It is my understanding after chatting with TC that the TC Kline camber plates also are limted due to the size of the hole in the frame of the car where the camber plates mount. Meaning, roughly 2.0 to 2.5 negative camber is the maximum anyone is achieving with Vorshlag or TC Kline without cutting the actual frame hole to make it bigger. (Assuming an average lowering in the 1.5 inch range) My guess is 3.5 negative is going to be more desireable for track and autocross. Now we just need a bolt on camber plate that can do it....:iono: |
10-17-2008, 12:32 PM | #90 |
Rep 268
Just bought the TC Kline D/A coilovers and the Vorshlag camber plates. Decided to start with the 350F/500R rates and then play around from there. Getting ready for some fun in STU next year.
TC mentioned that the "soft" stock subframe bushings might be the limiting factor to using a heavier spring efficiently at this time. He is putting some of the perfomance bushings on his car soon, so it will be interesting to see the difference. After I install the coilovers/camber plates, I will put a larger front sway bar on also....problem is my car still has a couple of weeks coming back from Germany...I am going through withdrawls...but the 156 mph stent on the autobahn makes me remember it was all worth it.:smile: |
10-17-2008, 01:08 PM | #91 |
Santa Fe Concorso
103
Rep 2,984
I'm envious of that setup and want to hear the details once you have it installed. :thumbup:
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
10-18-2008, 01:19 AM | #92 | |
Rep 1,764
Orb |
10-19-2008, 12:38 AM | #93 | |
Family Man
14
Rep 126
[SIGPIC][/SIGPIC]
11-02-2008, 10:39 AM | #95 |
Rep 41
What is done to these TC Kline Koni's to warrant such a high price as compared to the actual Koni shocks available right from Koni? I can see they are modified in some way and include springs and such. But, any specifics?
2004 Lexus IS300
11-02-2008, 04:49 PM | #96 |
Santa Fe Concorso
103
Rep 2,984
IIRC, TC Kline has them custom valved for their suspensions.
11-03-2008, 09:26 PM | #97 |
Supreme Allied Commander
3848
Rep 54,378
Drives: F80 M3
TC Kline are double adjustable and valved to TC's specs.
11-03-2008, 11:27 PM | #98 |
Rep 41
Cool, thanks.
Do you know if they still have the famous Koni warranty?
2004 Lexus IS300
11-04-2008, 01:53 AM | #99 |
3848
Rep 54,378
Drives: F80 M3
09-02-2009, 10:59 AM | #100 |
183
Rep 2,391
resurrecting old thread here -
you guys needed 10mm spacers for the 18x8.5 ET48 front Breyton wheel to clear the strut on the front end. if i'm using an 18x8.5 ET40 wheel on the front, will i have that clearence for the TC setup in the front? some guys are you using these front wheels with the KW V3, and they appear to be wider springs than the TC setup, so i just want to be sure. thank you!
2009 135i | space grey | sport | navi | hifi | heated
dinan stage 2 software | bmw performance exhaust kw v2 | hotchkis front sway | vmr v710 |
