FORUMS
- 5
| 05-28-2008, 02:40 PM | #1 |
Let's remove/install doorsills
The Doorsills are held in place with 6 clips. To remove the doorsills, you will need to start at one end and release each clip. I started at the front end of the door sills and worked my way back.
Use an Interior Trim Removal Tool to un-dock each clip. If you have one with a V shape on the end, you will be better off as you can get on each side of the clip. ![]() Slowly work your way to the other end and the door sill will be removed. The back of the doorsill looks like: ![]() With the doorsill removed, you can install the new doorsill. Installation is simple, simply line up the clips with their respective holes and push down until the clips dock. ![]() |
| 05-28-2008, 02:55 PM | #3 |
![]() Drives: 2008 135i SGM MT Join Date: Nov 2007
Garage List 1995 Acura Integra SE [0.00]
2008 BMW 135i [0.00] 2006 Porsche Cayman S [0.00] 1999 Toyota 4-Runner [0.00] |
ANDY.............are you teasing us with this?????
We can't replace our door sills unless we can buy new ones...Hint...Hint. When will you be getting them?????
![]() 2008 135i SGM |
| 05-28-2008, 05:57 PM | #6 |
| 05-28-2008, 07:59 PM | #7 |
yeah I would really like to put in the illuminated doorsills to match the illuminated door-handles. If anyone has done this, how difficult was it to do? where did you get the replacement doorsills?
Thanks in advance! |
| 05-28-2008, 08:31 PM | #9 | |
As for illuminated shift knobs, you just need to know where to look. :wink: |
| 01-04-2009, 07:36 PM | #10 |
![]() Drives: 135i, 335i Join Date: Sep 2008
Andy- are those door sills you took out from a ZSP, aka in shadowline, if so are they for sale? thanks
E82 N54 6MT 6FL 668 KASW turned in
E92 Crimson/Cream N54 6MT, ZSP, ZPP, ZCW, Nav, Sat radio, HD Radio, Logic7, PDC, Active Steering, Active Cruise, 6FL, CA |
| 01-27-2011, 10:39 AM | #13 |
Another greay DIY from you, Andy. Just did this and it was a breeze, thanks!
"I got my BMW up to about 160 MPH on Saturday.... I am now the only guy that has a skidmark on his drivers seat"
| Bookmarks |
