      05-23-2009, 09:14 PM   #45
AchtungF80
AchtungF80's Avatar
Philippines
208
Drives: '16 f80, '87 e30, '00 BB6
2008 135is  [4.75]
2010 Cooper S  [5.00]
1991 318is  [5.00]
Send a message via AIM to AchtungF80
Well chalk me up for trying to think outside the box...ermmm instructions.
Already frustrated at how much had to come off to install my SSK, I decided to try and just change the shift lever and new plastic cup. It bolted right up just fine, I could shift into every gear...at least till I started moving.
I now realized why BMW supplies a replacement arm....to give maybe 0.25" clearance to the driveshaft.
Gonna have to drop everything again later this week.
ig: achtungf80
      05-23-2009, 11:13 PM   #46
TimMc
TimMc's Avatar
Drives: 135i SCT N54
Yeah, I think the new arm is for this reason -and also to keep the "attack" angle into the gearbox similar to standard to stop introducing added notchiness to the gearchange.
Hope you get it all sorted out soon!
Driving - Man 135 (LeMans/Black). BMW Perf SW, Quaife LSD, KW V2s, Ground Control camber plates, M3 front Control Arms & SB, Helix IC, AR DPs, PROcede V5, ER CP, Forge DVs, BMS OCC, Setrab OC, P3 Gauge, Alcon 6 Piston Calipers, DBA 365mm 2 piece rotors.
Riding - BMW R1200RS Sport, Merida Scultura 7000E, Avanti Aggressor, Malvern Star Equipe, Mini Mal.
Proudly from the Shire.
      05-26-2009, 04:24 PM   #47
BlackjackMulligan
Most interesting Roadster
Drives: '01 Z3.0 Roady;'10 C300 Sport
So the linkage was hitting the driveshaft?
I can't complain, but sometimes I still do........Life's been good to me so far.
- Joe Walsh
      05-26-2009, 05:10 PM   #48
AchtungF80
AchtungF80's Avatar
Philippines
208
2008 135is  [4.75]
1991 318is  [5.00]
in 2nd, 4th and 6th it rubbed on the driveshaft...R, 1, 3 and 5 no problems. This was not detectable until the car was in motion and load introduced.
I suspect the new arm raises and gives you about 0.25" of clearance once installed and in the affected gears.
ig: achtungf80
      07-14-2009, 10:14 PM   #49
denial
denial's Avatar
back from the dead. no one ever made a model specific DIY I'm assuming?
      08-04-2009, 06:50 PM   #50
sootyvrs
sootyvrs's Avatar
26
Drives: M135i
Maybe this will help. Someone did this without having to jack the bottom up and remove bottom parts but it does seem more fiddly
http://babybmw.net/forum/viewtopic.php?f=29&t=12190
2018 BMW E87 M2
      08-04-2009, 10:08 PM   #51
denial
denial's Avatar
only for the USD 128i. the 135i's come with a new shift arm in addition to the shift lever. you have to jack it up to replace it, there's just no way around it.
      08-05-2009, 09:56 AM   #52
BlackjackMulligan
trust me, you cannot change out the shifter on the 135i from the top. It is impossible, believe me I tried. The shifter in those pics moves up and away enough to see the clip that holds the lever to the linkage......there's not as much "play" on the 135i to move the lever enough to see the clip from above. Plus, it's a different clip that can't simply be pulled off, it's a locking style clip that has to be pryed up and out at the same time.
- Joe Walsh
      08-05-2009, 09:56 AM   #53
The Cthulhu
Drives: N/A
I installed an Evolution 3 SSK in my car. I normally take pictures of everything, but I was too pissed off.
I didn't have to drop my exhaust, but I had to remove my gearbox brace. I also had to cut an allen wrench very short to tighten the screws around the new metal cup that holds the shifter pivot ball. They made the kit with a different linkage piece in mind, so i needed to machine two parts down.
There's also a piece that holds the shift cup that holds the ball. My kit included two replacement pins for that, but it was so much of a pain in the ass to get to that I didn't bother. I may go back and drop my exhaust now that I have Torx sockets.
It took me 3-4 hours and took a week to break in. It feels great now.
      08-05-2009, 10:00 AM   #54
BlackjackMulligan
lol, that was pretty much my state of mind as well. And imagine my frustration, when I didn't particularly care for the increased effort of the SSK I chose, that I had to do it all over again to take it out
- Joe Walsh
      08-05-2009, 10:44 AM   #55
Formel1
Formel1's Avatar
23
Drives: 2009 BMW 135i
I've got the BMW factory instructions...if you want I can scan and post them. They actually call for dropping the drive shaft to get to the new carrier...took mine to BMW for $250 and let them deal with it warranty wise should something happen down the road...money well spent...no bloody knuckles at least...
      08-05-2009, 12:53 PM   #56
The Cthulhu
Drives: N/A
Dropping the drive shaft makes sense, the stupid, giant guibo gets in the way.
      08-05-2009, 11:00 PM   #57
TimMc
TimMc's Avatar
I for one would certainly love to see the factory instructions if you're able to post! I'm yet to install my factory kit.
Cheers, Tim.
      08-06-2009, 08:32 AM   #58
Formel1
Formel1's Avatar
23
I'll scan and post them when I get home for lunch today.
      08-06-2009, 07:58 PM   #59
Formel1
Formel1's Avatar
23
As requested...
      08-07-2009, 07:47 AM   #60
TimMc
TimMc's Avatar
Awesome! Thanks Formel1!!!!!
I've got little excuse now. Just need to find TIS 25 11 211 & TIS 25 11 245 & have a go. Does anyone know the spec of the "standard BMW lubricant" they refer to?
Cheers, Tim.
      08-07-2009, 09:11 AM   #61
The Cthulhu
Drives: N/A
Cheers, Tim.
You have to grill a weisswurst and collect the oil drippings.
      08-07-2009, 09:19 AM   #62
sootyvrs
sootyvrs's Avatar
26
Drives: M135i
Yes apologies your are right, the 135i has an additional parts...
Just fitted mine, on my 130i, all from above and it took about an hour, most of which was trying to work out how to remove the white collar to gain access to the circlip!
The secret was in the technique of holding the 2 screw drivers as per the E90 thread "How to"
I also had to be very careful removing the circlip as it could easily drop (luckily there is a spare one in kit) for which I used some long nose pliers.
The easiest bit was removing the gear knob. I just put it in 2nd and pulled upwards and the gear knob, leather trim and plastic trim that connects it all came off! I think I was suppose to remove the leather trim from the plastic one first! ops:
I'm totally a novice when it comes to DIY stuff on the car and I was impressed how easy it was to do thanks to the excellent write ups and pics from BabyBMW and also E90 Forum.
Went for a quick drive and the travel is obviously shorter and it snicks into gear quite nicely so I'm very pleased!
2018 BMW E87 M2
      09-16-2009, 01:19 PM   #63
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [5.00]
Send a message via Yahoo to adrean8j
Originally Posted by HondaGoneRogue View Post
I installed mine with the do it yourself from the 335 guys. It wasn't that bad, but you do have to remove the midpipe of the exhaust and the heatshield. They don't have to remove their shifter support arm, but we do as the kit comes with a different one. It looks way harder than it is. If anybody has any questions let me know and I'll try to answer them as best I can.
So you have to remove the midpipe from the downpipes to the exhaust? That I wager will be the most difficult part for me due to how much of a pain it is to clamp up the DP's.
SGM was God's color and has been recalled to heaven.
      09-16-2009, 01:26 PM   #64
Formel1
Formel1's Avatar
23
Actually, BMW even says you have to drop the drive shaft to properly get to the carrier that has to be replaced. Not a difficult thing, but consumes time, and of course if something goes wrong, like a bolt loosens or snaps, warranty claim and they see it wasn't installed in house, knowing BMWNA, it will be denied. Was worth the $200 to have a dealer throw it on, and my knuckles are happy for it...
      09-16-2009, 01:35 PM   #65
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [5.00]
Yeah I don't have the BMW SSK so I won't have to drop the driveshaft to replace that particular piece...just worried about access to the retaining clip...which is the only real reason to get under the car for other SSK's.
      09-16-2009, 06:35 PM   #66
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [5.00]
Ok I finally installed the B&M SSK today. I had access to a lift which in hindsight is a HUGE bonus. It is not a bonus due to the difficulty (which is nil) but due to the angle at which you have to reach up to undo the U-clip and shifter arm. One the car is high enough and you have enough light (not to mention skinny girl wrists like mine...damn genes...LOL) then removed aforementioned parts is VERY easy. Install is reverse of removal. Took about an hour as stated in the instructions. You do NOT have to remove the driveshaft OR the midpipes. The throws are definitely shorter...maybe up to 45%-50% shorter..maybe more. I am assuming the shift motion will break-in over time. Right now it is a bit notchier than before- good thing, or bad thing depending on your preference. Two big thumbs up on this from me!
