      10-01-2012, 07:21 AM   #1079
Greg@DetailedImage
Drives: clean and protected
Today's Daily special (October 1, 2012) is Dodo Juice Sour Power Gloss Enhancing Shampoo.
Regular Price for 250 ml is $13.99. Today's price is $10.78!
  • Perfect maintenance shampoo that enhances gloss and depth
  • Lots of lubricity and slickness to help minimize adding imperfections
  • Concentrated formula means only a little product is needed per wash
  • Best used with a grout sponge or sheepskin wash mitt
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
      10-02-2012, 08:14 AM   #1080
Greg@DetailedImage
Today's Daily special (October 2, 2012) is Lake Country Orange Light Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.39!
Regular Price for 5.5 inch is $7.99. Today's price is $5.95!
Regular Price for 4 inch is $4.99. Today's price is $3.72!
Regular Price for 3 inch is $3.99. Today's price is $2.97!
  • A light cutting pad designed to remove moderate swirls and scratches with a medium polish
  • Works great with the Meguiar's Ultra-Cut Compound M105 and the Menzerna Super Intensive Polish SI 1500 (PO83)
  • We recommend caring for your pads with Lake Country Snappy Clean Pad Cleaner
  • Generally we recommend following up with a lighter pad and polish after
      10-03-2012, 08:13 AM   #1081
Greg@DetailedImage
Today's Daily special (October 3, 2012) is Clay Magic Medium Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $18.24!
  • Remove embedded surface contamination that does not come off during the washing process
  • Medium grade bars will remove contamination quickly, however it may result in micro-marring
  • Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
  • Helps you get the most out of any step you perform after using the clay bar
  • Follow up the medium grade clay bar with a finishing polish to remove any micro-marring
  • We recommend using Poorboy's Spray & Wipe as a clay bar lubricant and quick detailer
      10-09-2012, 08:03 AM   #1082
Greg@DetailedImage
Today's Daily special (October 9, 2012) is DI Accessories DetailedImage.com License Plate Frame.
Regular Price is $5.99. Today's price is $4.46!
  • Black DetailedImage.com license plate frame with white lettering
  • "Clean Shine Protect" tag line
  • Thank you for your support!
      10-10-2012, 07:59 AM   #1083
Greg@DetailedImage
Today's Daily special (October 10, 2012) is Chemical Guys Citrus Wash Wheel & Rim Cleaner.
Regular Price for 16 oz is $8.99. Today's price is $6.70!
  • Citrus based wheel cleaner that is safe to use on virtually any wheel surface
  • Concentrated solution makes this a great value as you can dilute it down 7:1 with water
  • Works best when an E-Z Detail Brush is used in conjunction with Wheel & Rim Citrus Cleaner
  • Protect your just cleaned wheels with Poorboy's World Wheel Sealant for easy maintenance
      10-11-2012, 08:12 AM   #1084
Greg@DetailedImage
Today's Daily special (October 11, 2012) is Meguiar's DA Microfiber Finishing Disc Buffing Pad - 2 pack.
Regular Price for 5.5" is $21.99. Today's price is $15.61!
Regular Price for 6.25" is $23.99. Today's price is $17.75!
Regular Price for 3" is $13.99. Today's price is $10.35!
  • Use this pad to apply the Meguiar's DA Microfiber Finishing Wax
  • This item includes 2x DA Microfiber Finishing Disc Buffing Pads
  • Outstanding polishing power that provides a high level of gloss
  • Microfiber buffing pads are changing the way detailers work
  • Use it with the Meguiar's Professional Backing Plate, 5" Product Code: W67DA, 6" Product Code: S6BP
      10-12-2012, 08:11 AM   #1085
Greg@DetailedImage
Today's Daily special (October 12, 2012) is 303 Cleaner & Spot Remover.
Regular Price for 32 oz is $7.99. Today's price is $5.95!
  • A great pre-diluted all purpose cleaner for carpets, upholstery, vinyl, rubber, leather, plastic and much more
  • Safely removes oil, grease, ink, coffee, tea, wine, juice, blood, and tons more
  • Cleaning action increases with warm water, agitation, and longer dwell time
  • For maximum efficiency use in a 4oz pump spray bottle for increased product control
      10-15-2012, 07:26 AM   #1086
Greg@DetailedImage
Today's Daily special (October 15, 2012) is Meguiar's Self Cleaning Dispenser Bottle.
Regular Price for 16oz is $3.49. Today's price is $2.58!
  • A self cleaning dispenser bottle that helps you work faster and neatly
  • Purchase larger sizes of your favorite products and pour them in a convenient dispenser bottle
  • Dispenses exactly the right amount of product each time
  • Will not clog and you won't get dried out product left in the tip
      10-16-2012, 08:08 AM   #1087
Greg@DetailedImage
Today's Daily special (October 16, 2012) is Lake Country Yellow Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.29!
Regular Price for 5.5 inch is $7.99. Today's price is $5.83!
Regular Price for 4 inch is $4.99. Today's price is $3.64!
  • The most aggressive foam cutting pad, designed to remove the deepest swirls and scratches
  • Medium to heavy cutting polishes work great with a yellow cutting pad
  • You need to follow up with a lighter pad and polish combo afterward to remove haze on the surface
      10-17-2012, 08:13 AM   #1088
Greg@DetailedImage
Today's Daily special (October 17, 2012) is Surbuf R Series MicroFingers Buffing Pads.
Regular Price for 2x 6.5" is $16.99. Today's price is $12.57!
Regular Price for 2x 5.5" is $13.99. Today's price is $10.42!
Regular Price for 2x 4" is $9.99. Today's price is $7.29!
  • Excellent polishing power with minimal haze left behind!
  • Read a professionals recommendations on how-to use Surbuf pads properly
  • Each box comes with 2 pads
  • The pads can be washed and re-used many times
  • Perfect match for Porter Cable users with Meguiar's M105
      10-18-2012, 08:14 AM   #1089
Greg@DetailedImage
Today's Daily special (October 18, 2012) is DI Accessories Reclosable Storage Bag.
Regular Price for 24" x 24" is $2.99. Today's price is $2.23!
  • Simple solution for storing microfiber towels!
  • The large 24" x 24" size offers flexibility to accommodate dozens of towels
  • Thick reclosable bags make it a durable long term solution to storage needs
      10-19-2012, 08:10 AM   #1090
Greg@DetailedImage
Today's Daily special (October 19, 2012) is Chemical Guys Citrus Wash.
Regular Price for 16 oz is $9.99. Today's price is $7.39!
Regular Price for 128 oz is $32.99. Today's price is $24.08!
  • Ultra concentrated paintwork cleaning shampoo designed to strip off protection to start fresh
  • Powerful concentrated formula only requires 1oz of product per gallon of water to effectively remove layers of protection
  • Works well in a Gilmour Foam Gun
      10-22-2012, 07:16 AM   #1091
Greg@DetailedImage
Today's Daily special (October 22, 2012) is SONAX Leather Foam.
Regular Price for 400 ml is $14.99. Today's price is $11.17!
  • Cleaner, conditioner and protectant in one bottle
  • Foam action makes it excellent for perforated seats
  • Works on leather and leatherette seats
      10-23-2012, 08:08 AM   #1092
Greg@DetailedImage
Today's Daily special (October 23, 2012) is DI Microfiber Autofiber Zero Cuff Chenille Wash Mitt.
Regular Price is $9.99. Today's price is $7.39!
  • Extra long strands and extra soft strands equals excellent results
  • Zero cuff design ensures your hand and wrist are comfortable
  • Paint safe and highly effective washing tool
  • Very cool looking design that is fun to wash with
      10-24-2012, 08:09 AM   #1093
Greg@DetailedImage
Today's Daily special (October 24, 2012) is NanoSkin AutoScrub Fine Foam Pad.
Regular Price for 4" is $59.99. Today's price is $42.59!
Regular Price for 6" is $49.99. Today's price is $36.49!
  • The fastest way to safely deep clean your paint
  • Replaces the need for a clay bar while saving you time
  • Works with most orbital buffers with a hook and loop backing
  • Can be used 30 or more times so it's a better value than clay bars
  • Works great with the NanoSkin Glide
      10-26-2012, 08:08 AM   #1094
Greg@DetailedImage
Today's Daily special (October 26, 2012) is Lake Country Snappy Clean Pad Cleaner.
Regular Price is $1.49. Today's price is $1.07!
  • A citrus degreaser designed to help release product and contamination from foam pads
  • Simply pour into a 5 gallon bucket of water and allow your foam pads and applicators to soak
  • To further the cleaning, massage the pads while soaking, rinse with pressured water, repeat
      10-29-2012, 07:19 AM   #1095
Greg@DetailedImage
Today's Daily special (October 29, 2012) is DI Microfiber Car Wash Mitt.
Regular Price is $3.99. Today's price is $2.91!
  • Excellent wash mitt that is soft and paint safe
  • Very cost effective washing medium
  • Can be machine washed and dried afterward
      10-30-2012, 08:16 AM   #1096
Greg@DetailedImage
Today's Daily special (October 30, 2012) is Raggtopp Convertible Top Cleaner - Fabric and Vinyl Tops.
Regular Price for 16 oz is $12.99. Today's price is $10.00!
  • Safely and effectively removes contamination from fabric and vinyl convertible tops
  • Endorsed by Haartz, the primary OEM for American and European make convertible tops
  • After treating the surface, we recommend agitating a stain with a brush or towel
      10-31-2012, 08:28 AM   #1097
Greg@DetailedImage
Today's Daily special (October 31, 2012) is DI Accessories Disposable Floor Mat.
Regular Price for 10 pack is $5.99. Today's price is $4.25!
  • Durable mats to help prevent adding stains to clean carpets during a detail
  • Ensure your carpets look their best when you deliver the vehicle to your customer
      11-01-2012, 08:12 AM   #1098
Greg@DetailedImage
Today's Daily special (November 1, 2012) is DI Brushes Foam Brush.
Regular Price for 2" is $1.49. Today's price is $1.09!
  • Highest quality foam brush made proudly in the USA
  • Helps spread any detailing product uniformly
  • Very soft and gentle yet durable and strong
      11-02-2012, 08:45 AM   #1099
Greg@DetailedImage
Today's Daily special (November 2, 2012) is Menzerna Paint Refresh Professional Grade Detail Spray.
Regular Price for 22 oz is $23.99. Today's price is $17.03!
  • Cleans, shines, and protects your paint all in one step
  • Safe for painted surfaces, glass, plastic, chrome, etc.
  • Quickly removes dust, dirt, fingerprints, and light contamination
  • Leaves behind a layer of protection and anti-static properties
      11-05-2012, 08:09 AM   #1100
Greg@DetailedImage
Today's Daily special (November 5, 2012) is Meguiar's Professional DA Polisher Backing Plate W67DA.
Regular Price for 5" is $19.99. Today's price is $15.53!
  • Soft core foam allows for easier maneuverability compared to stiffer backing plates
  • Works with any polisher with a 5/16th shaft (such as the Porter Cable 7424XP)
  • Durable one piece construction ensures a long life
  • Works best with 5.5" pads or larger
