01-12-2009, 08:23 PM | #67 |
Rep 149
You're right bro, I should be grateful for any progression! :drinking:
01-15-2009, 09:15 AM | #68 |
Rep 149
Update:
BMW service center called yesterday and said 2 more regional techs were there inspecting my car. No word yet on how they will fix it or how long it will take. This upcoming Saturday will mark 1 month that my car has been in the shop. |
01-15-2009, 09:58 AM | #69 |
Rep 1,609
It sounds like a ECU related issue. Have they refleshed or checked your ECU?
01-15-2009, 10:36 AM | #70 |
Rep 475
So how much longer are they going to jerk you around until they give you a new one? I'm sure you didn't buy a new car so that it could sit in the shop for a month.
///M 135i
01-15-2009, 11:20 AM | #71 |
Rep 5,970
Can't diagnose a slipping clutch with an internet connection. :wink: (Well, I guess you could, but you'd have to drive down the road and watch vehicle speed vs RPM.) I can't believe they're still dicking around with this. If the symptoms are being described correctly, there's only one answer, and it's the clutch. |
01-15-2009, 11:21 AM | #72 | |
Rep 149
They were supposed to already have done this when they entered the PUMA case and when the field engineers saw the car in person the first time. Who knows?!! I cannot believe it has been this long with no serious resolution to this problem. At this point, they do owe me a new one! |
01-15-2009, 11:22 AM | #73 |
Most interesting Roadster
69
Rep 2,224
Drives: '01 Z3.0 Roady;'10 C300 Sport
what do you have for a loaner?
I can't complain, but sometimes I still do........Life's been good to me so far.
- Joe Walsh |
01-15-2009, 11:57 AM | #74 |
Rep 149
A slow, slow, slow, 328i w/ auto tranny. I would never buy this piece of crap. It is great on the gas though.
That being said, the interior of the 1 is so much more user friendly. The location of the dials and controls feels more natural. Also, the 3's interior is a bit too boring. I've had plenty of time to think about this. You know, while my car has been in the shop FOR A FREAK'N MONTH!! |
01-15-2009, 01:58 PM | #75 |
Rep 149
Update:
BMW just called and said the field service engineers have determined that the problem is.....wait for it...... THE CLUTCH! How many times have you all guessed it???? How many times have I told the service engineers and BMW techs what you guys have been saying?????? They said they are now ordering the clutch and all the necessary parts. I am so pissed right now. So freaking pissed.......... |
01-15-2009, 02:04 PM | #76 |
Rep 621
Wow. That's all I can say. I can't believe it would take then this long to figure it out.
01-15-2009, 02:11 PM | #77 | |
Rep 5,970
Print this thread and give it to them. To think a software update could fix something like that was just stupid. It was a complete impossibility. And for the BMW "engineers": WE TOLD YOU SO MFers!!!!!! An internet forum properly diagnosed this car in a couple of hours based on the owners description of the problem, without ever even seeing, and it took you guys a damn month. Way to go! :biggrin: |
01-15-2009, 02:13 PM | #78 |
Rep 1,609
Well, at least they figured it out and replacing the clutch should be a more straight forward job for them than monkey around the ECU.
01-15-2009, 02:13 PM | #79 |
Rep 149
What would you guys recommend I do at this point?
Do I really want a car that has sat in the shop for a month and now needs a new clutch and all its respective parts? Do I tell them to keep the P.O.S. and get a new car? |
01-15-2009, 02:15 PM | #80 | |
Rep 149
01-15-2009, 02:19 PM | #82 | |
Rep 5,970
Yep. I just looked back to the first page. You posted this at 12:52 and less than 6 hours there were already four people who said exactly the same thing....clutch. 1Addicts - 1 BMW Techs - 0 (after a month of screwing around) |
01-15-2009, 02:19 PM | #83 |
Rep 1,288
The very least you should gain is having them cover one month's payment on your car. You lost use of it for a month, it depreciated during that month. You should be entitled to one month's compensation in the form of them covering one of your auto payments.
You might also hit them up for courtesy oil changes or if you want to dump the car, hit them up for special deal on something else. |
01-15-2009, 02:31 PM | #84 |
Rep 475
Are there many signs of a clutch slipping? Buddy of mine seems to have lost power throughout the entire powerband of his wrx. Nothing major, but he says noticable.
///M 135i
01-15-2009, 02:35 PM | #85 | |
Rep 5,970
The main sign of a slipping clutch is the RPMs go up, but the speed doesn't change as much as it should. You usually notice it in higher gears. Eventually the speed catches up, or you reduce the throttle and the clutch will grab. If the clutch is slipping on a relatively fast car, it will be obvious that something is wrong. |
01-15-2009, 02:42 PM | #86 | |
Rep 475
///M 135i
01-15-2009, 03:14 PM | #87 | |
Rep 5,970
I've had them cool down and work normally for a long time afterwards (I've usually done this at the drag strip going for low 60' times), but you're taking some life off for sure. |
01-15-2009, 03:38 PM | #88 |
69
Rep 2,224
It's similar to how brakes "fade" after a lot of hard use.....but after they cool down they often work just as well again, although the hard use will take a toll on the longevity of the pads themselves.
- Joe Walsh |
