      05-22-2009, 06:35 PM   #1
oneintheory
no longer a BMW owner
Drives: 2011 Ford Edge Sport
&*@^% RD LEDs
So, I finally got my car back today...(yay) and decided to install the RD LED kit I got from kmarei.
After about an hour of fighting vainly with the passenger headlamp assembly cover, I gave up and fired the car up.
Excuse the language about to spew forth from my mouth, but i was not expecting a fucking bulb out code. I spend an hour and a goddamned half fighting with the insanity that is BMWs "user replaceable parts" vainly and then have a fucking bulb out. awesome.
just thought I'd share. thank you, BMW, for making life easy.
      05-22-2009, 07:19 PM   #2
Mega Man
エアーマンが倒せない
Mega Man's Avatar
Drives: 2009 135i
2009 135i  [0.00]
Have you given up for good, or just for now?
Be interested to see it if you decide to get back at it.
      05-22-2009, 10:05 PM   #3
kmarei
kmarei's Avatar
Egypt
273
Drives: 2015 Alfa Romeo 4C LE
were you doing it from the top cover??
i use a quarter and it works fine on the M3
it took me seriously about 5 min per side
just twist the oem bulb
pull it out
disconnect oem connector from bulb
connect the RD ballast
and twist the RD led in the socket
      05-22-2009, 10:12 PM   #4
oneintheory
you have more space than i do. it's not the same.
      05-22-2009, 10:22 PM   #5
kmarei
kmarei's Avatar
Egypt
273
i know they work for the 1 series
http://www.rdash.com.tw/en/product_d...ber=CE1102979W
i wonder if anyone has them installed that might be able to shed some light on how he got them in
so you did get one side in and it works but gives a bulb out warning?
      05-22-2009, 10:31 PM   #6
oneintheory
both sides are in...they both worked initially. now the passenger side doesn't, and I'm sure its something I fucked up, but I don't feel like cutting my hands up any more today.
      05-23-2009, 12:32 AM   #7
kmarei
kmarei's Avatar
Egypt
273
my only guess is one of the 2 plugs fell out
either the yellow and brown going to the ballast
or the red and black going to LED
if you are getting a bulb failure
then its probably the yellow brown
cuz thats where the resistor is to fool the car into thinking there is a bulb
if it was the one for the LED, you would not get a bulb failure
but the LED would not light up
      05-23-2009, 01:37 AM   #8
HACKULO
HACKULO's Avatar
26
Drives: E92 335i
2012 BMW 335i coupe  [0.00]
2008 135i  [3.00]
lol~~
i am agree w/ u ~~~
the cover so hard to remove and so hard to put back
      05-23-2009, 09:26 AM   #9
kmarei
kmarei's Avatar
Egypt
273
see if this helps
http://www.1addicts.com/forums/showthread.php?t=212882
      05-23-2009, 11:20 AM   #10
E92-Lighting
E92-Lighting's Avatar
Drives: Next Generation LED Lighting
its easier to install on 3 series than 1 series,
      05-23-2009, 03:33 PM   #11
oneintheory
Originally Posted by kmarei View Post
i know how I have to do it, i just haven't yet. will update later tonight when I have time.
      05-23-2009, 07:30 PM   #12
oneintheory
update...got the bulbs working, no codes, but I cannot, for the life of me, get that damned passenger headlight cover back on. sdkljfha;lsdjfdasf. i've tried everything suggested here. i'm about to take the damned bumper off to get at the headlight.
      05-24-2009, 02:59 PM   #13
oneintheory
goddamnitall.
got the cover back on, everything was great. until today. washed my car, turned it on...
adaptive headlights out. fucking a. the warning comes and goes. any ideas?
this is causing more trouble than it's worth.
      05-24-2009, 05:43 PM   #14
kingnonis
**1er Lover**
kingnonis's Avatar
Drives: my gf insane
I battled against the cover on passenger side for 2 hours the first time...decided to just leave it halfway on and f*k it... After a few days i gave in to the "worry" and after another hour and a hand full of cuts, I was finally able to get it back on... with someone holding a flashlight while u use both hands to just push the shit out of the tabs into the holes its only half as hard...yet still: WORST. INSTALL. EVER.
*'08 135i vert Jet Black/Coral Red*Premium + ///Msport + JB3 + BMS DCI* (retired )
*'11 135i dct Le Mans/Black
Premium + ///Msport + JB3 Stg.1 + BMW Perf. Exhaust + HPA Foam Filter
      05-24-2009, 07:11 PM   #15
oneintheory
little update....my headlight has fog and condensation in it...and both the adaptive system and the lamp itself are out.
this just keeps getting worse.
      05-24-2009, 08:55 PM   #16
kmarei
kmarei's Avatar
Egypt
273
My headlight had water in it too
replaced under warranty
bad news is
you have to out the oem bulbs in again
so they don't say it was due to the LEDs
