      08-26-2014, 02:36 PM   #155
scottn2retro
scottn2retro's Avatar
496
Drives:
Hi All - I'm at the point where we won't be towing the small track trailer anymore (haven't for some time), so I have a hitch and light control module available (and a small track trailer for that matter) in SoCal. PM me if interested. If in SoCal, you can see how I have the light box wired before I remove it.
2015 M4 BMW Club Racer
SCTS Racing
https://www.facebook.com/sctsraceteam/
      05-12-2015, 08:08 AM   #156
AnthemX
Drives: 2011 335i xDrive M Sport
I'm about to install my curt 11184 hitch on my 2011 135 M-Sport and I'm a bit perplexed with the install instructions. Curt says only the bottom fascia of the bumper need to be removed yet every example on this thread shows bumper cover and lights removed. Am I missing something here? Has Curt revised this hitch in someway?
Here is the PDF instructions.
      05-12-2015, 08:16 AM   #157
igzekyativ
Drives: 2007 BMW 328xi Wagon
2007 BMW 328xi  [0.00]
Everytime I installed it I removed the bumper. I do think you can install it by only removing the diffuser, but space would be tight. Basically, you can do it either way. Give the diffuser route a try and if it doesn't work out, just take the whole bumper off.
2007 328xi Wagon, Black Sapphire Metallic, Sports Package, Cold Weather Package, Rear PDC, Airlift kit with 3P mgmt, CF Akrym rep lip, LCI M-Tech front bumper, LUX Angel Eyes, Black Kidneys, LED Interior Lights, M3 Steering Wheel with Extended Billet DCT Paddles, 19" Staggered VMR 710's
      05-12-2015, 12:43 PM   #158
AnthemX
Thanks for the reply. Sure enough, the hitch can can be installed with only diffuser removed. Took me all of 15 minutes to bolt it up. Didn't even have to drop the muffler as described in the curt install instructions. I'm going to see if can have the hitch modified so it's not visible. Either move the receiver back or go with a vertical setup.
      05-13-2015, 10:37 PM   #159
scottn2retro
496
Drives:
Is anybody SoCal looking for a complete setup? Hitch, light controller, trailer? I ready to get rid of my complete setup that I used to go to Road Atlanta a few years ago.
SCTS Racing
      05-14-2015, 08:48 AM   #160
spain4065
Drives: EM1 and 08 135i
Interested in light module, what did you use and any light errors?
      05-15-2015, 06:29 AM   #161
Rock1965
Drives: 2011 135i M Sport Conv
Ditto. Same here. I did mine with only removing the diffuser and no mod to the muffler as well. Quick install however the top bolts were a little difficult to tighten which took the most time.
http://www.1addicts.com/forums/showthread.php?t=1087950
      05-27-2015, 02:06 PM   #162
dannypwr
Drives: 135i Vert
about 40 minutes
Hey guys so i went and installed the hitch by etrailers aswell. Was pretty simple , no removal of bumber ,just the "diffuser". Just need extra hand to hold it up before the 1st nut is installed.
      07-15-2015, 04:41 AM   #163
ChiBimmer
Drives: 2010 135i 6MT Sold
What is safe tow capacity? I'm interested in getting a small travel trailer like a teardrop or popup. Some of these are around 1000 lbs.
      07-25-2015, 01:59 PM   #164
AnShk
Drives: E70 X5 35d
I did from east coast to west and back last year with 4x8 uhaul trailers full of home furniture and it was totally ok!
Have a look in a manual which model you have.
Driving is even better with a trailer. Not acceleration, but cornering.
Cruising is also OK! I enjoyed it way more as compared to audi a4 I used to drive in germany.
      07-25-2015, 02:03 PM   #165
AnShk
Drives: E70 X5 35d
if you still did not buy yet, I can let you know.
No errors.
      07-25-2015, 02:06 PM   #166
AnShk
Drives: E70 X5 35d
http://www.etrailer.com/Custom-Fit-V...id=20101170141
      08-27-2015, 12:02 PM   #167
ETADRAFT
ETADRAFT's Avatar
Drives: 2012-135i-white/coral/M
I'm looking into a hitch and this post has been very helpful BUT seems no one makes a hitch for a 2012 135i... I contacted Etrailer and they confirmed with Curt that they only fit up to 2011. I cant imagine BMW would of changed the bolt pattern on the car. Anyone ever try to put a hitch on a 2012?
2012 - 135i - White/Coral - BMS stg2, BMS intake, BMS catless DP, BMS meth, CP-e charge pipe, KW clubsports, M3 suspension bits, BRR rollbar, MOMO FIA seats, 18" APEX EC7 wheels 18x10.5 square, UUC short shifter, Stoptech BBK, ER wide front, N5tuner rear, ER dual oil cooler, CSF radiator, PS2, BMP PI, BoostConcepts LPFP upgrade.
      08-27-2015, 12:05 PM   #168
igzekyativ
I don't have an answer for you (my 1er was an '09) but I do still have a trailer hitch wiring kit for sale, so if you are interested let me know.
      09-02-2015, 06:38 AM   #169
ETADRAFT
ETADRAFT's Avatar
For anyone with a 2012+ the Curt hitch does fit! The only "modification" you will need to make is to one of the exhaust brackets. I just bent the gussets on the support back with a hammer. [IMG][/IMG]
      04-06-2016, 02:37 PM   #170
desertfox85
Drives: 2012 128i
I have a 2012 128i, installed the 2011 135i version of the hitch. Fits fine, no issues.
      04-11-2016, 09:37 AM   #171
Trenchdigger
Drives: 128i Coupe, VW MK6 GTI
DesertFox: Thank you for this ... I want to install a hitch on a 2013 128.
Do you have a part number for the hitch you used? Is it: Curt #11184
Thank you!
      04-11-2016, 01:19 PM   #172
odj
Drives: '13 135is + six other cars
Can anyone confirm that they've been successful in wiring in a trailer light adapter to an LCI tail car?
I've found both of these adapters:
OEM (includes the OEM retrofit module): http://bmwfans.info/parts-catalog/71...ined_undefined
Aftermarket: http://www.etrailer.com/Custom-Fit-V...id=20101170141
Thanks!
      04-12-2016, 07:12 AM   #173
spain4065
I used that aftermarket wiring kit on my 08 135i. No issues at all.
      04-19-2016, 01:34 PM   #174
Trenchdigger
Thank you!
Update: Yes, it is Curt #11184
I installed it on Sunday. Fits great, no issues on a 2013 128i. I'm using it for a bike rack; plenty of clearance.
Note: I did NOT remove the bumper cover to install. However, it would have been much easier if I had.
      05-05-2016, 12:58 AM   #175
tonyb.ca
Drives: M3/E93
Hi All,
I have read a lot of the posts here but may have missed something. Towing a small trailed with less than 200 lbs tongue weight shouldn't be a issue, but how well will it handle a bike rack. They talk about adding straps, which is what I am trying to avoid.
Does anyone have thoughts or experiences on this? I have a Thule 1 in. receiver mounted rack for ~ 3 bikes, although I'll never carry more than 1.
TIA
      05-05-2016, 02:14 AM   #176
The Wind Breezes
Drives: 135i N55 DCT
Originally Posted by tonyb.ca View Post
Hi All,
bikes
TIA
You will be fine with a hitch mounted bike rack loaded with as many bikes as it can hold.
