      01-17-2011, 06:22 PM   #199
WOPALX
WOPALX's Avatar
Drives: 335i Sedan
Originally Posted by Alext View Post
Hey Adrian does the Professional version come with the necessary cable so you can hook it up to your laptop?
Also can you pre-load software (like the latest N54 Z4 DCT transmission fix & a lower boost 'stock' secondary map) into the V5 before delivery so I won't have to worry about it?
Alex,
Spoke with Adrian yesterday and he's a tad pre-disposed @ home at present.
You need to purchase a USB to serial adaptor (unless your laptop has a serial port). They are about $20 from Dick Smith's etc.
Normally Adrian will load the current maps before shipping, you can leave them as is or tailor them to your liking using the software that links the tune to your laptop.
Cheers,
S
Vishnu PROcede V5 | VK Motorworks FMIC | AR Design OCC | Forge DV's | Bilstein PSS9 | M3 Lower Control Arms & Caster Rods | Quaife LSD | HiTech Exhaust | BMW Performance Illuminated Door Sills | BMW Performance Gear Selector & Boot | BMW Performance E-Brake Cover
      01-17-2011, 06:54 PM   #200
Alext
Drives: B M W
Hi WOPALX, thanks for asking Adrian for me. That sounds great. I am going to wait until they finish the DCT map - I think it is still in Beta.
      01-17-2011, 07:06 PM   #201
adrian@vishnu
Hi All,
Thanks Stuart for handling this for me mate. As Stuart stated, I am going through some difficult personal things at the moment, so I may take little longer than normal to respond. I have not been keeping a close eye on the forums, but email me or PM me (which send me an email) and I will get to it quickly.... just not much time for browsing at the moment.
The Procede does not come with a USB-Serial cable. Some laptops have a serial port built in and do not need one. For those without, you can purchase one from a computer store cheaply... or off ebay for a few $$$. The majority of my customers already have one for other things. Also, I can preload the latest maps (and usually do by default). Normally I use the latest release maps, but I can load the betas by request as long as I think they make sense for you (some betas are released specifically to test an aspect for beta testers, and may not make sense for normal use).
Justin, I will email you shortly.
Andrew, I will call you shortly.
Thanks guys for understanding, and sorry if I am not as prompt as usual.
Cheers,
Adrian
      01-17-2011, 07:07 PM   #202
MikeVictor
Drives: anything given a chance
Would a bluetooth OBD key be suitable as an alternative? I use one to connect my car to my Torque app rather than snake a cable around. Most modern laptops will have an inbuilt BT transceiver.
      01-17-2011, 07:19 PM   #203
WOPALX
WOPALX's Avatar
Drives: 335i Sedan
Matty some people have tried / accomplished this in the past. If you do a search you might find some other information. Not sure if it works or not.
There are also DIY's for feeding the USB cable through the air vent in the ECU box to the glove box. As there is heaps of space in the ECU box you can leave the adapter connected 100% of the time without issue.
As I'm lazy what I have done is just snake the USB port from the procede harness out of the ECU lid so it sits outside of the ECU box while still allowing the lid to seal. I then just plug in the adapter when needed and run the cable through the passenger side door. Has worked fine that way for the past 3.5 years so figure no point in routing it any other way.
      01-17-2011, 07:20 PM   #204
adrian@vishnu
BT has been done before by some of our customers. It works, but we cannot provide support for it since we are not experts in that area, but I am sure some forum members would be able to help.
To be honest, there is little need to connect to a laptop unless performing the updates. Most people connect a laptop once or twice a year or never. In these instances, it is easiest just to connect the cable under the bonnet and then through the window to the passenger seat... there is no need to snake a cable around permanently. Most things you might want to fiddle with are available from the dash control now.
Cheers,
Adrian
      01-20-2011, 09:12 PM   #205
Unkie
Unkie's Avatar
Drives: BMW
Is the AutoTune on the Procede able to accomodate and adjust to E85 fuel available here?
I'm not sure what the upper limits of the stock HPFP or injectors are so will also need to look into that
      01-20-2011, 09:46 PM   #206
Jeef Beef
Lord Captain Commander
Jeef Beef's Avatar
Drives: a sleeper
I didn't think the internal components of the N54 were capable of running on flex fuel
E82 135i M-sport: SGM/6MT/Black
      01-20-2011, 10:00 PM   #207
MikeVictor
Wouldn't put that fuel anywhere near my car in the first place. PULP or nothing.
      01-21-2011, 02:29 AM   #208
adrian@vishnu
No the Procede does not support E85, and the concensus seems to be that the fuel pump in the N54 would not like it.
I personally run E85 in my WRX race car. It is a great fuel for performance, but not for the N54.
Cheers,
Adrian
      01-23-2011, 07:36 PM   #209
Unkie
Unkie's Avatar
Drives: BMW
Thanks guys for clarifying on the E85! I suspected that with the US HPFP issues the stock unit wouldn't suffice (and would be tough finding higher capacity direct injectors...)
Oh well, shelf that idea for now
      08-22-2011, 09:16 PM   #210
adrian@vishnu
Price updates. Please see first post for details, but I have copied the pricing here:
* N54 Procede Professional version - $1050 inc GST and delivery OR install.
* N55 Procede Professional version - $1050 inc GST and delivery OR install.
* PWM Meth Kit (requires charge pipe) - $900 inc GST and delivery.
* Vishnu Charge Pipe (for meth kit) - $375 inc GST and delivery.
* Dual Cone Intake - $175 inc GST and delivery.
Cheers,
Adrian
      08-22-2011, 09:41 PM   #211
Liub
Drives: E8
Hi Adrian, where can I find a bit more info for the PWM meth kit n charge pipe? Photos etc.
Cheers.
      08-22-2011, 09:48 PM   #212
Unkie
Unkie's Avatar
Drives: BMW
Awesome. Do you have the meth kits in stock Adrian? Or is there a lead time out of the US?
      08-22-2011, 10:03 PM   #213
adrian@vishnu
Thanks for your interest guys.
Full photos and information on the PWM meth kit is available here:
http://procedetuning.com/BMW/n54/methanol/methanol.html
Unfortunately I have not got stock currently, but if there is enough interest, I would carry stock. Typically Australians are less keen to go the meth path than our US counterparts as we are not as used to do dealing with it, where it is commonly used on lots of different cars in the states, so they are more comfortable with it. Currently I can get stock in about 2-3 weeks depending on how US stock levels are. The system has been very popular in the states, so we have mostly been catching up on preorders, but I think we are getting on top of that now, so stock should be available to me more quickly.
Cheers,
Adrian
      08-22-2011, 11:54 PM   #214
Liub
Drives: E8
Hmm so the meth kid and charge pipe are for N54 only?
      08-23-2011, 12:08 AM   #215
adrian@vishnu
Watch this space!!
We have PWM meth running on our shop car N55. It is just a matter of time for us to modify our N55 charge pipe to suit the PWM meth kit. I would say it is a matter of weeks. We already have a charge pipe for our previous generation meth kit for N55, so we just need to update that and release the firmware we are using internally with PWM meth support (along with a bunch of other things that are ported across from the N54). Price should be the same as N54.
Cheers,
Adrian
      08-23-2011, 12:10 AM   #216
Liub
Drives: E8
Originally Posted by adrian@vishnu View Post
Watch this space!!
Cheers,
Adrian
Sweet, let me/Andrew know when you do .
      08-23-2011, 12:15 AM   #217
adrian@vishnu
Will do!!
      08-23-2011, 12:47 AM   #218
Stuart@BMRAutowerkes
Stuart@BMRAutowerkes's Avatar
423
Drives: a black car
any idea of whether the meth kit will work with an ER CP?
      08-23-2011, 01:47 AM   #219
adrian@vishnu
It can. It is just not as straight forward. You just need to hook up the hobs switch separately. No big deal.
      08-23-2011, 04:31 AM   #220
MrBlonde
MrBlonde's Avatar
Drives: E70 X5, Audi S3, M Coupe, 1299
I have an ER charge pipe
Check out the 1Addicts Drag Racing Standings and Drag Racing 101.
procede, vishnu
