10-14-2009, 08:39 PM | #1 |
23
Rep 194
BRracing e82 rear harness & strut bar
BRracing introduces it's new rear strut tower bar/brace, and harness bar with integrated down bars and x-brace.
With all of our recent track work and track testing, and prior work on our E46 M3 and MINI MCS, we both need and realized the need for an integrated harness bar and strut tower brace. But....this is our daily driver, and we wanted the solution to meet all possible customer needs for a combination daily driver and track car (not race car...track car mind you). To that end, the requirements for the daily driver are that the bar needed to allow for the continued use of rear seats all the time when we're not at the track, and to not interfere in any way for the rear seat passengers. We also needed the complete solution to be "bolt in", so that no new holes or attachment points are needed at any location. We wanted to use the strongest mounting locations to provide for the strength and rigidity, but not throw out the other requirements. We wanted the rear shock tower brace to both work for the harness bar attachment, strength, and torsional rigidity, but not interfere with the use of the trunk. We needed the rear down bars and x-brace to be easy to remove, but very strong, and easy to install. We wanted the look to look factory in all ways, including the clearances to the roof liner and side B-pillars. And...we think we have it. This approach allows for the implementation in multiple configurations and upgrades. You can start with just the rear strut tower brace only. You can then add the complete harness bar. You can run with just the main hoop and rear strut tower brace, and then, when going to the track, pop in the down bars/x-brace, and also the main harness cross bar. We even added a little set of extras, like integrated attachment points for the lower harness connections on each side. The main bar has a massive plate on the bottom, and uses both the side seat belt mount hole in the side rail, and the hole in the bottom floor pan that is over 4" away from the side rail, and in this manner, provide the strength required....plus the base plate is so thick, that you would have to crush the whole car to get the hoop to crush thru the floor pan. The rear strut brace uses two existing rear bulkhead mounts, that have already been strongly reinforced by BMW in the car, for the main attachment points. Again, no new holes, but incredibly strong attachment points. Plus, the rear strut bar sits so low, and forward in the trunk, that the complete trunk area is still usable, and you can even stow your skis and other things w the seats down. We even made sure visibility from the front seat is unobstructed thru the rear x-brace. Testing...we've only done the first set of tests, but we can attest that the whole assembly does significantly add to the torsional rigidity of the complet e car, as we almost couldn't get into a steep driveway that we've driven into before, as the car lifts that much now due to the stiffness. You can get the bar(s) in almost any powder coat color you want, and not have to pay a fortune to get the whole thing. And, for those that want to know, the whole solution is made of the following - 1.5" x .095 4140 chrom moly tubing chrom moly clevis mounts Grade 8 and above metric hardware Full TIG welding on all attachment points (tolerances are tight, welds are beautiful) Pricing is as follows - Rear strut bar only (in any powder coat color) - $300 Complete rear strut bar and harness bar assembly - $1,499 (if you want this, just be prepared to sign a bunch of disclaimers for insurance liability reasons) Last edited by brracing; 01-31-2013 at 10:56 AM.. |
10-14-2009, 08:50 PM | #2 |
Rep 1,262
That's some fantastic looking work! If my car was anything more than a street car and I didn't require the rear seat for passengers every so often, I'd definitely be considering this.
Nice to see stuff like this becoming available for the 1er!
10-15-2009, 10:11 AM | #4 |
23
Rep 194
Just so its clear....the implementation of the rear strut bar/harness bar DOES allow for continued use of the rear seats. This was one of the main objectives of the implementation and design.
The main hoop is designed to not interfere in any way to the access/egress to and from the rear seat. The rear strut bar is behind the rear seats, and does not interfere w the rear seats being up or down, or being used on a daily basis. The downbars/x-brace and main hoop cross brace just bolt in and pop out, so that you can have the full system in place when you want, or have them out in a snap when you use the car and need the full use of the rear seats. Even the base plates, attachment points, have been designed such as to not interfere in any way. |
10-15-2009, 11:05 AM | #5 |
drk one
38
Rep 797
Drives: 2008 135i
SOO damn cool. I'm putting this on my suspension wish list for sure!
I'm curious what other connection points to the interior of the car are made with this product
Jet Black | Coral | HighGlossBlack | Steptronic | Premium | Sport | Comfort | ActiveSteering | Navi | HiFi | HD | iPod | SAT
BMS JB3 v2.0 | BMS DCI | Berk Tech Sport Exhaust | UR * DPs | CoolingMist Meth Kit w/ CMGS | H&R OE Sport Springs | Breyton GTS-R | Dunlop Direzza Sport Z1 Star Specs | GP Thunder 8000K Low Beams/Angel Eyes/Cornering Lights | LED Interior Light Kit | Window Tint | Smoked Tail Lights | Smoked License Plate Cover |
10-15-2009, 11:28 AM | #7 |
Rep 420
Drives: E36 M3 3.2 (321hp)
Great! May want to order this when im done with the rest on my car.
120d, M-sport, H&R springs,Remus Exhaust, 135I kidneys, 18"BMW performance with Toyo T1R.(summer) 17" style 207 with Michelin Xice(winter), 17" M3 replica with Toyo R888 (Track), Hardwired H/K GPS 810. SOLD! Now driving E36 M3 3.2 (321Hp)
Track and Autox |
10-15-2009, 03:39 PM | #8 |
23
Rep 194
If you guys want put together a list of people interested in ordering this, I may be willing to drop the price a bit for a introductory offer to the 1 addicts members.
Let me know what you would like to do. Appreciate the kind words and support, let us know if you have any questions. Robb Co-Owner |
10-15-2009, 11:39 PM | #9 |
Rep 189
Robb, how much added rigidity does the rear strut bar alone generate? And would you consider selling the rear strut bar without the two tabs used to attach the rest of the cage? I'm reaching for my wallet....
10-15-2009, 11:59 PM | #10 |
23
Rep 194
Can sell with or without the tabs for the rear shock tower brace.
Understand that the bar attaches to two mounting points on the bulkhead behind the rear seats. When we pulled the carpet out to investigate possible connection points, that would offer the strength and rigidity we wanted, we were shocked to find two mounting points that BMW designed into the bulkhead, with existing bolts thru them. So, we just leveraged what was already there. Now, also understand, that the shock tower brace does NOT directly attach to the shock tower, but is adjacent to it....as we did not see an easy way to preserve the interior carpet, attach to the shock tower (the top of the shock is actually in a recessed hole, and no longer offers the old attachment points like for an RSM). We're here to make solutions that work...we can even make the center bar out of other material if desired....like polished aluminum (just would change the price) send us a PM if you need or want more specifics |
10-16-2009, 06:19 PM | #11 |
Rep 2,033
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
Very nice. Looks like I've found what I need when I'm ready for a rear strut bar!
10-16-2009, 08:32 PM | #12 |
23
Rep 194
Question relative to the rigidity....don't know yet other than seat of the pants results.
We will be going to the track either on October 26 or in early Nov, and will be installing "strain gauges" both w the system in the car, and w it removed, to see what kind of data we really get to change or impact torsional rigidity in the car....stay tuned for that info. |
10-17-2009, 08:43 AM | #13 |
Rep 1,376
Drives: 1988 M3, 1990 M3, 1998 M3/4
Garage List 1998 BMW M3/4 [10.00]
2011 BMW M3 Sedan [9.28] 1988 BMW M3 [9.40] 1990 BMW M3 [10.00] 2008 BMW 135i - sold [0.00] 2003 BMW M3 - sold [0.00] |
In your other thread you have shown the mounting of the hoop. Could you show us a picture of the mounting point of the shock tower bar?
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black 1998 BMW M3 - Alpine White/Mulberry 2011 BMW 328i racecar - LeMans Blue/Black |
10-18-2009, 12:14 AM | #15 |
23
Rep 194
Not sure I can post pricing ....if OK, someone let me know, happy to post prices.
Will shoot some pics of the rear shock mount attachment, so that it is clear to everyone. We have a HUGE show tomorrow at our shop in Los Gatos CA, so the car, along w a lot of others, will get displayed, then will shoot the pics and post, as this is unique or new approach, and would welcome the feedback. |
10-21-2009, 01:51 PM | #18 |
23
Rep 194
Just posting a update for you guys.
We will have brakes coming in about two weeks... Also we are making some changes to the harness bar to accommodate seat adjustment. Look for some new added images to come out soon. Thanks |
03-06-2010, 03:46 PM | #19 |
Rep 510
Hiya,
Any updates on the rear strut brace? I might be interested in the rear strut tower bar alone without the tabs. Would I notice any difference at all in the handling? Could I have it in black and shipped to the UK? Perhaps PM me with a price etc. Thanks Jack |
03-13-2010, 09:24 AM | #20 |
Rep 189
I asked Robb the same question a few days ago. Yes you can get the lower rear tower brace as a single unit, without tabs, powder coated in black for $300. As for adding stiffness, Robb did not have any empirical evidence but claimed a perceived improvement.
03-14-2010, 01:50 PM | #21 |
satch
39
Rep 1,040
Anyone taking orders for the rear strut brace? Was talk of a group buy - anything hapening? Went and saw Alice In Wonderland last night in a 3D Imax. Was kind of looking for you guys down the hole. Hope you had enough food for your 5 month dissapearance....
