      10-27-2009, 06:30 PM   #1
modbargains
modbargains's Avatar
86
Drives: 08 E90 335i & 01 Toyota Avalon
**********s| FORGESTAR 18" FINALLY RELEASING INFORMATION!!! 17lb 18" Track Wheel!
**********s.com is proud to introduce the Forgestar F14 Wheel in 18" fitments Available NOW!
Some of you heard the rumors and they are finally here and available. Over the next few days we'll be bringing you actual images on vehicles and hope to get you reviews of customers using it on the track. These are the same wheels we've gotten over to KW for their race car.
The 18" Forgestar F14s weighed in at an amazing light 17.6 Lbs . for the 18x8.5. These wheels are perfect for anyone who drives there vehicle on the street, but also takes there car to the track or autocross. Just like the 19" F14s the 18" allow for custom offsets so that you can decide exactly how you want the wheels to sit and look.
Whether you simply daily drive your BMW or only take it to track days, you can't go wrong with the Forgestar 18" F14s.
[IMG]http://www.**********s.com/images/Products/Forgestar%20Wheels/1885weights.jpg[/IMG]
Available Sizes
  • 18x8.5 offsets from +26 to +50
  • 18x9.0 offsets from +20 to +55
  • 18x9.5 offsets from +26 to +60
  • 18x10.0 offsets from +16 to +42
  • 18x11.0 offsets from +23 to +55
  • 18x12.0 offsets from +36 to +68
Weights
  • 18x8.5 ET48 - 17.6 Lbs.
  • 18x9.5 ET48 - 18.4 Lbs.
  • 18x10 ET42 - 18.2 Lbs.
  • 18x12 ET68 - 20.0 Lbs.
Why Forgestar Wheels are Better Than Cast Wheels
  • Custom Offsets - Forgestar wheels can be made in virtually any offset, whereas standard cast wheels come in a set offset. This allows you to dial in exactly how you want your wheels to sit (we can help you select the offset you need for the look your looking for). Having custom offsets allows for fitment of wider wheels in stock suspension and lowered vehicles. Forgestar wheels are designed specifically for your car and it's suspension setup, where cast wheels are designed for everyone and typically do not take in to account lowered suspension setups.
  • Weight - Forgestar wheels are also much lighter than cast wheels. The 18x8.5 F14 wheel weighs an amazingly light 17.6 lbs, where a cast wheel of this same size would weigh anywhere from 23-27 lbs. This saving of roughly 6-10 pounds per wheel makes a BIG difference in regards to handling and drivability. Reducing unsprung weight (weight that is not supported by the car's suspension, i.e wheels, tires, brake rotors, and brake calipers) is one of the easiest ways to improve your car's handling, braking, and acceleration. As a general estimate 1 pound of unsprung weight is equal to 10 pounds of static weight. (weight that is supported by the vehicle's suspension). By using this ratio if you were to replace your stock wheels that weighed 25 lbs with Forgestar wheels you would be saving 320 lbs. in static weight!
  • Strength - Flow-formed wheels are similar in strength to that of a fully forged wheel, without the cost. The process used to make the Forgestar wheels is the same process BBS wheels uses as well. Forgestar wheels are also rated at 1200 lbs per wheel which is considerably more than a cast wheels which are typically around 1000-1200 lbs. per wheel.
  • Range of Sizes - Forgestar wheels are available in a multitude of sizes, allowing you to decide exactly what diameter and width you want to run on your vehicle, rather being forced to run a set staggered size with cast wheels (As cast wheels usually are only available with one set front wheel width, and one rear wheel width).
Following images are on 19", will populate the thread with images of the 18"
[IMG]http://www.**********s.com/images/Products/Forgestar%20Wheels/f14_E90_335_5.jpg[/IMG]
[IMG]http://www.**********s.com/images/Products/Forgestar%20Wheels/a5black1.jpg[/IMG]
[IMG]http://www.**********s.com/images/Products/Forgestar%20Wheels/E90M3_Titanium3.jpg[/IMG]
**********s has exclusivity on Forgestar F14 in 18" for all BMW fitments. We are accepting applications for wholesale dealers please contact us if you are interested.
Please feel free to give me a call at (714) 582-3330 ext 8009 or E-Mail me at Kevin************.com if you have any questions.
      10-27-2009, 07:09 PM   #2
e82vette
Drives: 128i
pm me for price please... 18"
      10-27-2009, 08:11 PM   #3
jlee
jlee's Avatar
Drives: 2014 M5 Comp + 2008 M3 Vert
PM me a price on 18x8.5 and 18x9 setup ..
Thanks
Jeff
      10-27-2009, 09:53 PM   #4
akak1997
akak1997's Avatar
33
Drives: BMW 135 @ 135mph
2008 135i  [0.00]
Awesome, finally some Forgestar 18" for 1er.
What kind of offset would I need if I want to run 255 square setup?
      10-27-2009, 10:22 PM   #5
wolfson.tyler
wolfson.tyler's Avatar
Drives:
those look great please pm prices I wanna get some wide ones !
      10-28-2009, 09:25 AM   #6
zzz36
Drives: lexus
Can I get a PM on some 18 please. I'm running H&R sport springs. So what is the widest I can fit staggered of course without rubbing and rolling my fender.
thanks.
      10-28-2009, 12:50 PM   #7
tjockey
Drives:
What F&R offsets would work for 265X35 and 235X40 tires on 1.5" Coil-over height reductions with 9.5" R and 8.5" F widths
      10-28-2009, 01:05 PM   #8
Dave
formerly izzo/comeback
Dave's Avatar
Drives: 2016 RC 350 F Sport
2008 135i  [3.40]
pm me price for 18inch
BMW CCA # 418268
Still tracking my brothers 335i financial stage 2 (in my dreams)
      10-28-2009, 01:20 PM   #9
modbargains
86
Hey Guys,
All PM's have been replied to. For those of you out there who want to see WIDE, I'll show you WIDE !!!
[IMG]http://www.**********s.com/images/Products/Forgestar%20Wheels/comparison%20copy.jpg[/IMG]
Let us know if you have any questions!
Kevin
      10-28-2009, 01:24 PM   #10
BrokenVert
Resident Kerbalnaut
BrokenVert's Avatar
PM me an 8.5/9.5 setup please.
      10-28-2009, 03:09 PM   #11
xG35guy
xG35guy's Avatar
Drives: 2016 M4
Thx
2016 BMW M4 - Vorsteiner | Michelin MPSS | Dinan | Swift | M Performance Carbon Everything (Garage Queen)
2016 VW GTI - Unitronic Stage 1 Tune | AWE Track Edition Exhaust (Daily Driver)
      10-29-2009, 01:13 PM   #12
modbargains
86
All PM's replied to
Here are the Available Finishes!!!
Available Finishes:
  • Gunmetal
  • Piano Black
  • Matte Black
  • Piano Black
  • Brushed with Black Windows
  • Titanium
  • Hyper Silver
[IMG]http://www.**********s.com/zoom_img/Forgestar18_F14BMW_KM4_1236698036.jpg[/IMG]
[IMG]http://www.**********s.com/zoom_img/Forgestar18_F14BMW_KM4_1236698051.jpg[/IMG]
[IMG]http://www.**********s.com/zoom_img/Forgestar18_F14BMW_KM4_1236698093.jpg[/IMG]
[IMG]http://www.**********s.com/zoom_img/Forgestar18_F14BMW_KM4_1236698137.jpg[/IMG]
[IMG]http://www.**********s.com/zoom_img/Forgestar18_F14BMW_KM4_1241178894.jpg[/IMG]
Kevin
      10-29-2009, 02:25 PM   #13
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [5.00]
Send a message via Yahoo to adrean8j
Siiiiiiick...pm pricing for 8.5 all the way around
SGM was God's color and has been recalled to heaven.
      10-29-2009, 05:54 PM   #14
randomquickness
Drives: 996tt
please pm price for 8.5/9.5
      11-02-2009, 09:44 PM   #15
randomquickness
Drives: 996tt
gonna put that widebody to use huh? Congrats!
      11-05-2009, 01:34 PM   #16
Formel1
Formel1's Avatar
23
Drives: 2009 BMW 135i
+1 on that request...
      11-05-2009, 10:14 PM   #17
Rearro
Rearro's Avatar
Drives: Bmw 135I
Could you pm me the price if I wanted to keep Stock Sizes?
Thanks in Advance!
2008 135i,Dinan Stage 2,Dinan Free flow exhaust.
      11-05-2009, 10:28 PM   #18
rcracer_tx
Drives: BSM 135i
Thanks in Advance!
PM sent!
      11-06-2009, 11:51 AM   #19
kirby135i
Drives: bmw
which would look best for Space Grey? thinking either Titanium or Piano Black?
      11-06-2009, 12:01 PM   #20
woodman650
Super Couper
woodman650's Avatar
Drives: TBD
Please PM price for 8.5/9.5 set up
      11-07-2009, 04:51 PM   #21
rcracer_tx
Drives: BSM 135i
I think titanium would look the best, blacks a little played out IMHO
      11-07-2009, 11:06 PM   #22
BBK
Drives: A boring one...
2009 BMW 135i  [2.88]
PM for price on the 8.5/9.5 setup please :-)
