Reply
      01-11-2010, 11:44 AM   #1
Mark
Administrator
Mark's Avatar
Drives: 1M
Exclamation Officially announced changes to the 135i for 2011 (+ wallpapers)
BIMMERPOST NEWS
152
COMMENTS
Changes to the 1-Series in 2011 confirm what has been widely speculated:
  • Engine change to the new TwinScroll Single Turbo 6-cylinder engine (N55)
  • 300HP @ 5800
  • 300lb-ft @ 1200-5000
  • Now with Valvetronic
  • New 7-Speed DCT is now optional
  • Optional Harmon Kardon sound system now available
Discussion on the topic of the N54 being broadly replaced by the N55 and the inclusion of DCT has been going on in the following threads:
http://www.1addicts.com/forums/showthread.php?t=339016
http://www.e90post.com/forums/showthread.php?t=338908
http://www.1addicts.com/forums/showthread.php?t=337295
PRESS RELEASE + Expand
Woodcliff Lake, NJ – January 11, 2010… BMW's EfficientDynamics philosophy continues with the 2011 135i Coupe and Convertible models which feature the company’s latest twin-scroll turbocharged 3.0-liter inline six cylinder engine. Both models will feature the 7-speed Double-Clutch Transmission (DCT) as an option.
The new six-cylinder (N55 designation) develops maximum output of 300 hp at 5,800 rpm, with peak torque of 300 lb-ft available all the way from 1,200–5,000 rpm. This is the same level of performance as the current 3.0-liter twin-turbo six-cylinder but with the innovation of twin-scroll technology and the integration of VALVETRONIC throttle-less intake technology, this new engine promises even better throttle response and even more fuel efficiency. Thanks to VALVETRONIC, VANOS, and the twin-scroll turbocharger housing, peak torque is reached 100rpm earlier than with the previous engine, and engine boost response is improved across the entire engine speed range.
In order to enhance the sporting character of the optional 7-speed Double-Clutch Transmission, the shift paddles now feature dedicated paddles for upshifting and down shifting. The driver now pulls the right paddle for upshifts and the left for down shifts. Manual shifts may also be accomplished via the console mounted e-shifter.
Harman Kardon Surround Sound System replaces HiFi System Professional as the upgrade sound system option.
The 2011 BMW 135i Coupe and Convertible will go on sale in the United States as 2011 models in Spring 2010.
Pricing
Full invoice and msrp pricing for the 2011 1-series -- http://www.1addicts.com/forums/showthread.php?t=347072
135i Coupe and Convertible Wallpapers
135i Coupe Montego Blue
135i Coupe Alpine White
Interior
Share this story
The new beast. BMW M5.
Mark is offline   United_States
      01-11-2010, 12:08 PM   #2
Lloyd
Networking Geek
Lloyd's Avatar
Drives: 10000111
Send a message via AIM to Lloyd
i still <3 my 2010
Lloyd is offline   United_States
      01-11-2010, 12:14 PM   #3
DaveSakky135
Drives: 135i Montego Blue
is the DCT and SMG found i the M cars the same thing?
DaveSakky135 is offline   United_States
      01-11-2010, 12:20 PM   #4
atr_hugo
No longer moderate
atr_hugo's Avatar
Drives: SWB 335i
No SMG and DCT are different animals, the SMG was a single shaft, single clutch, electronic clutch engagement gearbox. The DCT is a twin concentric shaft, dual clutch, electronic clutch engagement gearbox. The DCT will appear to shift more smoothly than the SMG for folks who are used to automatics. (The trick to making an SMG feel smooth is to lift throttle a bit between shifts.)
atr_hugo is offline   No_Country
      01-11-2010, 12:22 PM   #5
ChrisK
ChrisK's Avatar
Drives: 2011 E92 M3
SMG was a pain!
ChrisK is offline   United_States
      01-11-2010, 12:23 PM   #6
oasis3582
oasis3582's Avatar
Damn, the HK sound system sounds more interesting to me than the powertrain changes. Is that odd?
Current: BMW 135i cpe BSM / blk/gray / sport / prem / ipod
Previous: 2008 Honda Accord Coupe, 2007 Acura RDX, 2005 Pontiac GTO, 2004 Pontiac Grand Prix GTP
oasis3582 is offline   Reply With Quote
      01-11-2010, 12:30 PM   #7
Spartikus
Spartikus's Avatar
Drives: Twin-Turbos
I cant wait to feel the drive an N55 powered 1er. I'm wondering if I'll be able to tell a diff from the seat of my pants. One would assume its underrated as well.
Spartikus is offline   Reply With Quote
      01-11-2010, 12:30 PM   #8
Ajumepke
Drives: None
I hope N55 doesn't have HPFP issues /cross fingers
Ajumepke is offline   Reply With Quote
      01-11-2010, 12:34 PM   #9
ChrisK
ChrisK's Avatar
Drives: 2011 E92 M3
I am PO'd since I was under the impression that the upgraded sound system in the 1er IS Harmon Kardon.
      01-11-2010, 12:34 PM   #10
ChrisK
ChrisK's Avatar
Drives: 2011 E92 M3
+1
      01-11-2010, 12:39 PM   #11
escobar929
escobar929's Avatar
2010 135i  [3.50]
interesting how the N55 will compare to the N54
escobar929 is offline   Reply With Quote
      01-11-2010, 12:41 PM   #12
DBFIU
Crack Addict
DBFIU's Avatar
Drives: Fast
Send a message via AIM to DBFIU
I wonder what type of turbo they will use, whether it be mitsubishi or something else. Not that I have anything against our turbos, i think theyre great for what we put through them with chips and all.
Just curious if they use the same 'low inertia' design as the current twin setup. I can imagine the valvetronic will help with control lag greatly because of the fine control of the exhaust valve lift and timing. Maybe that can make up for the overall greater inertia of one turbo over two smaller ones.
Just speculating, but still would be cool to know more.
2009 - Titanium Silver - Steptronic - 135i - Nasty
DBFIU is offline   United_States
      01-11-2010, 12:49 PM   #13
marcel b
marcel b's Avatar
Drives: 1M Coupe
great, they introduce the right shift up and left shift down for non M models as well!!!
marcel b is offline   Reply With Quote
      01-11-2010, 12:53 PM   #14
Mark M
Mark M's Avatar
Drives: E30M3 E83X3 E90335D
Just a thought....I am by no means an engineer, but could using a single turbo result in the power falling off relatively quick? I know with the twin turbo N54 the car is able to hold its power curve fairly well to redline.
Would a single turbo N55 contribute to a sharper power curve decrease towards redline due to lack of flow?
Thoughts?
Mark M is offline   United_States
      01-11-2010, 12:53 PM   #15
d3l0n
I love the ///M3, but I want 550hp ///M5
d3l0n's Avatar
Drives: BMW330iE90
wow, happy to see what they are doing with the 1 series. It's awesome.. they aren't treating it like some "cheap" model
d3l0n is offline   United_States
      01-11-2010, 12:59 PM   #16
mapezzul
Special Agent
mapezzul's Avatar
Drives: Depends on the day!
This has been hinted at for months... it is welcomed!!
mapezzul is offline   United_States
      01-11-2010, 01:09 PM   #17
Luvmybmw
One Fast 1
Luvmybmw's Avatar
Drives: '08 AW e82
Thoughts?
I also am not an engineer, but found this...
It it better for the turbo-spool up when it is only 3-cylinders that banging into the impeller. 6-cyl it to smooth if you understand what i mean. Why do you think the old Alpina B10 Biturbo had two turbos, and why does the new 335i have two. Toyota Supra, Nissan Skyline and so on.
I have a friend that is working on Saab. He is mapping the turbo engines for them, and he says it is a little bit better to have twin turbo on a strait six engine than just to have one. But like i said, one works good also, but maybe you will have little more lag.
Another thing is if you have one turbo with two intakes... then it is also best to have 3-cylinders in one hole and the other 3 in the other. So just don´t put all cylinders to one pipe.
But of course like you said, it is easier and cheaper to only have one turbo.
Luvmybmw is offline   United_States
      01-11-2010, 01:17 PM   #18
Monterra
Monterra's Avatar
Drives: 09 128i 6MT
Ah- so you're saying they are treating the 335Ci like a cheap model because it retains the N54- at least for now? N55 with one turbo I would bet saves $. I'm not saying it will be a completely bad thing- 20kg loss is one clear positive, 10% greater efficiency is another. I do find it odd that some keep the N54, some get the N55. I'd venture to say the N55 will feel more like a boosted motor than the N54- ie it will have more lag- not a good thing. But if they fix the FP issues it will likely be an 'upgrade' that many N54ers would probably welcome.
6MT-Montego/Terra 128i ZSP
Save the manuals, bring the diesels BMW!
Monterra is offline   Reply With Quote
      01-11-2010, 01:26 PM   #19
onefastman
I would assume that it would have more top end and more lag, at least from what I have read.
onefastman is offline   Reply With Quote
      01-11-2010, 01:26 PM   #20
RobLS
Drives: M3 Coupe
If I understand correctly, a twin-scroll turbo is not the same as a regular single turbo. It has two exhaust inlets? As opposed to 1. One being smaller than the other. This allows for the smaller one to be open during low rpms for boost to be engaged early on, and the larger one to open up later in the range to keep boost going to redline. So it essentially gives twin turbo like power in one turbo. Not sure how these will tune out, I think the turbo itself is tuner friendly since it's a big aftermarket turbo style and Subaru uses it in a couple of their cars as well. The thing that will fustrate tuners the most will probably be the valving technology.
RobLS is offline   Reply With Quote
      01-11-2010, 01:32 PM   #21
chesterfan1230
chesterfan1230's Avatar
Drives: a Bat Mobile :)
2010 BMW 135i  [5.00]
Send a message via AIM to chesterfan1230
I'm kind of upset about this. I ordered a 2010 and got mine in september, had i known they were going to change to DCT / just for the harmon kardon i would have waited.... oh well i love my 1 either ways...
What's a Mod?
chesterfan1230 is offline   Reply With Quote
      01-11-2010, 01:33 PM   #22
trahsub
Drives: 95' ///M3
I'm surprised that if they are offered the N55 with DCT in the 1ers, that they will continue to offer the N54 with DCT in the 335i and Z4. Just seems strange to me.
trahsub is offline   Reply With Quote
Reply
Forum Jump
