      10-15-2010, 06:26 PM   #23
arsenyc
www.SubXcess.com
arsenyc's Avatar
Drives: AW 135i
Windows rolling up can be programmed or "coded" very easily if you want that feature, but will cost you some $
      10-15-2010, 07:59 PM   #24
TP 135i
TP 135i's Avatar
Drives: 2008 135i SGM MT
Originally Posted by BrokenVert View Post
How do you do that?
It's in the I-Drive....
Select Climate
Select Parked car operation
Set the timer (there are two available timers to set)
That's it. The fan comes on at the set time and runs for (I Think) 20 minutes (I don't have my owners manual with me right now).
You have to start the car and drive to be able to do this again (to keep from draining the battery).
To the OP.......Sorry for the thread jack.
2008 135i SGM
      10-15-2010, 08:02 PM   #25
BrokenVert
Resident Kerbalnaut
BrokenVert's Avatar
No iDrive
yeah sorry to jack
      10-15-2010, 10:44 PM   #26
RPM90
Drives: 340i M-sport AT
I was under the impression that this could be done by your BMW dealer.
It's in the programming.
My 06 A4 had both unlock doors, roll down windows, and open sunroof if you press the unlock button a second time and then hold it.
Then, if you want lockup, close the sunroof, and roll up the windows, then you press and hold the lock button.
Safety is provided by the anti-pinch control, which works very nicely even in our cars. Get a stick and try to close your sunroof or windows. When the window/roof hits the stick, the window/roof will retract.
It doesn't require a lot of force to activate the anti-pinch, it's pretty responsive and safe.
I don't think BMW disable this due to safety lawsuit reasons. After all Audi/VW still offer this.
I keep forgetting to do it, but next time I'm going to ask the dealer to program this feature "on", and see what they say. It can't take but a few minutes, so even if there is a charge it'll probably be the 1/2 hour minimum, $40 or $50 bucks.
They should just do it for free, cause they should ask the customer if they want this feature when we pick up our new cars. Hell, it's already in there and we paid for it to begin with!
      11-29-2010, 08:08 AM   #27
SquidwarD
SquidwarD's Avatar
Drives: 2017 BMW X5 m-sport
I went to my service center last week here in Germany and he told me no more then 40-50 Euro to program this in to my car. Could take up to an hour to program. Iíll be making an appt this week. Iíll let you know if the numbers above change.
      12-15-2010, 04:28 PM   #28
Duckles McGee
Drives: ISO M3/M4
Originally Posted by Technic View Post
The Comfort Closing (including the folding of the mirrors by keyfob) can be coded into the USA 1-Series by Autologic or by NCS Expert.
BMW needs a VAG-com equivalent. You can safely program all sorts of options and features with it on a VW/Audi.
      12-25-2010, 08:44 PM   #29
SquidwarD
SquidwarD's Avatar
I found this, you can see if this will work out...
works for the windows and has some other things as well
http://www.wit-usa.com/sms/shop/inde...ode=view&id=65
      12-26-2010, 07:03 AM   #30
Harry_135i
Drives: Invisible so far
My uk 1er let's me open and close! Close by using the BMW badge on the key fob
      12-26-2010, 09:47 AM   #31
e46m3to335i
Drives: 2012 F30 335i
Any update to this???
-Nick
      12-27-2010, 03:33 AM   #32
ozzie135i
I tried this with my australian 09/10 135i and it opened and closed with the remote.
opened by holding the unlock
closed by holding the lock
      01-28-2011, 07:38 AM   #33
chrisN
chrisN's Avatar
Drives: bmw 125i coupe
2010 125i  [4.33]
ditto.
      01-30-2011, 06:29 PM   #34
falcon133
Chief
falcon133's Avatar
Drives: 135i Cabriolet, M-sport, 6sp
Send a message via AIM to falcon133
I have a US spec 135i convertible and I can open/close top and windows from the remote. Must be the comfort package feature.
      01-30-2011, 09:47 PM   #35
JimD
JimD's Avatar
139
Drives: 128i convertible
It is indeed the comfort package that lets you lower or raise the top with the remote. The modification will also let you raise or lower with a tap of the dash button from inside the car, however, as opposed to having to hold the button down.
Jim
      01-31-2011, 07:05 AM   #36
tyorll
tyorll's Avatar
Originally Posted by dubdemand View Post
My uk 1er lets me open and close the windows with a push and hold of either lock or unlock buttons...
my Australian spec 135i allows opening and closing of windows and sunroof with unlock/lock button on key fob.
      01-31-2011, 09:09 PM   #37
White-one
Drives: White 135I
Had mine programmed by EAS in LA for $95 plus they turned off the stupid seat belt chime. Good people.
      01-31-2011, 09:18 PM   #38
falcon133
Chief
falcon133's Avatar
The mod you are referring to is $350 . Seems like a lot of money to avoid holding down the button for 15 seconds. I considered it, but the price is prohibitive for me.
Jim
