      06-24-2010, 03:42 AM   #1
Eddy@ApexRaceParts
259
Drives: E30 M3, F10 M5
Smile APEX ARC-8 light weight wheels - [1000+ in stock ready to ship]
18" APEX ARC-8 WHEELS - IN STOCK AND READY TO SHIP
ApexRaceParts.com - Aftermarket Performance EXpress
We now have over 1000+ wheels in stock, including all 4 finishes of the 1 series specific wheel
All orders ship same or next day!
These wheels are Flow-Formed (roll-forged barrel) and available in 4 popular finishes.
Strength is a priority so the load rating has been set to 703KGS.
Weights ranges from 18.2lbs for the rear wheels and 18.45lbs for the fronts.
All the 18" wheel barrels were modifed in order to clear a stoptech 380mm BBK.
Camber plates are a MUST to run anything larger then a 225/40/18 extreme summer tire up front. some less aggressive 235's will fit without issue.
18x8.5" and 18x9.5" fitment is recommended but two highly modified cars are running the 9" front wheel
Recommended tire sizes for the front on the 8.5" rim is a 245/35/18. 255/35/18's can be used but a front fender roll may be required depending on tire model/brand
The rear can easily accomidate 275/35/18 tires, but 265/35/18 is very popular.
Note: that wide rear tires will contact the inner subframe while car is jacked up off the ground, such as r-compounds.
This is not an issue at all and there is plenty of clearance once the suspension settles.
Wheels are available online through ApexRaceParts.com
You can go Directly to our 1 series section by CLICKING HERE or on the wheel sizes listed below
Three 1 series fitments are available:
18x8.5" et38 - 18.45lbs - $289
18x9.0" et42 - 18.65lbs - $299
18x9.5" et62 - 18.20lbs - $314
4 finishes:
Hyper Silver
Hyper Black
Anthracite
Satin Black
Hyper Black
Satin Black
Hyper Silver
Anthracite
Hyper Black
Satin Black
Hyper Silver
Satin Black
Hyper Black
Satin Black
      06-25-2010, 02:08 PM   #2
Eddy@ApexRaceParts
259
Thanks for all the emails and calls. At this rate these will go surprisingly fast. Our site stays up to date on stock, so feel free to order online. And contact us if you have any questions.
      06-28-2010, 01:24 AM   #3
spyderx
Drives: 2011 135i
any 17s?
      06-28-2010, 11:47 AM   #4
Migsboyfresh
Donde esta la biblioteca?
Migsboyfresh's Avatar
Drives: like fernando alonso
what finish would you recommend for a sedona red 135? also i just bought hankook v12s 225 in the front and 255 in the rear. these will fit the 8.5 front rim and 9.5 rear rim, correct? if so whats the best pricing shipped to 07644? gracias!
      06-28-2010, 02:36 PM   #5
Eddy@ApexRaceParts
259
Originally Posted by spyderx View Post
any 17s?
We have 17x8.5" et38 wheels. Many people run this size, but the tire size you can run on it depends on your suspension as camber plates make a significant difference in how much front tire can be run without rubbing.
      06-28-2010, 02:36 PM   #6
N55_NOLE
Drives: 2008 550i
Does anyone know the weight of the stock m sport wheels, by chance, off the top of their head?
      06-28-2010, 02:40 PM   #7
Eddy@ApexRaceParts
259
Anthracite is a very popular finish on red cars, but all 4 look good.
Those tire sizes would work perfectly fine on a completely stock 135i. If you add negative camber to the car, then in the future you can run wider front tires, and the rear can fit more as well.
Shipping to 07644 is: $92.52
The apexraceparts.com site automatically calculates shipping for you when you enter your zip code. All 4 finish are in stock and ready to ship.
      06-30-2010, 01:15 PM   #8
Eddy@ApexRaceParts
259
The factory rim is around 26lbs if I remember correctly.
      06-30-2010, 02:43 PM   #9
akak1997
akak1997's Avatar
35
Drives: BMW 135 @ 135mph
2008 135i  [0.00]
can I mount 255 star specs on the 9.5 for the rear wheels? I just got the star specs a few months ago, don't wanna spend extra for tires yet.
      06-30-2010, 03:26 PM   #10
larryn
Drives: '97 332ti, '16 F82 M4
http://www.tirerack.com/tires/tires....t+Z1+Star+Spec
Specs are that it can mount on a 8.5" to 10" wide wheel...
      06-30-2010, 03:33 PM   #11
Eddy@ApexRaceParts
259
Yes sir, no problem with that fitment at all.
      07-01-2010, 06:13 PM   #12
Eddy@ApexRaceParts
259
Ready to go!
      07-02-2010, 07:45 PM   #13
Eddy@ApexRaceParts
259
all 4 finishes of the 1 series fitment wheels are in stock for immediate shipment!
      07-03-2010, 07:37 AM   #14
gap
Drives: 2008 135i
I've got Hankook V12 in stock tire sizes and BMW performance suspension,
will these wheels accept the tires and bolt on with no issues?
      07-05-2010, 11:15 PM   #15
Eddy@ApexRaceParts
259
They would be very undersized for these wheels. It would fit, but it would be stretching the tires noticeably. The wheels accept OEM lugs.
      07-09-2010, 01:59 PM   #16
Eddy@ApexRaceParts
259
We've moved into our new place. our systems are up and ready again. Orders will ship out ASAP
      07-12-2010, 03:51 PM   #17
Eddy@ApexRaceParts
259
ready to ship!
      07-13-2010, 06:52 PM   #18
Eddy@ApexRaceParts
259
Thank you for the orders. Please PM me if you have any questions
      07-13-2010, 10:49 PM   #19
jwellsiii
Drives: 135i SG 6MT
2010 135i  [0.00]
Bump for these wheels. That's my Space Gray (D 103) @ Laguna. Love these wheels. They've held up well for street use too with 245/35/18's up front and 265's in the rear. A little wheel wax and they stay clean with just the occasional quick spray with the hose.
      07-14-2010, 09:48 PM   #20
Eddy@ApexRaceParts
259
I'm looking forward to seeing the car in person. Did BR Racing do the work. I remember meeting a customer there who was getting a lot of work done on their 135i.
      07-17-2010, 09:45 PM   #21
deek
looks great
      07-19-2010, 03:44 PM   #22
Eddy@ApexRaceParts
259
Thanks for comments and inquiries. We still have plenty of stock.
18x8.5, 18x9.5, apex, arc-8, track wheels
