FORUMS
- 5
| 09-03-2010, 12:13 PM | #683 | |
Drives: S50 M Roadster Join Date: Sep 2010
So if you have the 911 Turbo technology, you can fit a larger turbo with a VNT and take more rpm.
I'm French no one is perfect in this world
| 09-03-2010, 12:46 PM | #684 |
![]() Drives: '08 135i, '03 WRX Join Date: Feb 2008
Sure, new technology is always more expensive initially, but it comes down in price over time.
Delivered in Munich, broken in on the Nurburgring.
| 09-03-2010, 12:56 PM | #685 | |
![]() ![]() ![]() ![]() Drives: 91 300ZX Twin-Turbo, 2010 135i Join Date: Aug 2009
I understand, I'm saying maybe the reason BMW gave us tiny, journal-bearing turbos with cast manifolds is likely because of the cheapness to manufacture vs Variable-vane, ball-bearing, tubular manifold turbo setups. (which would be FUCKING AWESOME!) |
| 09-03-2010, 01:25 PM | #686 | |
in the shadows..
The new 1M might have a bi-turbo VVT ..! |
| 09-03-2010, 01:31 PM | #687 |
No doubt about that, I agree. I'm just thinking that with M cars becoming FI, it would be great to see these types of turbos used in the M cars. The existing turbos are perfectly fine for the regular series cars.
| 09-03-2010, 01:34 PM | #688 | |
Then combine that with Valvetronic for the F30 M3.
| 09-03-2010, 01:48 PM | #689 |
BMW's turbo suppliers are Borgwarner and MHI, and these manufacturers don't have dual-ballbearing turbos in their lineup.
| 09-03-2010, 04:24 PM | #690 | |
![]() Drives: 1M / M3 E36 3.2 6MT Join Date: Jul 2010
![]() Main suppliers Several companies supply the rotating vane type of variable geometry turbocharger, including Garrett (Honeywell), Borg Warner and MHI (Mitsubishi Heavy Industries). |
| 09-03-2010, 05:03 PM | #691 | |
| 09-03-2010, 10:53 PM | #693 |
I'm just a cook
Emissions are driving the result of "The Hybrid". If you take an N55 335is and bump the power up, BMW may have been forced to use 2 more cats. Just a thought
| 09-03-2010, 11:09 PM | #694 |
Drives: 2010 128i Join Date: Feb 2010
And this is based on what?
| 09-03-2010, 11:50 PM | #695 |
I'm just a cook
| 09-04-2010, 12:01 AM | #696 | |
![]() ![]() Drives: white 135 Join Date: Aug 2010
to get what i'm on about, Look at the HIUE systems (or similar) used on transport trucks today. Last i checked (a few years back) they were injecting deisel into the cylindars at 22,000 PSI just to get their emissions low and power high. So seeing a car with 10,000 wouldn't suprise me one day in the future. it would be neat to see a dual plenum turbo (maybe even quad) used for more efficiency as well, help drop the spool times a tiny bit. I think it would work well with a Variable Vane turbo, though might not be that necessary since cars rev a lot higher pushing enough air that it wouldn't really matter. If you want to see the future of our beloved gasoline, watch the technological developments in transport truck engines. pretty amaizing stuff. and as stated by others, the more units of something that are made, the more the price can drop. The first fully carbon fibre car was 1000000$ now you can get many different car designs that are stronger and more advanced for a 1/4 of that price. it only took 20 years ![]() |
| 09-04-2010, 03:31 AM | #698 | |
in the shadows..
I doubt the 1M is going in that direction. I think it would require too much duct work. The 1M's engine will most likely be named a S54 & I think more fundamental philosophies are being used. We all know the N54 in stock form can make 425+HP in limited duration. But even matching that freakish hp from the M Division isn't logical.. it would simply be too much, for the scope of the car anyways. (ie: sloppy) So there is ALOT of middle ground between 300Hp ~ 450 in stock from. Let alone able to redesign internals, or use new variable efficiency turbo to the bi-turbo set up? If we can get 380hp @ 6400rpms & 380ft-lbs of torque @ a much lower and concise point of 1,200rpm's ~ 5,200rpm's. But even that isn't impressive, if they can't match the response... which I think they are secretly grinning about. I think that is alot of what this engine is about.. to pre-sell the new turbo M3. The E30 M3 didn't have alot of engine, but it had something right.... but.. HAF |
| 09-04-2010, 03:51 AM | #699 |
Hmm there is no point of having another cat rather than upgrading one with the right level of rare metal (palladium etc ...) to meet the emission
| 09-04-2010, 08:00 AM | #700 |
I'm just a cook
Sure, but the M1 evolves from existing piece parts and new cosmetics. Ok, ok the muffler is new, but only due to cosmetics.
| 09-04-2010, 05:17 PM | #701 |
I attended the BMW M Power Experience Event in Miramas France a couple of days ago. As a part of the event, they had a 1 Series M Coupe they showed us - at least the same front fender they show in the video. I was tempted to rip the rest of the cover off - but restrained myself and just felt the car up through the cover instead.
![]() There were a few tidbits thrown out about the car - one I haven't seen reported here is that it will be a limited production run for 1 year with 500 cars allocated to North America. |
| 09-04-2010, 05:22 PM | #702 | |
Ghetto Blasta
Gimme Dem Chips
| 09-04-2010, 05:26 PM | #703 |
| 09-04-2010, 05:38 PM | #704 | |
![]() Z4M Coupe 6MT Monaco Blue #13/36 ...Keeper... Z4 3.0 6MT ...Keeper... 2OO2 5MT ...Keeper... 335i 6MT Montego Blue M-Sport (Retired),X535d Vermillion Red/Saddle (Retired) |
| Bookmarks |
