Reply
      06-17-2011, 12:26 PM   #23
Moderator
Drives: 135i Silber mit/Rot 6MT N54
Originally Posted by romak47 View Post
...Also, I just changed my trans fluid recently like 4k km ago, and i am thinking of doing redline as well. I heard it will make shifting smoother as well.
Dackel... do me a favor and try it out for me first
lol..
I am having trouble finding a online dealer who will ship the RedLine D4-ATF to my APO. Does anyone know of a good source? Then I would be happy to test it for you Romak47
Btw... with my Perf SKK, it is most notchy in the 1st/2nd gear slots. Everything else is really sweet. I am not complaining either about the SSK. I would still do it again in a heartbeat! Its a sweet mod. Maybe your shop did not use enough lube in the shifter rod/ball & socket? You can use some CV joint (M02)grease in there.
Dackel
Dackelone is offline   Germany
      07-04-2012, 08:35 PM   #24
TSRgeneral
TSRgeneral's Avatar
Drives: 2008 135i Cab
I completed this mod today, not by myself but with a shops help. one hour labor and it was all done. I kept the old CDV in case I wanted to revert to stock.
The feeling is excellent. I was worried that i was going to make my 135i vert worse, as some mods take away from driving pleasure but immediately I was content with this mod.
TSRgeneral is offline   Reply With Quote
      09-08-2012, 07:38 PM   #25
kernelguy5
kernelguy5's Avatar
Drives: 2009 BMW 128i
2009 128i  [0.00]
So I just got home from the shop after a CDV delete. I got to feel it out a lot because it's an hour away. The main improvement that I felt was that I didn't need to baby the clutch as much as I used to. I could kinda just shift without thinking and everything just goes nice and smooth. Also, I'm wondering if the clutch should feel lighter? The first thing I noticed when I got in the car was that the clutch is much softer with a little bit of play..I'm hoping my shop didn't mess it up or anything
kernelguy5 is offline   United_States
      09-08-2012, 11:40 PM   #26
dorkdog
Big Mouth No Filter
dorkdog's Avatar
Drives: 128i Montego B*ue 6MT Sport
Now... for you guys who have done the CDV... you NEED the BMW Performance SSK. 55mm throws instead of 800mm throws! This will really make yourself wonder why BMW did not make the car with it!
As for the notchness... yea... mine is a little notchy still in 1st and 2nd gears. Even though I just changed my trans fluid... I am thinking about switching to Red Line's D4-AFT... bc it is known to make the trans shoft lighter/smoother. Atleast that is what I felt with my old e36 when I switched to it.
Dackel
+1 on the SSK... I had mine done yesterday and it's night and day! The shifting is a lot snick-snickier than it was before, and it's just more fun to drive.
Seems like a 30-40% reduction in throw. I did not swap out the knob and boot; I ordered only the 'hard' parts. Dackel thanks for your advice on the SSK; it's advice worth taking, OP.
I no *onger use the 12th *etter of the a*phabet because it resemb*es a gun, and I do not want to be *abeled a Terrorist for posting pictures of guns on the internet.
dorkdog is offline   United_States
      09-30-2012, 05:28 PM   #27
ThreeLO
Drives: 128i 6-M/T
this is good to know i hate CDVs on clutches as they increase the clutch wear substantially
ThreeLO is offline   Reply With Quote
      11-02-2012, 10:08 PM   #28
SquashAZ
Drives: Sedona Red 135i
Has any one has any issues post removal? A local BMW specialty shop in AZ claims that if you remove the CDV it is possible that if driven incorrectly the self adjusting clutch will self adjust it self to death. I do not see how this could happen and feel like it might be a old wise tail.
I asked my BMW dealer ship and they had no comment officially but could not image if would cause any damage if removed (as a data point).
Any one have any comments or thoughts on this?
SquashAZ is offline   Reply With Quote
      11-03-2012, 02:20 PM   #29
smellthebeans
smellthebeans's Avatar
Drives: LPCs
2011 328i Coupe  [0.00]
1990 325i  [0.00]
Dackel
Bavarian Auto Sport confirmed.
For the record I exclusively use redline MTL only. Doesn't ATF have anti foaming agents that might not play well with synchros in manual transmissions?
EDIT: "D4 ATF also provides a GL-4 level of gear protection, making it a superior product for transmissions and transaxles."
I'll be damned!
http://www.redlineoil.com/product.aspx?pid=51&pcid=9
smellthebeans is offline   Germany
      11-03-2012, 05:48 PM   #30
Rikx1M
MSgt (ret)
Rikx1M's Avatar
Drives: VO 1M #739/740
Interesting reading on Redline ATF:
http://www.1addicts.com/forums/showthread.php?t=765175
Rikx1M is offline   Germany
      11-04-2012, 02:47 AM   #31
Moderator
I'll be damned!
I have used Redline's D4 for many years in my Manual BMW trans. Redline's ATF works just fine in them. I just posted my thoughts in Rikx1M 's link...
I would highly recommend Redline's gear oils. D4 or D6 in our manual trans and MTL or their gear oil in our diff's. I like thier fluids bc they are fully synthetic and they really make a difference you can feel in shifting!
      11-04-2012, 06:25 AM   #32
smellthebeans
Drives: LPCs
1990 325i  [0.00]
maybe we should inject this stuff into our aging joints?
      11-04-2012, 12:25 PM   #33
Lucky1
Drives: '08 128i Coupe SGM 6MT
What is a self adjusting clutch? That sounds like a feature I'd expect on an SMG or DCT...
Lucky1 is offline   Canada
      11-04-2012, 12:28 PM   #34
Moderator
No such animal! That is some shop talking out of their arse(!) bc they don't want to do a CDV delete.
In the old(en) days... cars had a clutch cable. Then some cars had a self adjusting clutch cable. VW's were famous for these in the 80's and 90's. BUT I have never heard of a self adjusting clutch with a hydraulic clutch lines.
Dackel
      11-04-2012, 11:29 PM   #35
flinchy
Drives: 130i
Dackel
i've had it in for 2000km
it gets smoother every day, not even kidding, it's almost perfect with no notch now
io bought mine from amazon.
flinchy is online now   Reply With Quote
      11-05-2012, 07:50 PM   #36
Lucky1
Dackel
Thanks! I've never heard of them mentioned before on this forum in 2-3 years.
Reply
cdv clutch mod
Forum Jump
