      01-18-2012, 11:33 AM   #89
mtechnik3
mtechnik3's Avatar
Drives: 2020 M2C
Originally Posted by ChuckD05 View Post
You just made my mind up on spacers and springs haha
Only thing I would do different is put the bigger or the same spacer out back. On RWD car I'd prefer the rear wheel to poke a touch more than the front.
But ur car looks great. Sorry for thread revival but it's a great example of eobach springs with spacers on our stock wheel !
Thanks for the feedback, Chuck. Glad you're getting some on your 1er as well. I plan to run some wider 255 tires in the rear on mine this year so the stance should look better.
2020 /// M2 Competition
Past: 2016 435i ZHP Edition | 2013 335i | 2011 135i | 2008 328i | 2006 325i
      06-20-2012, 08:13 AM   #90
gmane
Drives: m235i
Sorry for bringing this up but why did you go FSD's as opposed to doing the Full Eibach pro system that comes with matched shocks and the springs? I'm curious cause i love the ride height of your car and i'm considering doing the same setup..
      06-24-2012, 05:56 PM   #91
mtechnik3
mtechnik3's Avatar
Drives: 2020 M2C
There was a period of time when the Koni FSD and Eibach Pro-Kit springs were sold as a bundled package on Tire Rack (I believe when the E90 was introduced). Since then, there have been several that decided to run this set up. I felt the FSD damper technology would meet my needs of a providing comfort yet still something I could enjoy during an occasional spirited back road drive. So far it has been great at dampening out some of the harshness of SE Michigan roads while still retaining the factory sport feel.
The full Eibach system may be more in line with the OEM BMW Performance suspension set up (also a great option).
      08-30-2012, 07:21 AM   #92
Cozy
Cozy's Avatar
Drives: E82 135i
Thanks for helping me spend money . Eibach's & spacers on the way...
Just to confirm, these are the Pro springs and not the lower, Sportline versions? It's just that I've heard that the Pro do not lower the car more than stock 135i height.
Using your car as inspiration in fact although I have 261M wheels in gunmetal on BSM instead.
Have you thought about a carbon rear diffuser? It would look really good on your car. I think that will be my next mod after lowering, something like iCarbon (any 3-fin style as I believe they are out of business now) or a BMWP replica (2-fin), a couple of the eBay ones get good comments.
      08-30-2012, 09:49 AM   #93
gmane
Drives: m235i
I find this setup to be quite stiff despite the claims of the FSD. Over bumps theres quite a bit of bounce, don't get me wrong it gives good feedback but it isn't similar to a stock setup IMO
      08-30-2012, 02:32 PM   #94
mtechnik3
mtechnik3's Avatar
Drives: 2020 M2C
No problem.
Pro-Kit Springs do indeed lower the ride height from stock. I would say about 1.25 inches front, 1 inch rear.
Yes - I've considered the BMW Performance rear spoiler painted in BSM. I think it looks great on the 1 Series.
Enjoy your car.
      09-28-2012, 07:17 AM   #95
Cozy
Cozy's Avatar
Drives: E82 135i
Do you think if you put 255's on the rear with a 15mm spacer it would rub? Or is space ok in there?
      09-28-2012, 09:58 AM   #96
mtechnik3
mtechnik3's Avatar
Drives: 2020 M2C
Interesting you just posted this. I just installed new tires on my 135i - 255/35/18 rear with 12mm spacers - and it is rubbing slightly over large dips in the road. I will go down to a 10mm and report back. So to answer your question, no. Additionally, my car is set up to factory alignment specs. You will gain a bit more room if you dial in negative camber in the rear.
      10-01-2012, 10:51 AM   #97
Cozy
Cozy's Avatar
Drives: E82 135i
Thanks for the reply .
Looking forward to hearing how you get on with 10mm. Will you swap your 12mm to the front?
