      06-13-2012, 05:53 PM   #111
Focusedintntions
Drives: 2011 135i M-Sport :D
Originally Posted by octironSmith View Post
So do we think this is worth the loss of comfort? Thoughts?
Wasn't this with complete CF body panel replacement?
yes and with no interior or carpeting or anything else in teh car....pure race car.
      06-13-2012, 05:57 PM   #112
The1
Drives: white 135
I think 3200 would be pushing it for daily comfort.
if you did a carbon front end and carbon trunk with light weight battery and some other minor tinkering, you're probably about as far as would be considered usable.
once you start driving around without a back seat and trunk lining, you're entering a different level of discomfort.
I would be willing to bet that 3300 is more reasonable then 3200lbs, but, everyone has a different opinion of what is tollerable, it's up to you to decide.
I had a car that I drove for about a year that was pretty much stripped out, was one of the most fun times of my life, unless I was on a road trip, and I never missed music so much (and the car had a stereo, it was just not that audible over the noises of the car)
It's a fine line, but it's up to you.
I would keep it simple, carbon hood and trunk, light weight wheels, and maybe sun roof. Take the back seat out for track days. and maybe scrap the plastic under the hood, it's very unnecessary. Going light weight battery does sit on the fence in my opinion. I love the idea but I know the battery is in the back for weight distribution purposes, and putting a light weight one in there when you have a massive front mount intercooler is going to move the bias to the front. This is why I've left my battery stock.
I'm willing to bet this would put the car at the 3300lbs and maybe a touch lighter mark
100lbs off a car is very noticeable to me. So, really depends how greedy for light weight you get
That 2500lbs car isn't usable on the street anymore. It may still be licensed, but there would be nothing legal about it.
      06-13-2012, 06:33 PM   #113
pixelblue
pixelblue's Avatar
78
Drives: the silver bullet
2010 135i  [4.45]
not sure if I am missing something but how is that simple?
3300 is no loss in comfort. 3200 you're looking in more road noise, so forth and so on...
      06-13-2012, 06:34 PM   #114
The1
Drives: white 135
lol, that's why the "maybe" I tend to make simple things complicated....
      06-13-2012, 09:35 PM   #115
bogart
bogart's Avatar
Drives: E82 N55 DCT
2011 BMW 135i  [3.53]
3,300 is easy and comfortable. The car is just as comfortable as it was stock. It depends what your definition of comfort is.
3,200 is easy as well. I used to run without the backseat, floor mats, and a stripped trunk. The biggest differences were road/exhaust noise, especially with the Cf trunk with no lining, and buffering when the windows are rolled down, wind getting caught against inside of trunk. Simple solution was to open more than one window or the sunroof as well. And yes, 100 lbs makes a huge difference.
The 2,500 was completely stripped. I think the FE was CF
Obv the trunk and hood as well. Race seats. Etc. It would be easy to achieve, but many "creature comforts" would be lost. It could be a daily driver if you're okay with that sort of thing.
      10-16-2012, 07:47 PM   #116
Xearo
Because 6466
Drives: Single Turbo 135i
I know this is an old thread but just FYI the mid section exhaust for an N54 weighs 29lbs And the rear muffler section weighs 28lbs. I can weigh the factory downpipes as well if anyone would like.
-'09 135i MT - Custom 6466 ST - 680whp
-'08 135i AT - 6466 ST - dead
-'97 318is - Daily
-'82 320i
      10-16-2012, 10:16 PM   #117
DRedman45
DRedman45's Avatar
11
Drives: E86 //M coupe, e84 X1
^good thread to bump
I find it odd that nobody has chimed in on the greater effects of getting rid of rotating mass vs deadweight...I am not so technical on the engineering/physics of it, but reducing rotating weight has a much greater impact on the power being put to the ground...10lb/corner lighter wheels and tires will give you better performance than losing 60lbs of deadweight
      03-11-2014, 07:33 PM   #118
stormzusmc
stormzusmc's Avatar
Drives: 08 135i Sedona Red
Again old thread bump, there may be a new one, but this should get cleaned up/updated, and made into a sticky!
JB4G5, BMS DCI/DPs, VRSF 7", Stett CP/Tial BOV.
"I'd rather be whackin tangos"
      03-11-2014, 08:39 PM   #119
MuNkY6913
The Crowing
MuNkY6913's Avatar
Drives: BMW 135i
2009 135i  [4.00]
Combined OEM clutch plate, clutch disk and dual mass flywheel is 42.2 lbs including the bolts holding the clutch to the flywheel and the stock spindle in the flywheel. It's substantially heavier than the Spec stage 2+ Steele single mass flywheel and clutch disk and clutch plate. I'm sure you can get the exact weights from Spec. No way I'm taking it off the car to weight it. Haha. But picking the spec flywheel up after taking the stock one off I remembered saying holy crap this thing is light.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback
      03-08-2015, 09:25 PM   #120
inline sex
inline sex's Avatar
Drives: SGM 135I 6MT
a year old bump
My 135i M/T weighed in at 3380 3/4 tank and driver[145#]
No real weight reduction besides bmw PE and DCI
Also has power seats, navi and convenience
Since then I got catless DP and real tires so I should be right around 3300lbs
      03-09-2015, 04:55 PM   #121
heeblet
Drives: 2013 135i Carbon Black
Thnx for the bump I read the whole thing. Very good thread.
      06-28-2015, 03:27 PM   #122
hokejka
Drives: 135i 6mt
any updates? i know a lot of you guys are running some empty cars
      06-29-2015, 10:48 AM   #123
lowbudgethero
lowbudgethero's Avatar
108
2009 BMW 135i  [4.25]
Any weight savings from exhaust I did was added with bigger front wheels/tires and the 335is/550i clutch and pp. I didn't think to weigh them both but the PP seemed heavier than the factory one by a few lbs.
      06-29-2015, 11:11 AM   #124
Ginger_Extract
California-bound
Ginger_Extract's Avatar
Drives: BMW 135i
2010 135i Coupe, 6MT
- US Spec (sun roof)
- No options (no nav, manual, non heated seats, etc.)
Race weight: 3409lbs.
- 3/4 tank of fuel
- Me in car (185#)
3409 - 185 = 3224
Weight considerations
- Cowl delete
- N55 MP/BERK Race
- 17" track set up 255/40 square
- TC Kline coilovers (about the same as stock)
- Eibach front sway bar (heavy)
Pretty sure there's at least another 50# that can be easily removed via battery and seats.
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18
https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3
      06-29-2015, 11:24 AM   #125
ShocknAwe
ShocknAwe's Avatar
Drives: E82 N54
- 3/4 tank of fuel
- Me in car (185#)
3409 - 185 = 3224
- Cowl delete
- N55 MP/BERK Race
Front race seats, rear seat delete and a braille battery and you'd be sitting pretty ~ 3250 or so race weight.
2010 135i M-Sport 6MT Jet Black
N54 | BUILD THREAD
      11-03-2015, 05:15 PM   #126
feeshta
Drives: 2012 135i 6MT, Alpine White
Zombie thread alert!
I was searching for something else and came upon this thread. I read through it with interest as to whether anyone would mention the best mod I have ever made to any car I have owned, which happens to have a weight savings benefit. Sadly, nobody had.
Get rid of that evil squeaking bastard of a center arm rest. It's worth 10 lbs easy, as the thing is surprisingly heavy, and worth infinitely more as a measure of addition by subtraction. No more bashing your elbow on it every time you shift into second. No more incessant squeaking making you want to burn your car to the ground on every long trip. Just get the trim piece that covers the hole and the fitting piece that holds things together. I think they cost about $25 for both, and enjoy a life free from the worst flaw of the E82.
It's completely liberating.
      08-31-2016, 03:54 AM   #127
dbronnik
dbronnik's Avatar
169
Drives: N54 E88
Zombie thread alert #2
22lb cast-iron counterweight can be removed in rear crash bar! credit to hydra from n54tech (#4 here: http://www.realoem.com/bmw/enUS/show...diagId=51_5403)
      07-20-2017, 01:28 AM   #128
Newguy123
Drives: 2008 Nissan Titan
Good call! Will be doing this soon, I also have invested in some "unsprung" or "rotational" weight savings as of late.
Kosei k1 wheels 17x8.5 ET40 square 16.xx lbs per corner
*This saves 8 lbs per corner in the front and 10 lbs per corner in the rear over stock 264 wheels so a total of about 36lbs this doesn't include going to a non run flat R compound tire.
Racing brake 2 piece light weight Oem replacement rotors/pads for front and rear. this shaves a total of 22lbs of rotational weight if you do all 4 corners. 12lbs front savings and 10lbs rear.
M4 dct flywheel went in that saves about 10lbs of rotational weight over the stock weighted unit (and most importantly fixed the misfires i was seeing when running 475+ wheel horsepower)
I read pretty deep into rotational weight savings and found a general consensus among a few different articles of "for every ~10lbs of rotational weight removed it's equal to removing about ~26lbs static weight"
The only other weight removal I do for race day is remove the axle back muffler and run a straight pipe not exactly sure on the savings but it's at least 30lbs
Pull the passenger seat and rear seats. The rear I believe are good for 55lbs and not sure what the motorized heated front seat weighs but I think it's around 65-70lbs.
2012 DCT 135i
PURE S2
JB4/mhd
Fuel-It! direct port meth injection
check out my youtube channel here
      08-20-2017, 06:06 PM   #129
Newguy123
I pulled the rear bumper cover and the rear bumper itself to find no hidden or built in weight. My car is a 2012, my buddy checked his 08 with the same result... Nothing there
      08-22-2017, 01:57 AM   #130
dbronnik
dbronnik's Avatar
169
Drives: N54 E88
Sorry about the wasted time! I did just read in this thread that some other people were also not able to find the rear crash bar. Perhaps this is only found on convertibles: http://www.1addicts.com/forums/showthread.php?t=213443
      08-22-2017, 02:40 PM   #131
TZANIDO777
Drives: 2011 E82 135i, 2015 F15 X5 35D
2015 BMW F15 X5  [0.00]
2011 BMW 135i  [0.00]
Got mine down to 2678 without driver and this is with a half cage. No carbon fiber panels.
      08-22-2017, 11:52 PM   #132
Newguy123
Wow!! let's see some pics! That thing must fly
