FORUMS
- 5
| 02-24-2011, 06:57 PM | #1 |
Drives: E30 M3, E34 540i/6, Cooper S Join Date: Jun 2009
APEX AERO-7 Wheel - Now Available 1 Series Specific, Flow-Formed, Light-weight wheel December only Sale! 15% OFF Save over $180 off the regular set price ![]() Available for Purchase on ApexRaceParts.com In stock, and available for same day shipment in all 4 finishes! CLICK HERE FOR MORE DETAILS AND TO PURCHASE ![]() Specifications: 18x8" (et45) 19lbs~ Front - use with 225/40/18 - normally $299 December sale $254 each 18x9" (et50) 20lbs~ Rear - use with 255/35/18 - normally $309 December sale $264 each Available Finishes: Hyper Silver Hyperblack Anthracite Gloss Black. Misc. Comes with carbon-look APEX center caps Accepts OEM Roundel center caps Installs using your factory lugs TPMS compatible ![]() ![]() ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Wheel Details: Manufacturing process: All APEX wheels are flow-formed resulting in a light weight, track and street worthy wheel. Flow-forming significantly reduces weight in the barrel by rolling the barrel out into it's final shape using large wheels/disks that apply high pressure. This step is the same step that monoblock forged wheels go through to shape their barrels. By doing this, the flow-formed wheel's barrel has the same density and strength as a traditional forged wheel. This significantly reduces rotational mass at the furthest point from the center, which is the most important weight savings area on a wheel. Fitment: These wheels were designed to be a direct, bolt on, rub-free wheel for both stock and modified 1 series models. No spacers, or fender rolling is required if standard 225/40/18's are mounted up front, and a 255/35/18's are mounted in the rear. Cars with suspensions set extremely low, those running r-compounds, or wider then recommended tire sizes can/may have front or rear rubbing issues. Please ask us for fitment advice if you are concerned about your specific application. For wide tire setups we recommend the APEX ARC-8 wheel. Strength: These wheels are fully VIA and JWL certified with a load rating of 1580lbs. VIA certificate numbers are listed in post #58. Don't be fooled by competitors that claim to be certified, but cannot provide registration numbers. There are vendors on this forum selling wheels that are not certified, yet they claim they are. Ask for certification numbers! Last edited by Eddy@ApexRaceParts; 12-12-2011 at 09:01 PM. |
| 03-01-2011, 04:20 AM | #3 |
Id love to see a pic of these on a blue 1er, specially silver and anthracites
| 03-05-2011, 03:14 AM | #4 | |
| 03-09-2011, 01:36 AM | #5 | |
We did update the post above with studio shots. You could photoshop them onto your car for a general idea. |
| 03-15-2011, 03:02 PM | #7 |
Thanks for the calls and PM's.
Yes, these wheels fit without modification or camber plates even though they are wider and support more rubber. They have 1 series specific/exclusive offsets that allow for proper fitment unlike 3 series offset wheels that compromise proper fitment. |
| 04-25-2011, 08:20 PM | #10 |
Has anyone bought and installed these?? Id love to see an installed picture..I mean theyre nice wheels, Im just wishing they had more concavity to them, specially for the price id be paying Id like to know theyre exactly what Im looking for
| 04-25-2011, 08:52 PM | #11 | |
Here's a thread I could find: http://www.1addicts.com/forums/showthread.php?t=517541 |
| 04-28-2011, 08:46 PM | #13 |
![]() ![]() ![]() Drives: 135i + Subaru Legacy (DD) Join Date: May 2010
could i fit a 265 rear tire on these on stock suspension?
FWIW im going to be ordering a set of goodyear eagle f1 assymetrics or michelin PSS thanks in advance. |
| 04-28-2011, 10:48 PM | #14 |
265/35/18 has a very good chance of rubbing on the fender side. It may just squeak by if the tire runs narrow compared to other brands, but I don't think the PSS runs as narrow as the original PS2. This wheel is effectively 8mm more aggressive then the factory wheel, so if you can image mounting an 8mm spacer + 265's onto your stock wheels, that's about what the fitment would be like (8mm accounts for wheel width increase over stock rears)
| 05-02-2011, 02:54 PM | #16 |
Vrooom :)
do you guys sell 17 inch for 128i?
2009 128i Coupe Crimson Red
MODS: -Injen Intake-Magnaflow Exhaust-Carbon Fiber Spoiler - Carbon Fiber Grilles - OZ Ultraleggeras - CF Mirrors |
| 05-02-2011, 03:13 PM | #17 |
We sell a 17x8.5" et40
Can can work on the 1 series, but as normal, tire sizes are limited without camber. 235/40/18 would be the size that would fit properly on those wheels on a stock car http://www.apexraceparts.com/ARC-8-1...eel_p_106.html |
| 11-29-2011, 04:30 PM | #22 |
Here are links to posts containing pictures of the AERO-7 wheels
Gloss Black http://www.1addicts.com/forums/showp...06&postcount=1 Gloss Black http://www.1addicts.com/forums/showp...54&postcount=1 Anthracite http://www.1addicts.com/forums/showthread.php?t=613826 Hyper Black http://www.1addicts.com/forums/showthread.php?t=607100 |
| Bookmarks |
| Tags |
| 18x8, 18x9, aero-7, aero7, apex |
