Reply
      07-17-2011, 09:08 AM   #23
KinoBoom
KinoBoom's Avatar
Drives: 2009 135i
Send a message via Yahoo to KinoBoom
Originally Posted by bubb2521 View Post
Funny... I think the stock wheels look better than most aftermarket wheels. Aftermarket takes away from the "class" of the car. Only thing they need is a little depth. So spacers, in my opinion are the answer.
+1
BMW CCA # 450304
KinoBoom is offline   United_States
      07-17-2011, 10:26 AM   #24
BBursey
Work hard, play harder
BBursey's Avatar
Drives: 2011 135i
2011 135i  [0.00]
Originally Posted by Hind View Post
12 will be fine. Do u have oem wheels? Oem suspension? I chose a smaller size for rear cuz it's already flared some.
Thanks for your reply. I'm on OEM wheels and suspension - no plans to go with wider non-runflat tires and only the slight possibility of going to BMW Performance Suspension in the future.
I think I'll try 12mm (or maybe 15mm per email from Burger Tuning) in the back to go with 12mm in the front.
Appreciate you taking the time to respond.
Cheers,
Bryan
BBursey is offline   Canada
      07-17-2011, 10:28 AM   #25
BBursey
BBursey's Avatar
Drives: 2011 135i
2011 135i  [0.00]
Originally Posted by Bimmer-Bob View Post
If you're not stock, 12 mm may be too much. I rubbed with 12's in back, but I'm lowered on Bilstein PSS9's and running Star Spec 255's in back (which I'm told run wide). Just FYI.
Thanks Bob. I'm completely stock (and plan to stay that way for a while yet), so hopefully 12mm out back will be good. I've had Burger Tuning suggest as wide as 15mm in back as acceptable with stock wheels / suspension.
Cheers,
Bryan
      07-18-2011, 04:30 AM   #26
Fidiman
Fidiman's Avatar
Drives: BMW 120d e82 M Sportpaket
2010 120d E82  [0.00]
It looks better with the spacer !
Fidiman is offline   France
      07-18-2011, 05:42 AM   #27
SiN55
Drives: 135i N55
This is my setup: front spacers 12mm, rear 10mm + KW V3 coilovers. Everything working fine, no rubbing. Agree too, OEM wheels are good looking for me.
SiN55 is offline   Reply With Quote
      07-18-2011, 06:50 AM   #28
BBK
Drives: A boring one...
2009 BMW 135i  [2.88]
I've ordered 12mm and 15mm, was going to go with 12 front, 15 rear... but after reading, it seems like you can go with wider at the front? So maybe Will go with 12 rear and 15 front... Hmmm. I will post pics when done! Also, it's on an otherwise stock suspension/wheel setup.
BBK is offline   Reply With Quote
      07-18-2011, 11:59 AM   #29
New21er
Drives: 2011 135i
12mm rear, 18mm front. Puts all 4 corners right to the edge for stock application.
New21er is offline   United_States
      07-18-2011, 01:20 PM   #30
Fidiman
Fidiman's Avatar
Once, I've heard that spacers deform the axle of the wheels on which they are mounted and moreover from a certain speed, you feel some vibrations ...
Is it true ? 'Cause I like this look very much !
      07-30-2011, 02:59 PM   #31
van11135
van11135's Avatar
Drives: 2011 135i DCT with M package
Cheers,
Bryan
I have 12mm in back and 10mm front from Burger and I love them. Not over the top looks wise, subtle but a much better stance. Handling is also improved.
van11135 is offline   Canada
      07-30-2011, 04:19 PM   #32
BBursey
BBursey's Avatar
Drives: 2011 135i
2011 135i  [0.00]
Hey guys.
I eventually chose 15mm front and 12mm rear spacers from BMS for my '11 135i with stock M Sport wheels / suspension. After some spirited driving, not indication of rubbing in front or back. Pics are posted here.
Cheers,
Bryan
      09-02-2011, 01:37 PM   #33
BimmerE82
BimmerE82's Avatar
Drives: 2009 BMW 135i Sport package
2009 BMW 135i  [0.00]
Looks like Burger Motor Sport spacers are in my future! I'll go with 15mm in the rear and 10mm up front!
BimmerE82 is offline   United_States
      10-10-2012, 08:10 AM   #34
Cozy
Cozy's Avatar
Drives: E82 135i
Sorry to revive this but it's better than filling up the forum with junk duplicates I guess.
For those of you who are lowered on Eibach Pro or more with 255's, did you get serious rub with 12mm+ in the rear? I am considering a square 12mm setup, does that extra 4mm on the rear axle (vs 10mm) make THAT much difference?
Cozy is offline   United Kingdom
      10-16-2012, 10:04 PM   #35
Naoto
warranty denied.
Drives: 2011 135i
Send a message via AIM to Naoto Send a message via Yahoo to Naoto
i run 255 nitto invos on the rear with 10mm spacers lowered on eibachs, and it rubs a little over dips.
Naoto is offline   Japan
      10-17-2012, 06:39 AM   #36
AKopp
Originally Posted by MITE82 View Post
Very nice can't wait to see it when the car is lowered.... A bit overkill on the anti seize?? Haha
You can never have too much lube!
2009 135i - SG/Coral - 19" Alufelgen SF-71 - ST Coilovers - Cobb Stage 2+ - AR Downpipes - Berk Sport Exhaust - Active Autowerke Charge Pipe - AMS FMIC - AFE DCI - LUX V3 Angel Eyes - LCI Blacklines - BMW Performance CF Spoiler - Kerscher Carbon Splitter - Scopian CF Diffuser - MusicarNW Level 2
AKopp is offline   Reply With Quote
      01-12-2013, 10:26 PM   #37
BrunoT
Drives: 2012 F-150
Yes so why should anyone be impressed with a cheap fix on their 1?
Some people eventually mature and do things to please themselves, not others. Impressing people with glitzy things is not really impressing anyone in the true sense of the word.
BrunoT is offline   Reply With Quote
      01-12-2013, 10:35 PM   #38
BrunoT
Drives: 2012 F-150
Not to mention resale. A lot of dealers won't touch a car with aftermarket wheels, I found out. At the very least one should hold onto the OEM's instead of selling them.
Also, how heavy could aluminum spacers be? Many cars could benefit from the wider stance visually even if there was a minute degradation of performance. Especially vs larger heavier aftermarket wheels (unless one wants to drop thousands on them).
      01-12-2013, 10:50 PM   #39
EINSER M
EINSER M's Avatar
Drives: 2011 E82 1M
Send a message via AIM to EINSER M Send a message via MSN to EINSER M Send a message via Yahoo to EINSER M
very cool!
EINSER M is offline   United_States
      01-21-2013, 08:41 AM   #40
J Lau
J Lau's Avatar
Drives: E46
great story.....?
J Lau is offline   Hong Kong
      02-04-2013, 02:06 PM   #41
bmw0bsession
bmw0bsession's Avatar
Drives: 2011 135i M Sport
Is your car on the stock suspension? Any Rub Issues? Sorry I just got a 135i and I am a total noob still. I ordered the same set up but I am asking because I am afraid of rub when I lower my car with the Dinan Performance Springs which is a 0.5" drop.
bmw0bsession is offline   United_States
Reply
Forum Jump
