Reply
      06-15-2011, 07:01 AM   #199
HotSauce
Citizen Snips
HotSauce's Avatar
Drives: Crimson Red 2009 BMW 135i
2009 135i  [5.00]
Originally Posted by aacabriolet View Post
Correct. Socket 8 and a screwdriver to take the carpet clips off. Easy as pie
Do you think you could make a quick DIY guide?
HotSauce is offline   Reply With Quote
      06-15-2011, 10:51 AM   #200
aacabriolet
aacabriolet's Avatar
Drives: '09 120i Cabriolet (Vert)
1) Remove negative terminal from battery (socket 10)
2) Take 2 plugs that are holding the carpet in off with a flat screwdriver.
3) Pry the carpet back so you can get to the 3 bolts securing the tail lights
4) Undo the 3 bolts holding the tail light in place (socket 8)
5) Replace tail light with new tail light
Reverse instructions to install. Repeat for each side. Reconnect battery afterwards obviously.
aacabriolet is offline   South Africa
      06-15-2011, 11:01 AM   #201
HotSauce
Citizen Snips
HotSauce's Avatar
2009 135i  [5.00]
Thank you. Can't wait to put these in.
09 Crimson Red BMW 135i. P3 Boost Gauge, BMW Performance Exhaust, Matte Black Kidney Grills, LCI Taillights, 19" VMR 701 on Michelin Pilot Super Sports.
      06-20-2011, 10:13 PM   #202
outsider
The Show Goes On
Got mine installed today. aacabriolet's right on the money with his quick DIY. One thing though is that these lights don't sit as flush as the ones I had installed in my car. Make sure you notice how your stock lights are lined up before you proceed to install these. The new lights seem to have a thicket foam which pushes the lights slightly out. You have a certain degree of tolerance to adjust the lights when you are fitting them and tighetning the bolts so make sure you line them up good. I held mine pushed in while I fitted them to get them where I wanted them.
outsider is offline   United_States
      06-20-2011, 10:24 PM   #203
HotSauce
Citizen Snips
HotSauce's Avatar
2009 135i  [5.00]
Can you post a few pictures up of your install?
      06-20-2011, 11:36 PM   #204
UdubBadger
Drives: '04 330i ZHP
2004 BMW 330i ZHP  [4.75]
2011 135i  [3.73]
2008 328xi  [4.38]
hahaha really?
it's about the most straightforward install ever. you pull off the carpet behind the light, use an 8mm socket to unscrew 3 nuts and the then disconnect the light and pull it out, put the new one in, connect the plug, use the socket to screw the nuts back on the 3 bolts. Rinse, repeat on other side and boom you are done.
UdubBadger is offline   No_Country
      06-21-2011, 09:24 AM   #205
outsider
The Show Goes On
I've got a pic of the finished product but didn't snap any when installing.
Originally Posted by UdubBadger View Post
hahaha really?
Yes - I understand that, I did the procedure myself. I don't see what's funny?
      06-24-2011, 12:21 AM   #206
toto4dwin
Drives:
Thanks dude How did you come to the conclusion that the LED Eyebrow is getting power from the Angel Eye lights?
Eagerly await your feedback! If you have an email address please PM me so we can keep in touch as well.
So you think if I get the Bi-Xenon LCI headlights and plug them in, the Angel Eyes and LED Eyebrow will light up? Considering I have stock halogen at the moment.
Then I would just need a HID kit for the projectors?
I'm trying to ask a few guys here... Even BMW aren't sure..
Hi aacabriolet,
I got the new LCI headlights but have yet to get the LED eye-brow lit. No problem with the other bulbs. The new headlights have an additional pin. The attached pictures will give you a better idea. I'll try to get a jumper across. Will keep you posted.
toto4dwin is offline   Reply With Quote
      06-24-2011, 01:03 AM   #207
aacabriolet
Originally Posted by toto4dwin View Post
Hi aacabriolet,
Thanks. I got mine installed last week. We tapped angel eye wire for now for the eyebrow until BMW releases the wiring diagrams for the LED brow. We haven't found anything yet, let me know if you do and I'll do the same!
Thanks.
      06-27-2011, 07:01 AM   #208
thewist
Drives: BMW 135i Convertible
Rear Lights for 12/2008
Hello
I have a 135i convertible build 12/2008 with xenon and just sent my dad to buy a set of the new LEDs in Austria armed with Dackelone's part numbers (left tailight with rear fog : 63217273427, right tailight with rear fog : 63217273428)
I was then a bit confused when my dad put this guy on and he said to me on the phone that end number 427 doesn't talk about being LEDs but just states bulbs in his computer (maybe he didn't really know as I suppose there are some bulbs still in there such as the fog?).
And on top of it all he advised that I need a cable adapter and the footwell module for my car.
Now I think I have read that some guys here say that we don't need anything else than the new taillights and they are plug and play.
Can anyone confirm both the part numbers again and that it's not necessary to buy the footwell and an adapter cable before I get the gear shipped from Europe?
Thanks a lot.
thewist is offline   Reply With Quote
      07-07-2011, 11:39 PM   #209
daimeow
Hi outsider and everyone
The thick foam is item number 8, right? And it comes free with item number 9, right?
Thanks
Daimeow
daimeow is offline   Reply With Quote
      07-24-2011, 11:58 PM   #210
Xeretic
Drives: 135i N54
2 toto4dwin:
2 aacabriolet:
Hello guys! I was going to do an LCI headlight install to my 135i. As you have some experience in this can you help me out with some questions i had. Cant send you a PM yet till my account is fully activated so i will ask here:
1) Which part numbers did you use for ordering the LCI headlights?
2) Which P/N were your previous headlights?
3) Did all the bulbs fit from old healdights to new ones or did you buy it with all the lamps new?
4) Is it a PnP install or do i need to change the control unit and ALC box as well?
Xeretic is offline   Russian Federation
      07-25-2011, 03:56 AM   #211
toto4dwin
Drives:
63117273833 & 63117273834
63117181291 & 63117181292
from the old light = xenon + control unit & signal bulbs will fit
not PnP. I added a jumper to tap the DC supply from the ring light bulb. see attached.
      07-27-2011, 09:16 AM   #212
Stuart@BMRAutowerkes
Stuart@BMRAutowerkes's Avatar
Drives: a black car
PIC Request: I want to find out if the indicator/turn signal on the LCI taillights is RED or ORANGE. Please also state which vendor you got it from as it may differ between UK/US etc... Thanks
Stuart@BMRAutowerkes is offline   Reply With Quote
      07-28-2011, 08:17 AM   #213
Drives: a black car
bump... orange or red indicators anyone???
      07-28-2011, 04:04 PM   #214
amancuso
amancuso's Avatar
Drives: 00 Z3 2.3,12 R56, 12 128i
2008 128i  [0.50]
Never seen red. Only amber (orange).
2012 Mini Cooper Hatchback
amancuso is offline   Reply With Quote
      07-28-2011, 06:01 PM   #215
Drives: a black car
cool, thanks, I'll order a set
      07-29-2011, 11:05 AM   #216
romak47
romak47's Avatar
Drives: like a bat out of hell
For the LED LCI tail lights. Is the Braking pedal light an LED or is that still a regular halogen?
I will be all over it if its LED as that means the light illuminates faster and improves braking distance reaction time of people behind you.
a good read:
http://chemlinks.beloit.edu/BlueLigh...p/an1155-3.pdf
JB4, DCI, Digi boost, CSL eyelids, 5% tint, KW v2's. Bastuck 85mm quad w/ cat+resonator delete mids, LED int ltg, Perf SSK, CF int trim, 19" SF-71 rims, CDV mod, BMS OCC, ER+tial charge pipe. AR DP's, Helix IC,meth,
romak47 is offline   United_States
      08-01-2011, 11:11 AM   #217
Jonny Tea
Jonny Tea's Avatar
Drives: 123d M Sport Coupe in White
Hi there,
I've got a passenger side UK bi-xenon headlight with all bulbs and ballasts etc if anyone is interested?
email me at jon.thaxter@gmail.com for pictures etc.
Jonny Tea is offline   Reply With Quote
      08-08-2011, 04:27 PM   #218
bigmondy
Drives: 118i M Sport 3 Series Coupe
This thread has been a great read. 1 hour and the excitement in the posts is almost palpable.
bigmondy is offline   Reply With Quote
      08-10-2011, 09:29 AM   #219
fatjoez
baller
fatjoez's Avatar
Drives: lambo
Is coding required for the LCI tail lights?
Seems like just plug & play..
fs: oem lip spoiler - from e82 135i , pm me
fatjoez is offline   No_Country
      08-11-2011, 07:50 AM   #220
SDW335
SDW335's Avatar
Drives: BMW Drei-Reihen
Just installed mine - received from Tischer - and they light up when the brake pedal is presed, but that's it.....no running lights. What did I do wrong? Please help!!!!
SDW335 is offline   Reply With Quote
Reply
Forum Jump
